Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Hiberante and Hbxml resource
[Teneo] Hiberante and Hbxml resource [message #122894] Thu, 22 May 2008 15:21 Go to next message
Hello!
My application uses a GMF based editor with Teneo to store the model
instances to the database. Currently i am using two resources, the HBXML
resource for the editor and the hibernate resource for my other model
entities.
Attributes of the GMF related model entities have non-containment
references to model entities in the hibernate resource. When opening my
diagram editor I load the hibernate resource, but when I create a new
model instance and save it, then I also have to reopen my GMF diagram
editor to be able to reference it.
So my question is: Would it be a disadvantage if I use the HBXML resource
for all of my model entities?!? Would it work?! Would there be any
limitiations?!
If yes, then how can I manage my problem?!?
Matthias
Re: [Teneo] Hiberante and Hbxml resource [message #122898 is a reply to message #122894] Thu, 22 May 2008 18:05 Go to previous messageGo to next message
Hi Matthias,
The HibernateXMLResource inherits from the HibernateResource and only adds minimal xml specifics. So
afaics you can use the HibernateXMLResource for all your data.
gr. Martin
Matthias wrote:
> Hello!
> entities.
> resource for all of my model entities?!? Would it work?! Would there be
> any limitiations?!
> Best regards,
> Matthias
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Hiberante and Hbxml resource [message #122965 is a reply to message #122898] Mon, 26 May 2008 03:34 Go to previous messageGo to next message
Hello Martin,
thank you for your answer.
I have some additional questions (honestly I do not know Hibernate very
well so these questions might also be related to Hibernate in general).
1. My persisted model instances have ids like 987845 and 345152 so on. Why
does not counting start at 1 even on an empty database?!?
2. I have a plugin that registers a "persistence" service, that provides
storage to databases with Teneo. The service provides the interface method
"getResource" that returns in fact the HibernateXMLResource. This
resources gets loaded on startup of the plug-in and unloaded at the end of
the plug-in lifecycle. Is this good practice (because in the GMF tutorial
you load and un-load a new resource when you need it.). Saving the
resource also does a commit, right?!
3. In terms of performance and best practice: I want to search a model
object with a specific name in my database. What do you think, iterating
the resource and making instanceofs and equals calls or creating a HSQL on
the session object?!?
4. I have a GMF based model instance editor and I am using Teneo for
diagram and model persistence. My meta-model defines for instance that the
model object "Company" must have a (ONE) name. When I create a Company in
the diagram editor and do not set a name, I get an error message. Is there
any mechanism to provide a self defined error message (because the default
one might be to technical and implementation specific for the end user).
Thank you for any response...
Matthias
Re: [Teneo] Hiberante and Hbxml resource [message #122967 is a reply to message #122965] Mon, 26 May 2008 08:31 Go to previous message
Hi Matthias,
See comments inline.
gr. Martin
Matthias wrote:
> Hello Martin,
> Why does not counting start at 1 even on an empty database?!?
MT>> It should start with 1, you can check the database configuration, you can also try to remove
the database and start from fresh again. Are you sure that your id's are autosequence id's?
> method "getResource" that returns in fact the HibernateXMLResource. This
> of the plug-in lifecycle. Is this good practice (because in the GMF
> tutorial you load and un-load a new resource when you need it.). Saving
> the resource also does a commit, right?!
MT>> Yes save does a commit, the resource only opens a transaction during the load/save. So in
between it does not put load on the database. So this is good practice.
> on the session object?!?
MT>> It all depends on your database size. I prefer querying because it always works (also with
larger databases).
> the model object "Company" must have a (ONE) name. When I create a
> Company in the diagram editor and do not set a name, I get an error
> message. Is there any mechanism to provide a self defined error message
> (because the default one might be to technical and implementation
MT>> I would have expected that EMF validation would have caught this one upfront. Can you check if
validation is done before/during save? (see the StoreResource.validateContents method).
> Best regards,
> Matthias
The Netherlands
Re: [Teneo] Hiberante and Hbxml resource [message #618149 is a reply to message #122894] Thu, 22 May 2008 18:05 Go to previous message
Hi Matthias,
gr. Martin
Matthias wrote:
> Hello!
> entities.
> any limitiations?!
> Best regards,
> Matthias
The Netherlands
Re: [Teneo] Hiberante and Hbxml resource [message #618966 is a reply to message #122898] Mon, 26 May 2008 03:34 Go to previous message
Hello Martin,
Matthias
Re: [Teneo] Hiberante and Hbxml resource [message #618968 is a reply to message #122965] Mon, 26 May 2008 08:31 Go to previous message
Hi Matthias,
gr. Martin
Matthias wrote:
> Hello Martin,
larger databases).
> Best regards,
> Matthias
The Netherlands
Previous Topic:How to create a copy of an EObject with non-null Resource
Next Topic:[EMF Compare] Does EMF Compare really need to know about IFile and so on?
Current Time: Thu Nov 06 09:48:43 EST 2025
Powered by FUDForum. Page generated in 0.06844 seconds
