Home » Eclipse Projects » WindowBuilder » Support for Eclipse 4 Parts planned?
Support for Eclipse 4 Parts planned? [message #786628] Mon, 30 January 2012 11:55 Go to next message
I updated my Eclipse 4 Tutorial .
Using WindowBuilder for Eclipse 4 Parts is relatively simple, I just have to wrap the whole content of @PostConstruct into a composite and work with WindowBuilder on this composite.
Is it planned to have direct support for Parts in WindowBuilder? I have no idea about the internal structure of WindowBuilder but I think you could treat @PostConstruct similar to the createPartControl() method of ViewPart.
Re: Support for Eclipse 4 Parts planned? [message #787017 is a reply to message #786628] Mon, 30 January 2012 22:50 Go to previous messageGo to next message
Do you have a suggested template(s) we should use for new, clean e4 parts?
Re: Support for Eclipse 4 Parts planned? [message #787165 is a reply to message #787017] Tue, 31 January 2012 03:29 Go to previous messageGo to next message
The following would be a simple Part definition without any controls. The names of the methods are flexible with Eclipse 4, I like the existing ones, except that I added a "s" to the old createPartControl method.
package com.example.e4.rcp.todo.parts;
import javax.annotation.PostConstruct;
import javax.annotation.PreDestroy;
import org.eclipse.swt.widgets.Composite;
public class TodoDetailsPart {
@PostConstruct
public void createControls(Composite parent) {
@PreDestroy
public void dispose() {
@Focus
public void setFocus() {
// TODO Set Focus to control
[EDIT: Focus is mandatory, got confirmation from Remy Suen via IRC, changed method name to createControls()]
[Updated on: Wed, 01 February 2012 16:13] by Moderator
Re: Support for Eclipse 4 Parts planned? [message #790106 is a reply to message #787165] Fri, 03 February 2012 15:40 Go to previous messageGo to next message
Hm...
I've downloaded Eclipse 4.2M5 SDK, but I don't see "e4 Application Project" wizard.
Re: Support for Eclipse 4 Parts planned? [message #791748 is a reply to message #790106] Mon, 06 February 2012 03:07 Go to previous messageGo to next message
Am 03.02.12 21:40, schrieb Konstantin Scheglov:
> Hm...
> Project" wizard.
You need to install the e4 tools from the e4 update site [1].
Tom
[1]http://download.eclipse.org/e4/downloads/drops/S-0.12M5-201201271145/index.html
Re: Support for Eclipse 4 Parts planned? [message #794068 is a reply to message #791748] Wed, 08 February 2012 17:13 Go to previous messageGo to next message
Ah...
Thank you, Tom.
Re: Support for Eclipse 4 Parts planned? [message #1230040 is a reply to message #794068] Fri, 10 January 2014 16:16 Go to previous messageGo to next message
Hey,
I was able to builder a part with the WindowBuilder - pretty nice. I also tried to build a composite that conforms the e4 style since I usually compose my parts out of multiple composites. Unfortunately, it did not work as expected. This is my result:
public class MyComposite extends Composite {
	public MyComposite(Composite parent, int style) {
		super(parent, style);
		createContents();
	private void createContents() {
		Button btnNewButton = new Button(this, SWT.NONE);
		btnNewButton.setBounds(0, 0, 91, 29);
		btnNewButton.setText("New Button");
	protected void checkSubclass() {
		// Disable the check that prevents subclassing of SWT components
Am I doing it wrong? I would have expected a @PostConstruct annotation being able to use the eclipse context. Has anyone else tried to create a composite with die WindowBuilder so far? Thank you!
Kon
Re: Support for Eclipse 4 Parts planned? [message #1233095 is a reply to message #1230040] Sat, 18 January 2014 11:15 Go to previous messageGo to next message
The current Composite creation support creates generic SWT Composite classes that can be used in any SWT/RCP app. It does not generate e4 specific code in that case as that would limit where the code could be used. It would not be very hard to add an e4 Composite wizard/template. That isn't something we plan to do, but we are very open to contributions.
Re: Support for Eclipse 4 Parts planned? [message #1233123 is a reply to message #1233095] Sat, 18 January 2014 13:03 Go to previous messageGo to next message
Hey Eric,
the wizard would be the cherry on top Smile But for me it would be really nice being able to use WindowBuilder and Composites in the e4 specific way. For instance, the following example is not recognized by WindowBuilder in the Design tab.
	@Inject
	private IEclipseContext context;
	@PostConstruct
		Text text = new Text(this, SWT.BORDER);
		text.setText(".....");
		// here I'm able to use the context
It would help a lot if this e4 specific code would be recognized by WindowBuilder.
Thank you.
Kon
Re: Support for Eclipse 4 Parts planned? [message #1233192 is a reply to message #1233123] Sat, 18 January 2014 17:41 Go to previous messageGo to next message
Try adding the following line to the constructor...
if (java.beans.Beans.isDesignTime()) this.createContents();
Re: Support for Eclipse 4 Parts planned? [message #1243661 is a reply to message #786628] Tue, 11 February 2014 04:15 Go to previous message
Hey Eric,
thank you for the workaround Smile
Kon
Previous Topic:Jbuilder
Next Topic:Elements appear disordered
Current Time: Wed Jul 23 12:27:40 EDT 2025
Powered by FUDForum. Page generated in 0.11635 seconds
