Home » Language IDEs » C / C++ IDE (CDT) » A problem with Remote Debugging(compile and upload OK, debugging fails)
| A problem with Remote Debugging [message #1228166] |
Mon, 06 January 2014 10:09  |
I am trying to configure a virtual machine (Debian 7 Wheeze) to cross-comile for ARM9 processor working on a Aria G25 board(www.acmesystems.it / aria). I've found a manual (www.lvr.com / eclipse1.htm) for something similar (the manual is for another board and for Ubuntu, not Debian). Despite the differences I had success almost with everything from this manual by selecting appropriate components for Debian.
For now I made Eclipse to compile for ARM, to automatically upload the application to the board and even to run it (both being connected to the board by SSH or clicking "run" in Eclipse)... what I don't yet have (but I really need it) is the remote debugging of the application. I.e. when I click "debug" I need the toolchain to compile for debugging, upload the file to the board and start debugging. As I've already wrote, I have everything but the last and I don't know why it does not happen. All I get in Eclipse as a result is this:
Quote:Last login: Sun Dec 22 15:48:21 2013 from mycomputer.domain.de
echo $PWD'>'
chmod 777 /crossdev/helloworld/helloworld;gdbserver :2345 /crossdev/helloworld/helloworld;exit
root@ariag25:~# echo $PWD'>'
/root>
root@ariag25:~# chmod 777 /crossdev/helloworld/helloworld;gdbserver :2345 /cross dev/helloworld/helloworld;exit
Process /crossdev/helloworld/helloworld created; pid = 2324
Listening on port 2345
Remote debugging from host 192.168.21.204
readchar: Got EOF
Remote side has terminated connection. GDBserver will reopen the connection.
| Re: A problem with Remote Debugging [message #1230658 is a reply to message #1228177] |
Sun, 12 January 2014 13:19   |
Marc Khouzam wrote on Mon, 06 January 2014 10:34The EOF you see could be that GDB crashed. When this happens, check if your GDB is still running or not.
You can also look at the 'gdb traces' to see what is happening with GDB:
http://wiki.eclipse.org/CDT/User/FAQ#I.27ve_been_asked_for_.27gdb_traces.27.2C_where_can_I_find_them.3F
Marc
Remote Debugging FAQ:
http://wiki.eclipse.org/CDT/User/FAQ#How_do_I_debug_a_remote_application.3F
Yes, seems GDB crashes. Here is the gdb trace (I have a line "192.168.21.209 ariag25" in my /etc/hosts to map the board):
097,342 2-environment-cd /home/super/workspace/helloworld
097,343 2^done
097,344 (gdb)
097,346 3^done
097,346 (gdb)
097,346 3-gdb-set breakpoint pending on
097,347 4^done
097,347 (gdb)
097,347 4-enable-pretty-printing
097,348 &"maintenance set python print-stack off\n"
097,348 5^done
097,349 (gdb)
097,349 5maintenance set python print-stack off
097,358 6-gdb-set print object on
097,358 6^done
097,358 (gdb)
097,359 7-gdb-set print sevenbit-strings on
097,359 7^done
097,359 (gdb)
097,360 8-gdb-set host-charset UTF-8
097,360 8^done
097,360 (gdb)
097,361 9-gdb-set target-charset UTF-8
097,361 9^done
097,361 (gdb)
097,366 10-gdb-set target-wide-charset UTF-32
097,372 10^done
097,372 (gdb)
097,373 11source .gdbinit
097,373 &"source .gdbinit\n"
097,374 11^done
097,374 (gdb)
097,375 12-gdb-set target-async off
097,375 12^done
097,375 (gdb)
097,376 13-gdb-set auto-solib-add on
097,376 13^done
097,376 (gdb)
097,385 14-file-exec-and-symbols /home/super/workspace/helloworld/Debug-cross/helloworld
097,395 14^done
097,395 (gdb)
097,403 15-target-select remote ARIAG25:2345
097,494 =thread-group-created,id="42000"
097,494 =thread-created,id="1",group-id="42000"
097,496 16-list-thread-groups --available
097,513 =thread-group-exited,id="42000"
097,514 15^error,msg="Malformed packet(b) (missing colon): ore:0;\nPacket: 'T050b:00000000;0d:a0fdff\
be;0f:c0a7fdb6;thread:89d;core:0;'\n"
097,514 (gdb)
097,515 16^error,msg="Don't know how to get OS data. Try \"help target\"."
