Home » Eclipse Projects » Remote Application Platform (RAP) » Graphic is disposed
Graphic is disposed [message #1231378] Tue, 14 January 2014 09:19 Go to next message
in out Application class we create image with
"ImageDescriptor.createFromURL(url).createImage()" and use them as
window images like this "Window.setDefaultImages(images);". The start
method looks like this:
Display display = null;
Image[] images = null;
try {
display = PlatformUI.createDisplay();
images = setWindowDefaultImages();
int returnCode = PlatformUI.createAndRunWorkbench(display, new
ApplicationWorkbenchAdvisor());
if (returnCode == PlatformUI.RETURN_RESTART) {
return IApplication.EXIT_RESTART;
return IApplication.EXIT_OK;
catch (Exception e) {
return getApplicationStatus(e);
finally {
dispose(display, images);
In the dispose method we dispose the created images as the javadoc
states in imageDescriptor.createImage().
Unfortunatelly, this leads to an Exception "Graphic is disposed", if a
second instance (browser tab or window) of our application is opend and
closed. Then the "old" instance in the first tab throws this exception.
Is it correct to dispose images created by
imageDescriptor.createImage()? Any hints?
Markus
Re: Graphic is disposed [message #1231784 is a reply to message #1231378] Wed, 15 January 2014 06:49 Go to previous messageGo to next message
Hi Markus,
could you create and attach a complete simple project that demonstrate
the issue?
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Graphic is disposed [message #1231788 is a reply to message #1231378] Wed, 15 January 2014 06:59 Go to previous messageGo to next message
Hi Markus,
could you post a stacktrace and maybe the dispose method?
You don't share image instances across sessions, do you?
Generally, RAP does not deviate from the API contracts of JFace unless
stated otherwise. So, yes, it's correct to dispose these images.
Ralf
Ralf Sternberg
Re: Graphic is disposed [message #1231849 is a reply to message #1231784] Wed, 15 January 2014 09:54 Go to previous messageGo to next message
Sure :-)
I can't actually reproduct that the exceptionto occurs like in our
application, but in the attached extended mail demo you can see, that
the images are shared among sessions somehow, although ever session
creates its own images. Maybe this is the cause of our stacktrace.
To reproduce:
1. Start the application
2. Click "Open Message" or "About"
3. You can see, that the window images are used as expected
4. Now, open the app in a seconnd tab, window or a different browser
5. Window images still working
6. Now, close one of the opened apps
7. Click "Open Message" or "About" in the other app
8. You can see, that there are no window imagas used anymore
9. Now, open the app again in a seconnd tab, window or a different browser
10. Window images are now working again in both apps
Markus
Am 15.01.2014 12:49, schrieb Ivan Furnadjiev:
> Hi Markus,
> the issue?
> Best,
> Ivan
Re: Graphic is disposed [message #1231852 is a reply to message #1231788] Wed, 15 January 2014 10:00 Go to previous messageGo to next message
No, we do not share image by intention.
Here is the stacktrace (its pretty long):
osgi> !SESSION 2014-01-15 15:55:26.925
eclipse.buildId=unknown
java.version=1.6.0_30
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -dev
file:W:/workspaces/myapp-rap/.metadata/.plugins/org.eclipse.pde.core/myapp
WEB/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -console
-data
W:\workspaces\myapp-rap/.metadata/.plugins/org.eclipse.rap.tools.launch/myappWEB
!ENTRY org.eclipse.rap.ui.workbench 4 2 2014-01-15 15:56:37.568
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.rap.ui.workbench".
