Graphic is disposed [message #1231378] |
Tue, 14 January 2014 09:19  |
in out Application class we create image with
"ImageDescriptor.createFromURL(url).createImage()" and use them as
window images like this "Window.setDefaultImages(images);". The start
method looks like this:
Display display = null;
Image[] images = null;
try {
display = PlatformUI.createDisplay();
images = setWindowDefaultImages();
int returnCode = PlatformUI.createAndRunWorkbench(display, new
ApplicationWorkbenchAdvisor());
if (returnCode == PlatformUI.RETURN_RESTART) {
return IApplication.EXIT_RESTART;
return IApplication.EXIT_OK;
catch (Exception e) {
return getApplicationStatus(e);
finally {
dispose(display, images);
In the dispose method we dispose the created images as the javadoc
states in imageDescriptor.createImage().
Unfortunatelly, this leads to an Exception "Graphic is disposed", if a
second instance (browser tab or window) of our application is opend and
closed. Then the "old" instance in the first tab throws this exception.
Is it correct to dispose images created by
imageDescriptor.createImage()? Any hints?
Markus
Re: Graphic is disposed [message #1231849 is a reply to message #1231784] |
Wed, 15 January 2014 09:54   |
Sure :-)
I can't actually reproduct that the exceptionto occurs like in our
application, but in the attached extended mail demo you can see, that
the images are shared among sessions somehow, although ever session
creates its own images. Maybe this is the cause of our stacktrace.
To reproduce:
1. Start the application
2. Click "Open Message" or "About"
3. You can see, that the window images are used as expected
4. Now, open the app in a seconnd tab, window or a different browser
5. Window images still working
6. Now, close one of the opened apps
7. Click "Open Message" or "About" in the other app
8. You can see, that there are no window imagas used anymore
9. Now, open the app again in a seconnd tab, window or a different browser
10. Window images are now working again in both apps
Markus
Am 15.01.2014 12:49, schrieb Ivan Furnadjiev:
> Hi Markus,
> could you create and attach a complete simple project that demonstrate
> the issue?
> Best,
> Ivan
Re: Graphic is disposed [message #1231852 is a reply to message #1231788] |
Wed, 15 January 2014 10:00   |
No, we do not share image by intention.
Here is the stacktrace (its pretty long):
osgi> !SESSION 2014-01-15 15:55:26.925
eclipse.buildId=unknown
java.version=1.6.0_30
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -dev
file:W:/workspaces/myapp-rap/.metadata/.plugins/org.eclipse.pde.core/myapp
WEB/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -console
-data
W:\workspaces\myapp-rap/.metadata/.plugins/org.eclipse.rap.tools.launch/myappWEB
!ENTRY org.eclipse.rap.ui.workbench 4 2 2014-01-15 15:56:37.568
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.rap.ui.workbench".
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:3582)
at org.eclipse.swt.SWT.error(SWT.java:3505)
at org.eclipse.swt.SWT.error(SWT.java:3476)
at org.eclipse.swt.widgets.Widget.error(Widget.java:1031)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:973)
at org.eclipse.swt.widgets.Widget.removeDisposeListener(Widget.java:492)
at
org.eclipse.swt.widgets.Control.removeMenuDisposeListener(Control.java:2528)
at org.eclipse.swt.widgets.Control.releaseWidget(Control.java:2343)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:861)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:855)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:856)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1124)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1127)
at org.eclipse.jface.window.Window.close(Window.java:347)
at
org.eclipse.jface.window.ApplicationWindow.close(ApplicationWindow.java:307)
at
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1822)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:726)
at
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:702)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:818)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:816)
at org.eclipse.jface.window.WindowManager.close(WindowManager.java:110)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1151)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1148)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1071)
at org.eclipse.ui.internal.Workbench$21.run(Workbench.java:1337)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1335)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1297)
at
org.eclipse.ui.internal.Workbench$ShutdownHandler.handleEvent(Workbench.java:387)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:85)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:651)
at org.eclipse.swt.widgets.Display.sendDisposeEvent(Display.java:741)
at org.eclipse.swt.widgets.Display.release(Display.java:724)
at org.eclipse.swt.graphics.Device.dispose(Device.java:276)
at
de.cenit.myapp.ui.workbench.internal.Application.dispose(Application.java:244)
at
de.cenit.myapp.ui.workbench.internal.Application.start(Application.java:124)
at
org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
at
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:186)
at
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:298)
at java.lang.Thread.run(Thread.java:662)
at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:104)
2014-01-15 15:56:37,568 [UIThread [141e53f]] ERROR
org.eclipse.core.runtime - Problems occurred when invoking code from
plug-in: "org.eclipse.rap.ui.workbench".
