Home » Eclipse Projects » Remote Application Platform (RAP) » RAP - qooxdoo: Set selection value of combo box via javascript(Fire 'selection changed' event via JavaScript)
RAP - qooxdoo: Set selection value of combo box via javascript [message #662888] Fri, 01 April 2011 07:44 Go to next message
Hi all,
I try to test the RAP user interface using selenium and the qooxdoo user-extensions. In most situations the standard selenium commands in conjunction with qooxdoo extensions works very well. But i have a strange problem in accessing and editing the selection of a combo box.
Because selenium sets the combo box value quite unreliable, i wrote some javascript based extension functions to do that.
With the code shown below i can successful change the selection of the combo box. But the new value will not be synchronized with the server. When i safe the changes and reload them, the old value is still displayed. It seems that no change
event is fired, which causes the server to safe the new value.
In the qooxdoo 0.73 implementation used in RAP, a very poor event mechanism is implemented. A function like 'fireEvent' (which is defined in the current version) is not available.
Has anybody an idea, how i can fix it?
Thx for your replies.
Selenium.prototype.doSetComboBoxValue = function(locator, value){
	var uwindow = this.browserbot.getUserWindow();
	var wmanager = uwindow.org.eclipse.swt.WidgetManager.getInstance();
	var cmbBox = wmanager.findWidgetById(locator);
	cmbBox.setValue(value);
[Updated on: Fri, 01 April 2011 07:46] by Moderator
Re: RAP - qooxdoo: Set selection value of combo box via javascript [message #663190 is a reply to message #662888] Mon, 04 April 2011 05:12 Go to previous messageGo to next message
Hi Christian.
It's called dispatchEvent, or createDispatchEvent, depending on what you
need. You'll find those in qx.core.Target.
This will only set the content of the combos textfield, not the selected
item. Try cmbBox.select( int ).
Greetings,
Tim
Re: RAP - qooxdoo: Set selection value of combo box via javascript [message #663270 is a reply to message #663190] Mon, 04 April 2011 09:43 Go to previous messageGo to next message
Hi Tim,
thanks for your advice.
With the 'select' command i got the combo box running.
Now i have a similar issue to solve for check boxes and radio buttons.
I tried the 'dispatchEvent' command for a check box with the following code snippet:
evt = new qx.event.type.ChangeEvent("selectionChanged", value, oldValue);
checkBox.dispatchEvent(evt, true);
The call of 'dispatchEvent' causes the following exception:
[[error] Unexpected Exception: message -> $0 is undefined, fileName -> http://127.0.0.1:10080/default?custom_service_handler=org.ec lipse.rwt.internal.service.JSLibraryServiceHandler&hash= H1511568866, lineNumber -> 24, stack -> ((void 0),true) @http://127.0.0.1:10080/default?custom_service_handler=org.e clipse.rwt.internal.service.JSLibraryServiceHandler&hash =H1511568866:24 SJOWContentBoundary()@:0 , name -> TypeError
It seems that a predefined event type String or a constant has to be passed as first parameter.
But i can't find any documentation where this event type parameter is explained in detail. In the qooxdoo 0.74 API reference only a
'type name of the event' is mentioned. Do you know a location where i can find a useful documentation or API reference?
Greetings,
Christian
Re: RAP - qooxdoo: Set selection value of combo box via javascript [message #663291 is a reply to message #663270] Mon, 04 April 2011 10:39 Go to previous messageGo to next message
Hi.
Well, first of all, for buttons "execute()" should simulate a mouse
click i think. There often exist no real, client-side "selection" (or
other swt-like) events, client-widgets mostly process dom-events. The
"selection" event for button gets created on the server only. Faking
dom-events is also possible, but not trivial.
As for API documentation: There is an API-Viewer for qooxdoo. But you
either have to use the existing one for qooxdoo 0.7.4, which won't
reflect our additions and changes to the API, or generate a new one for
the RAP-version of qooxdoo. I recommand just reading the source-code.
All events that exist for a class are either noted in the "events" map,
or, in case of change events, in the property definition.
Greetings,
Tim
Re: RAP - qooxdoo: Set selection value of combo box via javascript [message #664058 is a reply to message #663291] Thu, 07 April 2011 06:54 Go to previous messageGo to next message
Hi Tim,
our test infrastructure prototype is now working fine for basic widgets like
text field, text area, check box, radio button, combo box, list (multiselect)
and spinner (setting, increment and decrement value). Table selection could
be handled through the 'qx' click command, which is delivered with the
selenium 'user.extension' file of qooxdoo. It is also possible to read the value
of most widget types using custom 'user.extension' java script functions. For
the localization of the UI elements we use a mixture of custom id's, xPath
expressions and additional localization information like the position of an
item in a list or table. The test infrastructure provides test developers with a
Java API, that prevents them from dealing with xPath. Test cases could be
written (and executed with Selenium-RC) the same way like JUnit tests are
developed. To include test data dynamically, we wrote a simple function, that
can be used to import data from excel sheets.
We now care about basic widgets like check boxes or text fields that are
included in editable table cells. The key issue is whether widgets that are
embedded in a table cell editor could be accessed the same way like
widgets that are located outside a editable table cell. If this is possible and a
localization (e.g. by custom id or table row and column number) could be
implemented, we can reuse the existing user extensions. Otherwise we
have to find another solution.
Best Greetings,
Christian
[Updated on: Thu, 07 April 2011 06:55] by Moderator
Re: RAP - qooxdoo: Set selection value of combo box via javascript [message #717114 is a reply to message #664058] Fri, 19 August 2011 06:58 Go to previous messageGo to next message
Hi Christian,
I am working on a GUI test "framework" which will be able to test both RCP and RAP GUIs (and later can be extended). I found RAP to be a bit tricky though... Managing basic widgets seems to be ok but I couldn't find a solution to edit table cells.
As I see you've created a test infrastructure which handles RAP GUI. Is it possible to find this framework somewhere to get ideas from it? If not than can you tell me which way should I go to find a solution for that problem?
Balazs
icon7.gif  Re: RAP - qooxdoo: Set selection value of combo box via javascript [message #1231310 is a reply to message #717114] Tue, 14 January 2014 05:19 Go to previous message
I have now similar issue to solve.
@Christian: Could you please tell if you have already a solution for your problem?
@Balázs: Is it possible to see your RAP GUI testing framework?
Thanks for hints!
George
Previous Topic:Javascript-Error with 1.4.0M6
Next Topic:%Text not translated after language change
Current Time: Wed Jul 23 04:07:04 EDT 2025
Powered by FUDForum. Page generated in 0.05708 seconds