097,515 (gdb)
097,539 17-gdb-exit
097,541 17^exit
I've tryed to find info on this "Malformed packet" error and didn't have much success, the only thing that could help people with the same error was checking the versions of gdb and gdbserver to be equal.
My are not:
I have gdbserver of version 7.4.1+dfsg-0.1 at the board and gdb-arm-linux-gnueabi of version 7.0.1.-2 in the eclipse settings in "Run / Debug Configurations / C/C++ Remote Application / helloworld Debug-cross / Debugger / GDB Debugger" where helloworld and Debug-cross are the titles of my eclipse project and its build configuration.
And I have no other gdb on my development computer installed, only this gdb-arm-linux-gnueabi. I used this one because in the tutorial I mentioned earlier an another gdb-debugger for arm is being installed (arm-angstrom-linux-gnueabi-gdb, www.lvr.com / eclipse5.htm), so I just searched available packets for arm and gdb and chose the gdb-arm-linux-gnueabi.
If this theory, that the problem is in different versions, is right, can I just install the gdb (removing the gdb-arm-linux-gnueabi) and changing the debug configuration accordingly?
Or is this theory completely wrong?
[Updated on: Sun, 12 January 2014 13:21] by Moderator
| Re: A problem with Remote Debugging [message #1232277 is a reply to message #1228177] |
Thu, 16 January 2014 10:27   |
Marc
Thank you Marc. After some times I managed getting all the dependencies and building the gdb of an appropriate version with --target=arm-linux-gnueabi.
For some reason "make install" didn't move all of the files into their places as I expceted (for example, I don't have gdb in /usr/bin/. Despite that the gdb seems to work -- I pointed the Eclipse Debug configuration to the compiled gdb, it lays where it was compiled, in my user directory. When I gave this version of gdb to Eclispe, the debugging actually started working but with a pair of additional problems.
The first is
warning: Unable to find dynamic linker breakpoint function.
GDB will be unable to debug shared library initializers
and track explicitly loaded dynamic code."
if I understand right, it seems to happen because gdb doesn't have access to some libraries that are supposed to be on my board. The supposed (somewhere in internet) solution for this is having those libraries on the development computer and setting the appropriate option of gdb, for it to know the path to libraries.
The other problem is the error "Cannot access memory at address 0x0" which comes when I start debugging, before I make any actions. It doesn't seem to break anything, but who knows... Perhaps it doesnt't break anything because I have nothing to break? I have only a pair actual strings in the programm:
#include <stdio.h>
int main()
int a = 5;
printf("Hello World!\n");
return 0;
Should I worry about this error? Can it be repaired?
P.S. Here is the gdb trace:
844,426 2-environment-cd /home/super/workspace/helloworld
844,430 2^done
844,430 (gdb)
844,430 3-gdb-set breakpoint pending on
844,431 3^done
844,431 (gdb)
844,431 4-gdb-set detach-on-fork on
844,431 4^done
844,431 (gdb)
844,432 5-enable-pretty-printing
844,433 5^done
844,433 (gdb)
844,435 6-gdb-set python print-stack none
844,435 6^done
844,435 (gdb)
844,440 7-gdb-set print object on
844,440 7^done
844,440 (gdb)
844,447 8-gdb-set print sevenbit-strings on
844,447 8^done
844,447 (gdb)
844,450 9-gdb-set host-charset UTF-8
844,452 9^done
844,452 (gdb)
844,452 10-gdb-set target-charset UTF-8
844,452 10^done
844,452 (gdb)
844,453 11-gdb-set target-wide-charset UTF-32
844,453 11^done
844,453 (gdb)
844,454 12source .gdbinit
844,455 &"source .gdbinit\n"
844,457 12^done
844,457 (gdb)
844,457 13-gdb-set target-async off
844,458 13^done
844,458 (gdb)
844,458 14-gdb-set auto-solib-add on
844,458 14^done
844,458 (gdb)
844,462 15-file-exec-and-symbols --thread-group i1 /home/super/workspace/helloworld/Debug-cross/hell\
oworld
844,501 15^done
844,501 (gdb)
844,513 16-target-select remote ARIAG25:2345
844,602 =thread-group-started,id="i1",pid="42000"
844,603 17-list-thread-groups --available
844,604 =thread-created,id="1",group-id="i1"
844,616 18-thread-info 1
844,617 &"warning: Unable to find dynamic linker breakpoint function.\nGDB will be unable to debug s\
hared library initializers\nand track explicitly loaded dynamic code."
