Home » Eclipse Projects » Equinox » equinox on glassfish?
| equinox on glassfish? [message #122487] |
Fri, 12 December 2008 05:56  |
Folks,
reading through the tutorial how to set equinox to run in an http servlet
container[1], I tried the same thing on a glassfishv3 application server:
- Deploying and starting bridge.war seems fine, even though the OSGi console
obviously seems to work, testing http://.../bridge/sp_test does provide the
expected output.
- However trying to deploy a "demo.war" to build upon this application fails
reproducibly throwing this exception:
[#|2008-12-12T11:35:12.898+0100|SEVERE|sun-appserver9.1|java x.enterprise.system.container.web|_ThreadID=72;_ThreadName=T hread-
225837;_RequestID=b4afba8e-1976-4556-aa7d-2dff785c4cef;|WebM odule[/demo]StandardWrapper.Throwable
java.lang.RuntimeException: Could not find framework
at
org.eclipse.equinox.servletbridge.FrameworkLauncher.buildIni tialPropertyMap(FrameworkLauncher.java:401)
at
org.eclipse.equinox.servletbridge.FrameworkLauncher.start(Fr ameworkLauncher.java:271)
at
org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeS ervlet.java:65)
at javax.servlet.GenericServlet.init(GenericServlet.java:254)
So... should I assume running equinox on glassfish(v2,v3) is not supported
by now, or is there something I am missing thus far?
TIA and all the best,
Kristian
[1]http://www.eclipse.org/equinox/server/http_in_container.php
| Re: equinox on glassfish? [message #123257 is a reply to message #123012] |
Fri, 19 December 2008 04:12   |
Simon Kaegi schrieb:
> That's a gentle understatement.
> I truly wish we had a better story here as teams using this stuff have
> fairly inconsistent build stories and component selections (e.g. take a look
> at what say RAP is doing vs. BIRT. Use in commercial products that I've seen
> is similarly inconsistent).
Hmmm, indeed, this is not that pleasant. :( At the moment I am investigating
how to throw in maven2 here as most of our backend applications so far get
built this way and I don't want to deal with the equinox/osgi bundles in a
different way, but I do have a strange sentiment that this ain't gonna make
things easier...
> dynamic benefits inherent in an OSGi based system. In my opiniong the
> largest obstacle remains on the provisioning side where we really need
> something iron-clad, consistent and ultra reliable. I believe we're now
> making progress with p2 in this space towards a common core that ought to be
> usable in a wide-range of applications including server-side.
Indeed, this sounds desirable. In some ways, so far I felt a little
disappointed about all this osgi-on-server stuff, just to so far figure out
that most of the applications indeed are, again, .war files containing all
the .jars as they did before, just seeing they throw in osgi eventually. So
I'm gonna have a look at p2 here, is it server-ready to some degree yet?
Cheers & thanks again,
Kristian
| Re: equinox on glassfish? [message #123516 is a reply to message #122487] |
Tue, 30 December 2008 11:45   |
Sorry to come late to this thread, but one question that leapt to mind
when I saw this (and it wasn't answered in the subsequent messages) was
this: why are you trying to embed an OSGi runtime inside Glassfish V3,
which already IS an OSGi runtime?
GF uses Apache Felix by default as its OSGi implementation but it is
possible to get it to use Equinox instead if that is your requirement.
Neil
Kristian Rink wrote:
> Folks,
> expected output.
> at
> at
> at
> Kristian
| Re: equinox on glassfish? [message #123690 is a reply to message #123516] |
Sun, 04 January 2009 15:42   |
Neil do you know if Glassfish V3 is any different and now making any attempt
to expose the OSGi implementation at the application level?
The OSGi / app server integrations I looked at a while back were all
improving there internal implementations by using OSGi but providing none of
that goodness to the user space. I know there is work going on at the OSGi
currently that will eventually allow better leveraging of the app servers
OSGi internals but I wasn't aware of that being available in a production
product. Even when these products do become available I think there will
still be value in embedding a separate isolated and independent framework as
this allows full control of the applications environment.
-Simon
"Neil Bartlett" <njbartlett@gmail.com> wrote in message
news:gjdj6p$iba$1@build.eclipse.org...
> Regards,
> Neil
>> Folks,
>> console
>> the
>> expected output.
>> fails
>> at
>> at
>> at
>> supported
>> Kristian
| Re: equinox on glassfish? [message #123703 is a reply to message #123690] |
Mon, 05 January 2009 14:01  |
Simon,
You're right, even GFv3 doesn't offer any exposure to OSGi for
application developers yet. I believe it's on the plan but they're
taking gradual steps towards that goal.
For instance, a quick call of the "services" command reveals no services
whatsoever, except for the low-level framework ones (i.e. PackageAdmin
and the Felix shell service). The only benefit from OSGi at the moment
in GFv3 is you can leave out modules that you might not need.
There is one app server product right now that offers a fully OSGi
programming model to application developers, and that is SpringSource's
dm Server. However its installed base is still miniscule.
Neil
> -Simon
>> Regards,
>> Neil
>>> Folks,
>>> console
>>> the
>>> expected output.
>>> fails
>>> at
>>> at
>>> at
>>> supported
>>> Kristian
Current Time: Fri Nov 07 16:31:39 EST 2025
Powered by FUDForum. Page generated in 0.03811 seconds
