Home » Eclipse Projects » Eclipse Platform » new File(".")
new File(".") [message #123120] Fri, 05 September 2003 11:12 Go to next message
Originally posted by: npatel.indigostone.com
Dear Friends,
I am running a simple test which shows some descripancy between buliding
from ant within eclipse and build from eclipse run facility. I ran simple
check program from eclipse and ant and found following results.
From ANT: c:\eclipse\TEST.TXT
From eclipse run: c:\nilesh\env\TEST.TXT
Please note that eclipse was started from "c:\eclipse" and then java project
was created with path "c:\nilesh\env"
JAVA FILE:
import java.io.File;
public class pathCheck
public static void main(String[] args)
pathCheck t = new pathCheck();
File file = new File("TEST.TXT");
System.out.println("FILE PATH = " + file.getAbsolutePath());
I don't know why running from ant replaces project path with eclipse
start-up path. I would like to configure ant such that project path
("c:\nilesh\env") gets taken as base dir of pathCheck class. Please help.
Love you all,
nilesh
Re: new File(".") [message #123157 is a reply to message #123120] Fri, 05 September 2003 11:28 Go to previous messageGo to next message
Which Eclipse are you using?
You are running Ant within the same VM as Eclipse.
See bug 30353 comment #4
In Eclipse 3.0 you can run Eclipse in a separate VM as a solution
Or you could base your pathCheck basedir based on the location of a known
resource using getClass().getResource(String)
HTH
Darins
"eclipse" <npatel@indigostone.com> wrote in message
news:bja8jj$lgk$1@eclipse.org...
> Dear Friends,
project
> JAVA FILE:
> Love you all,
> nilesh
Re: new File(".") [message #123192 is a reply to message #123157] Fri, 05 September 2003 11:43 Go to previous messageGo to next message
Thanks for your reply,
I am running eclipse 2.1,as it is the current GA release. I can not use 3.0.
However please help me on step by step instruction on "how to run Eclipse in
a separate VM?" I have only started working on eclipse from yseterday,
switching from netbeans.
Thanks for you help and looking forward to hearing again.
Nilesh
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:bja9vq$mtq$1@eclipse.org...
> HTH
> Darins
> > Dear Friends,
simple
> project
> > JAVA FILE:
help.
> > Love you all,
> > nilesh
Re: new File(".") [message #123204 is a reply to message #123192] Fri, 05 September 2003 11:39 Go to previous messageGo to next message
You are much more likely to have success by adapting your Ant build file or
your pathCheck code as I indicated.
But you can see Bug 24129 comment #10 and start from there.
HTH
Darins
ps you should likely move to the 2.1.1 as this is the latest release.
news:bjaae7$nf4$1@eclipse.org...
3.0.
in
> Nilesh
known
> > HTH
> > Darins
> > > Dear Friends,
buliding
> simple
> > project
> > > JAVA FILE:
> help.
> > > Love you all,
> > > nilesh
Re: new File(".") [message #123213 is a reply to message #123204] Fri, 05 September 2003 12:27 Go to previous messageGo to next message
I just looked at ant manual, and found that java task is associated with
attribute called "fork=true/false",. By default it is false. By setting it
to true, it runs in external jvm and provides the results as required.
Thanks for everyones effort and if you guys have anyt comment or disagree
with my message, then please write me back.
Thanks in the meantime, and I must admit, I am beginning to adopt eclipse
platform as opposed to netbeans.
Thanks again
Nilesh
news:bjaajs$nkg$1@eclipse.org...
or
> HTH
> Darins
> 3.0.
Eclipse
> in
> > Nilesh
> known
> > > HTH
> > > Darins
> > > > Dear Friends,
> buliding
> > simple
> > > project
> > > > JAVA FILE:
> > help.
> > > > Love you all,
> > > > nilesh
Re: new File(".") [message #123236 is a reply to message #123213] Fri, 05 September 2003 13:08 Go to previous message
news:bjad17$q3n$1@eclipse.org...
Well that will work...sorry I didn't give you that advice first :-)
Good thing or else you will have to change name from eclipse to netbeans :-)
Darins
Previous Topic:Absent line number attribute while debugging!
Next Topic:A question of update
Current Time: Tue Nov 04 21:47:04 EST 2025
Powered by FUDForum. Page generated in 0.03682 seconds