844,617 &"\n"
844,640 *stopped,frame={addr="0xb6fda7c0",func="??",args=[]},thread-id="1",stopped-threads="all",cor\
e="0"
844,648 16^connected
844,648 (gdb)
844,649 19-data-evaluate-expression --thread-group i1 "sizeof (void*)"
844,792 17^done,groups=[{id="1",type="process",description="init [2]",user="root",cores=["0"]},{id="\
2",type="process",description="[kthreadd]",user="root",cores=["0"]},{id="3",type="process",descripti\
on="[ksoftirqd/0]",user="root",cores=["0"]},{id="4",type="process",description="[kworker/0:0]",user=\
"root",cores=["0"]},{id="5",type="process",description="[kworker/0:0H]",user="root",cores=["0"]},{id\
="6",type="process",description="[kworker/u2:0]",user="root",cores=["0"]},{id="7",type="process",des\
cription="[khelper]",user="root",cores=["0"]},{id="8",type="process",description="[kdevtmpfs]",user=\
"root",cores=["0"]},{id="154",type="process",description="[writeback]",user="root",cores=["0"]},{id=\
"156",type="process",description="[bioset]",user="root",cores=["0"]},{id="158",type="process",descri\
ption="[kblockd]",user="root",cores=["0"]},{id="187",type="process",description="[khubd]",user="root\
",cores=["0"]},{id="202",type="process",description="[cfg80211]",user="root",cores=["0"]},{id="203",\
type="process",description="[kworker/0:1]",user="root",cores=["0"]},{id="292",type="process",descrip\
tion="[kswapd0]",user="root",cores=["0"]},{id="293",type="process",description="[fsnotify_mark]",use\
r="root",cores=["0"]},{id="294",type="process",description="[crypto]",user="root",cores=["0"]},{id="\
398",type="process",description="[w1_bus_master1]",user="root",cores=["0"]},{id="414",type="process"\
,description="[deferwq]",user="root",cores=["0"]},{id="419",type="process",description="[kworker/u2:\
2]",user="root",cores=["0"]},{id="422",type="process",description="[mmcqd/0]",user="root",cores=["0"\
]},{id="428",type="process",description="[jbd2/mmcblk0p2-]",user="root",cores=["0"]},{id="429",type=\
"process",description="[ext4-rsv-conver]",user="root",cores=["0"]},{id="430",type="process",descript\
ion="[ext4-unrsv-conv]",user="root",cores=["0"]},{id="545",type="process",description="udevd --daemo\
n",user="root",cores=["0"]},{id="660",type="process",description="udevd --daemon",user="root",cores=\
["0"]},{id="661",type="process",description="udevd --daemon",user="root",cores=["0"]},{id="1549",typ\
e="process",description="[jbd2/mmcblk0p3-]",user="root",cores=["0"]},{id="1550",type="process",descr\
iption="[ext4-rsv-conver]",user="root",cores=["0"]},{id="1551",type="process",description="[ext4-unr\
sv-conv]",user="root",cores=["0"]},{id="1951",type="process",description="/usr/bin/dbus-daemon --sys\
tem",user="messagebus",cores=["0"]},{id="1992",type="process",description="dhclient -v -pf /run/dhcl\
ient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases eth0",user="root",cores=["0"]},{id="2048",type=\
"process",description="/usr/sbin/lighttpd -f /etc/lighttpd/lighttpd.conf",user="www-data",cores=["0"\
]},{id="2049",type="process",description="/usr/bin/php-cgi",user="www-data",cores=["0"]},{id="2055",\
type="process",description="/usr/bin/php-cgi",user="www-data",cores=["0"]},{id="2059",type="process"\
,description="/usr/bin/php-cgi",user="www-data",cores=["0"]},{id="2061",type="process",description="\
/usr/bin/php-cgi",user="www-data",cores=["0"]},{id="2078",type="process",description="/usr/bin/php-c\
gi",user="www-data",cores=["0"]},{id="2080",type="process",description="avahi-daemon: running [ariag\
