Access a referenced JvmGenericType in the JvmModelInferrer [message #1231289] |
Tue, 14 January 2014 04:22  |
Hello everyone,
Here is my test grammar:
grammar some.grammar.example with org.eclipse.xtext.xbase.Xbase
generate example "http:/www.some.com/grammar/example/"
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as jvmTypes
ModelRoot:
(elements += ElementDecl)*
ElementDecl:
'element' name = ValidID '{'
referenced += ReferencedDecl*
ReferencedDecl:
'referenced' type = [jvmTypes::JvmGenericType | QualifiedName]
With an example:
element X {
referenced my.package.ClassX
I would like to "browse" the declared operations, fields etc. of the referenced JvmGenericType in my implementation of JvmModelInferrer (I need to generate specific classes depending on the content of the referenced type).
I have no problem doing that in a "initializeLater" section, but all the fields of the referenced type are empty or null when I try to browse them outside an "initializeLater", and printing the type itself gives me:
"elem.type=JvmGenericType: (eProxyURI: platform:/resource/some.grammar.example/src/some.grammar.example/test.example#xtextLink_::0.1.0.3.1::0::/2)
The problem is I can't do my browsing inside an "initializeLater" because I need to pass new classes to the acceptor depending on it, and I can't do that in this phase.
Do you have any idea of how I could browse the JvmGenericType in an infer(...) method? That is, resolving the proxy, changing something in my grammar or something like that?
Thank you,
Re: Access a referenced JvmGenericType in the JvmModelInferrer [message #1231671 is a reply to message #1231289] |
Wed, 15 January 2014 02:19  |
You cannot resolve any crossreferences when 'preIndexingPhase=true'.
This is because you run into a chicken and egg problem when you try to
look up types in order to contribute new types because you will change
the scope (the types available) and that would cause non-deterministic
behavior.
I thinl you'll have to reconsider your design.
Sven
Am 14/01/14 10:22, schrieb Cioran Naroic:
> Hello everyone,
> ModelRoot:
> ElementDecl:
> ReferencedDecl:
> With an example:
> element X {
> referenced type).
> Thank you,
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
FUDForum. Page generated in 0.03985 seconds