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:3582)
at org.eclipse.swt.SWT.error(SWT.java:3505)
at org.eclipse.swt.SWT.error(SWT.java:3476)
at org.eclipse.swt.widgets.Widget.error(Widget.java:1031)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:973)
at org.eclipse.swt.widgets.Widget.removeDisposeListener(Widget.java:492)
at
org.eclipse.swt.widgets.Control.removeMenuDisposeListener(Control.java:2528)
at org.eclipse.swt.widgets.Control.releaseWidget(Control.java:2343)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:861)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:855)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:856)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1124)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1127)
at org.eclipse.jface.window.Window.close(Window.java:347)
at
org.eclipse.jface.window.ApplicationWindow.close(ApplicationWindow.java:307)
at
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1822)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:726)
at
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:702)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:818)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:816)
at org.eclipse.jface.window.WindowManager.close(WindowManager.java:110)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1151)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1148)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1071)
at org.eclipse.ui.internal.Workbench$21.run(Workbench.java:1337)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1335)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1297)
at
org.eclipse.ui.internal.Workbench$ShutdownHandler.handleEvent(Workbench.java:387)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:85)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:651)
at org.eclipse.swt.widgets.Display.sendDisposeEvent(Display.java:741)
at org.eclipse.swt.widgets.Display.release(Display.java:724)
at org.eclipse.swt.graphics.Device.dispose(Device.java:276)
at
de.cenit.myapp.ui.workbench.internal.Application.dispose(Application.java:244)
at
de.cenit.myapp.ui.workbench.internal.Application.start(Application.java:124)
at
org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
at
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:186)
at
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:298)
at java.lang.Thread.run(Thread.java:662)
at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:104)
2014-01-15 15:56:37,568 [UIThread [141e53f]] ERROR
org.eclipse.core.runtime - Problems occurred when invoking code from
plug-in: "org.eclipse.rap.ui.workbench".
at
at
at
at
at
at
at
at
at
at
at
[de.cenit.myapp.core.logging.internal.Log4jLogListener@14fcd9a] ERROR
org.eclipse.rap.ui.workbench - Problems occurred when invoking code
from plug-in: "org.eclipse.rap.ui.workbench".
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jface 4 0 2014-01-15 15:56:37.568
!MESSAGE Beim Schließen der Workbench ist ein Fehler aufgetreten.
Details finden Sie im Fehlerprotokoll.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.runtime - Beim Schließen der Workbench ist ein Fehler
aufgetreten. Details finden Sie im Fehlerprotokoll.
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.rap.ui.workbench - Beim Schließen der Workbench ist ein
Fehler aufgetreten. Details finden Sie im Fehlerprotokoll.
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.core.commands 4 2 2014-01-15 15:56:37.568
"org.eclipse.core.commands".
!STACK 0
at org.eclipse.swt.widgets.ToolItem.setToolTipText(ToolItem.java:366)
at
org.eclipse.ui.menus.CommandContributionItem.updateToolItem(CommandContributionItem.java:674)
at
org.eclipse.ui.menus.CommandContributionItem.update(CommandContributionItem.java:592)
at
org.eclipse.ui.menus.CommandContributionItem$4.run(CommandContributionItem.java:393)
at
org.eclipse.ui.menus.CommandContributionItem.updateCommandProperties(CommandContributionItem.java:398)
at
org.eclipse.ui.menus.CommandContributionItem.access$7(CommandContributionItem.java:370)
at
org.eclipse.ui.menus.CommandContributionItem$3.commandChanged(CommandContributionItem.java:362)
at org.eclipse.core.commands.Command$1.run(Command.java:540)
at org.eclipse.core.commands.Command.fireCommandChanged(Command.java:535)
at org.eclipse.core.commands.Command.setHandler(Command.java:1024)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:455)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.deactivateHandler(HandlerAuthority.java:310)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHandler(HandlerService.java:146)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHandlers(HandlerService.java:155)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.clearActivations(HandlerPersistence.java:102)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.dispose(HandlerPersistence.java:123)
at
org.eclipse.ui.internal.handlers.HandlerService.dispose(HandlerService.java:161)
at
org.eclipse.ui.internal.services.ServiceLocator.dispose(ServiceLocator.java:141)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3094)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1160)
at
at
at
at
at
at
plug-in: "org.eclipse.core.commands".
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.commands - Problems occurred when invoking code from
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Graphic is disposed [message #1232116 is a reply to message #1231849] Thu, 16 January 2014 04:05 Go to previous messageGo to next message
Hi Markus,
thanks for the snippet. I can reproduce the issue. Actually, I also
found what is the problem. If you look at Window.setDefaultImages
implementation, the images are kept in a static filed. That's why they
are shared between the UI sessions. Please open a bug report about this
issue to track the progress on it. Also attach you test project there.
Ivan
Ivan Furnadjiev
Re: Graphic is disposed [message #1232248 is a reply to message #1232116] Thu, 16 January 2014 09:09 Go to previous message
done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=425861
Am 16.01.2014 10:05, schrieb Ivan Furnadjiev:
> Hi Markus,
> Ivan
Previous Topic:How to make custom widgets themeable?
Next Topic:Images not visible
Current Time: Sat Jul 26 12:04:14 EDT 2025
Powered by FUDForum. Page generated in 0.09872 seconds