25.local]",user="avahi",cores=["0"]},{id="2081",type="process",description="/usr/bin/php-cgi",user="\
www-data",cores=["0"]},{id="2082",type="process",description="/usr/bin/php-cgi",user="www-data",core\
s=["0"]},{id="2083",type="process",description="avahi-daemon: chroot helper",user="avahi",cores=["0"\
]},{id="2084",type="process",description="/usr/bin/php-cgi",user="www-data",cores=["0"]},{id="2128",\
type="process",description="/usr/bin/shellinaboxd -q --background=/var/run/shellinaboxd.pid -c /var/\
lib/shellinabox -p 4200 -u shellinabox -g shellinabox --user-css Black on White:+/etc/shellinabox/op\
tions-enabled/00+Black on White.css,White On Black:-/etc/shellinabox/options-enabled/00_White On Bla\
ck.css;Color Terminal:+/etc/shellinabox/options-enabled/01+Color Terminal.css,Monochrome:-/etc/shell\
inabox/options-enabled/01_Monochrome.css -s/:LOGIN -t --no-beep",user="shellinabox",cores=["0"]},{id\
="2129",type="process",description="/usr/bin/shellinaboxd -q --background=/var/run/shellinaboxd.pid \
-c /var/lib/shellinabox -p 4200 -u shellinabox -g shellinabox --user-css Black on White:+/etc/shelli\
nabox/options-enabled/00+Black on White.css,White On Black:-/etc/shellinabox/options-enabled/00_Whit\
e On Black.css;Color Terminal:+/etc/shellinabox/options-enabled/01+Color Terminal.css,Monochrome:-/e\
tc/shellinabox/options-enabled/01_Monochrome.css -s/:LOGIN -t --no-beep",user="shellinabox",cores=["\
0"]},{id="2130",type="process",description="startpar -f -- shellinabox",user="root",cores=["0"]},{id\
="2143",type="process",description="/usr/sbin/sshd",user="root",cores=["0"]},{id="2169",type="proces\
s",description="/sbin/getty 38400 tty1",user="root",cores=["0"]},{id="2170",type="process",descripti\
on="/sbin/getty 38400 tty2",user="root",cores=["0"]},{id="2171",type="process",description="/sbin/ge\
tty 38400 tty3",user="root",cores=["0"]},{id="2172",type="process",description="/sbin/getty 38400 tt\
y4",user="root",cores=["0"]},{id="2173",type="process",description="/sbin/getty 38400 tty5",user="ro\
ot",cores=["0"]},{id="2174",type="process",description="/sbin/getty 38400 tty6",user="root",cores=["\
0"]},{id="2175",type="process",description="/sbin/getty -L ttyS0 115200 vt100",user="root",cores=["0\
"]},{id="2191",type="process",description="sshd: root@pts/2",user="root",cores=["0"]},{id="2193",typ\
e="process",description="/usr/lib/openssh/sftp-server",user="root",cores=["0"]},{id="2194",type="pro\
cess",description="/usr/lib/openssh/sftp-server",user="root",cores=["0"]},{id="2276",type="process",\
description="-bash",user="root",cores=["0"]},{id="2282",type="process",description="gdbserver :2345 \
/crossdev/helloworld/helloworld",user="root",cores=["0"]},{id="2285",type="process",description="/cr\
ossdev/helloworld/helloworld",user="root",cores=["0"]}]
844,795 20-list-thread-groups
844,795 (gdb)
844,800 &"Cannot access memory at address 0x0\n"
844,801 18^done,threads=[{id="1",target-id="Thread 2285",frame={level="0",addr="0xb6fda7c0",func="??\
",args=[]},state="stopped",core="0"}]
844,801 (gdb)
844,808 19^done,value="4"
844,809 (gdb)
844,809 21-interpreter-exec --thread-group i1 console "show endian"
844,834 20^done,groups=[{id="i1",type="process",pid="42000",executable="/home/super/workspace/hellow\
orld/Debug-cross/helloworld",cores=["0"]}]
844,834 (gdb)
844,834 ~"The target endianness is set automatically (currently little endian)\n"
844,834 21^done
844,835 (gdb)
844,854 22-break-insert --thread-group i1 -f /home/super/workspace/helloworld/helloworld.c:12
