Home » Archived » Hudson » Hudson Configuration Changes can't be "Saved"(Hudson configuration)
Hudson Configuration Changes can't be "Saved" [message #1224659] Fri, 27 December 2013 06:30 Go to next message
Recently discovered that our Hudson system will no longer accept new user sign-ups or be able to be restricted (security matrix based). I'm sure it's something simple but obviously have googled for hours and made changes to the config.xml (commented out user permissions (authorization strategy) and changed from false to true for "Use Security" as well as multiple restarts. Any ideas folks?
java - jdk1.6.0_51
Hudson ver. 1.395 (I know it's old)
Re: Hudson Configuration Changes can't be "Saved" [message #1232447 is a reply to message #1224659] Thu, 16 January 2014 19:29 Go to previous messageGo to next message
May be you want to check if Hudson is picking up the correct Hudson home where you are making changes.
Re: Hudson Configuration Changes can't be "Saved" [message #1292233 is a reply to message #1232447] Fri, 11 April 2014 12:42 Go to previous message
Hi Prakash,
I have installed Hudson 3.1.2 on Solaris box version 5.10 and JDK used is 1.6.0_23. Page "Configure Security" does not display the "Save" Button. Restart is successful however after sometime below exceptions gets logged - Could you please help me understanding the issue
Apr 11, 2014 5:16:18 PM hudson.util.ProcessTree killAll
INFO: killAll (process started by build): process=java.lang.UNIXProcess@1ac8ba8 and envs={HUDSON_COOKIE=1ed810f2-a8ec-45e2-b221-6d1e1fa4f036}
Apr 11, 2014 5:16:18 PM hudson.model.Run run
INFO: Build locatesserver.idelta_trunk #9 main build action completed: SUCCESS
11-Apr-2014 17:35:55 org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /apps/phxrelaut/system/java/jdk1.6.0_23/jre/lib/sparc/server:/apps/phxrelaut/system/java/jdk1.6.0_23/jre/lib/sparc:/apps/phxrelaut/system/java/jdk1.6.0_23/jre/../lib/sparc:/usr/jdk/packages/lib/sparc:/lib:/usr/lib
11-Apr-2014 17:35:55 org.apache.coyote.http11.Http11Protocol init
SEVERE: Error initializing endpoint
java.net.BindException: Address already in use <null>:8080
at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:549)
at org.apache.coyote.http11.Http11Protocol.init(Http11Protocol.java:176)
Previous Topic:how to configure mail ext plugin
Next Topic:Problems : Unable to read .../hudson/hudson_home/hudson-security.xml
Current Time: Sat Jul 26 05:39:05 EDT 2025
Powered by FUDForum. Page generated in 0.05154 seconds
