Home » Eclipse Projects » Remote Application Platform (RAP) » NullPointerException while loading multiple reqeusts
NullPointerException while loading multiple reqeusts [message #1232129] Thu, 16 January 2014 04:35 Go to next message
Requirement:
1) Create a UI using RAP and deploy in Jboss server
2) Show the UI on the same browser using multiple iframes. So, the page will have same UI rendered multiple times.
Setup:
1) A guice filter which filters all the request going through
2) a rwt servlet to process RAP requests.
Error:
1) Some of the iframes throw a NPE. The error is intermittent but very visible (reproducible 9 times out of 10).
Error trace:
	org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.shutdownUISession(LifeCycleServiceHandler.java:163)
	org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.synchronizedService(LifeCycleServiceHandler.java:87)
	org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.service(LifeCycleServiceHandler.java:66)
	org.eclipse.rap.rwt.engine.RWTServlet.handleValidRequest(RWTServlet.java:119)
	org.eclipse.rap.rwt.engine.RWTServlet.handleRequest(RWTServlet.java:106)
	org.eclipse.rap.rwt.engine.RWTServlet.doGet(RWTServlet.java:92)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:734)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:847)
	com.google.inject.servlet.FilterChainInvocation.doFilter(FilterChainInvocation.java:66)
	com.google.inject.servlet.FilterDefinition.doFilter(FilterDefinition.java:168)
	com.google.inject.servlet.FilterChainInvocation.doFilter(FilterChainInvocation.java:58)
	com.google.inject.servlet.ManagedFilterPipeline.dispatch(ManagedFilterPipeline.java:118)
	com.google.inject.servlet.GuiceFilter.doFilter(GuiceFilter.java:113)
Thanks for the all the good work RAP team is doing.
Re: NullPointerException while loading multiple reqeusts [message #1232140 is a reply to message #1232129] Thu, 16 January 2014 04:53 Go to previous messageGo to next message
does it happen with RAP 2.2?
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: NullPointerException while loading multiple reqeusts [message #1232152 is a reply to message #1232140] Thu, 16 January 2014 05:08 Go to previous messageGo to next message
I am on RAP 2.1. I need to see if it happens with RAP 2.2 as well. I doubt its due to the creations of dummy session for GET requests.
// The GET request currently creates a dummy UI session needed for accessing the client
// information. It is not meant to be reused by other requests.
Re: NullPointerException while loading multiple reqeusts [message #1232156 is a reply to message #1232152] Thu, 16 January 2014 05:19 Go to previous messageGo to next message
Just found that it is not a problem with the GuiceFilter. It happens in general. following is the trace from eclipse jetty.
	at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.service(LifeCycleServiceHandler.java:65)
	at org.eclipse.rap.rwt.engine.RWTServlet.handleValidRequest(RWTServlet.java:119)
	at org.eclipse.rap.rwt.engine.RWTServlet.handleRequest(RWTServlet.java:106)
	at org.eclipse.rap.rwt.engine.RWTServlet.doGet(RWTServlet.java:92)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1448)
	at com.google.inject.servlet.DefaultFilterPipeline.dispatch(DefaultFilterPipeline.java:43)
	at com.google.inject.servlet.GuiceFilter.doFilter(GuiceFilter.java:113)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1419)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:455)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:557)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1075)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:384)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1009)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:255)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
	at org.eclipse.jetty.server.Server.handle(Server.java:368)
	at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:489)
	at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:53)
	at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:942)
	at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:1004)
	at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:640)
	at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
	at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:72)
	at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:264)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
	at java.lang.Thread.run(Thread.java:722)
Re: NullPointerException while loading multiple reqeusts [message #1233042 is a reply to message #1232156] Sat, 18 January 2014 07:38 Go to previous messageGo to next message
I tried this in RAP 2.2, and no luck. The issue is there as well. Below is the trace in RAP 2.2. Please let me know if I raise a bug. Thanks
	at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.shutdownUISession(LifeCycleServiceHandler.java:172)
	at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.synchronizedService(LifeCycleServiceHandler.java:88)
	at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.service(LifeCycleServiceHandler.java:67)
	at org.eclipse.rap.rwt.engine.RWTServlet.handleValidRequest(RWTServlet.java:121)
	at org.eclipse.rap.rwt.engine.RWTServlet.handleRequest(RWTServlet.java:108)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:457)
	at org.eclipse.jetty.server.Server.handle(Server.java:364)
Powered by Jetty://
Re: NullPointerException while loading multiple reqeusts [message #1233057 is a reply to message #1233042] Sat, 18 January 2014 08:31 Go to previous messageGo to next message
yes... please file a bug. Also, please create a simple project (maybe a
war for deployment) in order to fast check and reproduce the issue. Does
it happens only in JBoss? Did you try with Tomcat or Jetty?
Best,
Ivan
Ivan Furnadjiev
Re: NullPointerException while loading multiple reqeusts [message #1234282 is a reply to message #1233057] Tue, 21 January 2014 11:00 Go to previous messageGo to next message
Thanks. I will file a bug. I tested in Jboss 7.1 and Embedded Jetty. It happens in both. Thanks
Re: NullPointerException while loading multiple reqeusts [message #1234291 is a reply to message #1234282] Tue, 21 January 2014 11:18 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=426269
Re: NullPointerException while loading multiple reqeusts [message #1697108 is a reply to message #1234291] Mon, 01 June 2015 12:00 Go to previous messageGo to next message
I do not know if it is related, but since 3.0 RC2, I have randomly an exception when my application start
This does not seems to bother it, I do not see any issue, just this stacktrace once at startup, then it does not occur anymore
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.service(LifeCycleServiceHandler.java:66)
at org.eclipse.rap.rwt.engine.RWTServlet.handleValidRequest(RWTServlet.java:135)
at org.eclipse.rap.rwt.engine.RWTServlet.handleRequest(RWTServlet.java:117)
at org.eclipse.rap.rwt.engine.RWTServlet.doPost(RWTServlet.java:107)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.rap.rwt.osgi.internal.CutOffContextPathWrapper.service(CutOffContextPathWrapper.java:106)
at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1271)
at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:162)
at org.eclipse.equinox.http.servlet.internal.servlet.FilterChainImpl.doFilter(FilterChainImpl.java:50)
Re: NullPointerException while loading multiple reqeusts [message #1697112 is a reply to message #1697108] Mon, 01 June 2015 12:27 Go to previous messageGo to next message
Hi Arnaud,
I hope this is fixed in RC3. See https://git.eclipse.org/r/#/c/49000/.
Could you please check and report it ASAP. We are very very close to the
release build and if the issue persists we still have short time to fix it.
Ivan
Ivan Furnadjiev
Re: NullPointerException while loading multiple reqeusts [message #1697652 is a reply to message #1697112] Fri, 05 June 2015 12:24 Go to previous message
I confirm RC3 fixed this issue
Previous Topic:Custom Widget: Operation "create" on target "r183" of type "null" fai
Next Topic:Submitting a form using POST
Current Time: Sat Jul 26 20:36:56 EDT 2025
Powered by FUDForum. Page generated in 0.04514 seconds