844,859 22^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x000084d8",func="m\
ain()",file="../helloworld.c",fullname="/home/super/workspace/helloworld/helloworld.c",line="12",tim\
es="0",original-location="/home/super/workspace/helloworld/helloworld.c:12"}
844,860 (gdb)
844,884 23-break-insert --thread-group i1 -t -f main
844,889 23^done,bkpt={number="2",type="breakpoint",disp="del",enabled="y",addr="0x000084d8",func="ma\
in()",file="../helloworld.c",fullname="/home/super/workspace/helloworld/helloworld.c",line="12",time\
s="0",original-location="main"}
844,889 (gdb)
844,890 24-exec-continue --thread-group i1
844,905 24^running
844,906 *running,thread-id="all"
844,906 (gdb)
844,914 25remote get /proc/cpuinfo /tmp/org.eclipse.cdt.dsf.gdb.cpuinfo.13
845,030 =library-loaded,id="/usr/lib/arm-linux-gnueabi/libstdc++.so.6",target-name="/usr/lib/arm-lin\
ux-gnueabi/libstdc++.so.6",host-name="/usr/lib/arm-linux-gnueabi/libstdc++.so.6",symbols-loaded="0",\
thread-group="i1"
845,031 =library-loaded,id="/lib/arm-linux-gnueabi/libm.so.6",target-name="/lib/arm-linux-gnueabi/li\
bm.so.6",host-name="/lib/arm-linux-gnueabi/libm.so.6",symbols-loaded="0",thread-group="i1"
845,031 =library-loaded,id="/lib/arm-linux-gnueabi/libgcc_s.so.1",target-name="/lib/arm-linux-gnueab\
i/libgcc_s.so.1",host-name="/lib/arm-linux-gnueabi/libgcc_s.so.1",symbols-loaded="0",thread-group="i\
1"
845,031 =library-loaded,id="/lib/arm-linux-gnueabi/libc.so.6",target-name="/lib/arm-linux-gnueabi/li\
bc.so.6",host-name="/lib/arm-linux-gnueabi/libc.so.6",symbols-loaded="0",thread-group="i1"
845,031 =library-loaded,id="/lib/ld-linux.so.3",target-name="/lib/ld-linux.so.3",host-name="/lib/ld-\
linux.so.3",symbols-loaded="0",thread-group="i1"
845,031 &"warning: Could not load shared library symbols for 5 libraries, e.g. /usr/lib/arm-linux-gn\
ueabi/libstdc++.so.6.\nUse the \"info sharedlibrary\" command to see the complete listing.\nDo you n\
eed \"set solib-search-path\" or \"set sysroot\"?"
845,031 &"\n"
845,050 =breakpoint-modified,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x0000\
84d8",func="main()",file="../helloworld.c",fullname="/home/super/workspace/helloworld/helloworld.c",\
line="12",times="1",original-location="/home/super/workspace/helloworld/helloworld.c:12"}
845,051 =breakpoint-modified,bkpt={number="2",type="breakpoint",disp="del",enabled="y",addr="0x00008\
4d8",func="main()",file="../helloworld.c",fullname="/home/super/workspace/helloworld/helloworld.c",l\
ine="12",times="1",original-location="main"}
845,070 *stopped,reason="breakpoint-hit",disp="keep",bkptno="1",frame={addr="0x000084d8",func="main"\
,args=[],file="../helloworld.c",fullname="/home/super/workspace/helloworld/helloworld.c",line="12"},\
thread-id="1",stopped-threads="all",core="0"
845,072 =breakpoint-deleted,id="2"
845,072 (gdb)
845,072 &"remote get /proc/cpuinfo /tmp/org.eclipse.cdt.dsf.gdb.cpuinfo.13\n"
845,083 ~"Successfully fetched file \"/proc/cpuinfo\".\n"
845,084 25^done
845,084 (gdb)
845,099 26-list-thread-groups i1
845,102 26^done,threads=[{id="1",target-id="Thread 2285",frame={level="0",addr="0x000084d8",func="ma\
in",args=[],file="../helloworld.c",fullname="/home/super/workspace/helloworld/helloworld.c",line="12\
"},state="stopped",core="0"}]
845,102 (gdb)
845,108 27-thread-info 1
845,111 27^done,threads=[{id="1",target-id="Thread 2285",frame={level="0",addr="0x000084d8",func="ma\
845,112 (gdb)
845,623 28-list-thread-groups