at
at
at
at
at
at
at
at
at
at
at
[de.cenit.myapp.core.logging.internal.Log4jLogListener@14fcd9a] ERROR
org.eclipse.rap.ui.workbench - Problems occurred when invoking code
from plug-in: "org.eclipse.rap.ui.workbench".
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jface 4 0 2014-01-15 15:56:37.568
!MESSAGE Beim Schließen der Workbench ist ein Fehler aufgetreten.
Details finden Sie im Fehlerprotokoll.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.runtime - Beim Schließen der Workbench ist ein Fehler
aufgetreten. Details finden Sie im Fehlerprotokoll.
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.rap.ui.workbench - Beim Schließen der Workbench ist ein
Fehler aufgetreten. Details finden Sie im Fehlerprotokoll.
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.core.commands 4 2 2014-01-15 15:56:37.568
"org.eclipse.core.commands".
!STACK 0
at org.eclipse.swt.widgets.ToolItem.setToolTipText(ToolItem.java:366)
at
org.eclipse.ui.menus.CommandContributionItem.updateToolItem(CommandContributionItem.java:674)
at
org.eclipse.ui.menus.CommandContributionItem.update(CommandContributionItem.java:592)
at
org.eclipse.ui.menus.CommandContributionItem$4.run(CommandContributionItem.java:393)
at
org.eclipse.ui.menus.CommandContributionItem.updateCommandProperties(CommandContributionItem.java:398)
at
org.eclipse.ui.menus.CommandContributionItem.access$7(CommandContributionItem.java:370)
at
org.eclipse.ui.menus.CommandContributionItem$3.commandChanged(CommandContributionItem.java:362)
at org.eclipse.core.commands.Command$1.run(Command.java:540)
at org.eclipse.core.commands.Command.fireCommandChanged(Command.java:535)
at org.eclipse.core.commands.Command.setHandler(Command.java:1024)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:455)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.deactivateHandler(HandlerAuthority.java:310)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHandler(HandlerService.java:146)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHandlers(HandlerService.java:155)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.clearActivations(HandlerPersistence.java:102)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.dispose(HandlerPersistence.java:123)
at
org.eclipse.ui.internal.handlers.HandlerService.dispose(HandlerService.java:161)
at
org.eclipse.ui.internal.services.ServiceLocator.dispose(ServiceLocator.java:141)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3094)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1160)
at
at
at
at
at
at
plug-in: "org.eclipse.core.commands".
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.commands - Problems occurred when invoking code from
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Graphic is disposed [message #1232248 is a reply to message #1232116] |
Thu, 16 January 2014 09:09  |
done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=425861
Am 16.01.2014 10:05, schrieb Ivan Furnadjiev:
> Hi Markus,
> thanks for the snippet. I can reproduce the issue. Actually, I also
> found what is the problem. If you look at Window.setDefaultImages
> implementation, the images are kept in a static filed. That's why they
> are shared between the UI sessions. Please open a bug report about this
> issue to track the progress on it. Also attach you test project there.
> Ivan
FUDForum. Page generated in 0.06804 seconds