845,627 28^done,groups=[{id="i1",type="process",pid="42000",executable="/home/super/workspace/hellow\
845,627 (gdb)
845,684 29-stack-info-depth --thread 1 11
845,684 29^done,depth="1"
845,684 (gdb)
845,868 30-stack-list-locals --thread 1 --frame 0 1
845,869 30^done,locals=[{name="a",value="0"}]
845,869 (gdb)
845,889 31-stack-info-depth --thread 1
845,890 31^done,depth="1"
845,890 (gdb)
845,891 32-var-create --thread 1 --frame 0 - * a
845,891 32^done,name="var1",numchild="0",value="0",type="int",thread-id="1",has_more="0"
845,892 (gdb)
850,863 33-interpreter-exec --thread-group i1 console kill
850,865 ~"Kill the program being debugged? (y or n) [answered Y; input not from terminal]\n"
850,865 =thread-group-exited,id="i1"
850,865 33^done
850,865 (gdb)
850,896 34-gdb-exit
850,897 34^exit
850,909 35-break-delete --thread-group i1 1
[Updated on: Thu, 16 January 2014 10:28] by Moderator
| Re: A problem with Remote Debugging [message #1232752 is a reply to message #1232285] |
Fri, 17 January 2014 11:30   |
Marc Khouzam wrote on Thu, 16 January 2014 10:50I wouldn't worry about those just yet, if your debugging seems to work properly.
The first error seems to say you won't be able to debug dynamically loaded code, so unless you need that case, don't worry about it.
The second happens sometimes when GDB tries to access memory while the program is running. Since it only seems to happen at
the beginning in your case, it looks like things are good after and the debugging session will work properly.
Happy debugging!
Marc
Thank you again, Marc, but seems I need sometimes to have a possibility of debugging a shared library, so the first problem looks like to be necessary to solve.
According to what I've managed to understand, to solve it I must copy the /usr from the board to a directory on the development PC and point the GDB to it adding "set sysroot /path/to/that/directory" to .gdbinit and this seems to do the job.
Is my theory right?
[Updated on: Fri, 17 January 2014 11:31] by Moderator
| Re: A problem with Remote Debugging [message #1233792 is a reply to message #1233779] |
Mon, 20 January 2014 08:45  |
Roman Reimche wrote on Mon, 20 January 2014 08:03Thank you very much for your help, Marc.
by the way, adding "set sysroot remote:/" solved the problem. And now I have another one:
Function "internal_error" not defined.
Function "info_command" not defined.
Trying to understand what's it about or where to get those functions. That's the relative part of the traces:
116,185 22-break-insert --thread-group i1 -f internal_error
116,185 23-break-insert --thread-group i1 -f info_command
116,186 24-break-insert --thread-group i1 -f /home/super/workspace/helloworld/helloworld.c:12
116,186 &"Function \"internal_error\" not defined.\n"
116,188 22^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="<PENDING>",pending=\
"internal_error",times="0",original-location="internal_error"}
116,188 (gdb)
116,198 &"Function \"info_command\" not defined.\n"
116,198 23^done,bkpt={number="2",type="breakpoint",disp="keep",enabled="y",addr="<PENDING>",pending=\
"info_command",times="0",original-location="info_command"}
116,198 (gdb)
116,199 24^done,bkpt={number="3",type="breakpoint",disp="keep",enabled="y",addr="0x000084d8",func="m\
116,199 (gdb)
116,213 25-break-insert --thread-group i1 -t -f main
116,218 25^done,bkpt={number="4",type="breakpoint",disp="del",enabled="y",addr="0x000084d8",func="ma\
Current Time: Sat Oct 25 18:28:49 EDT 2025
Powered by FUDForum. Page generated in 0.05717 seconds
