Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [CDO 0.8.0] Performance
[CDO 0.8.0] Performance [message #122918] |
Fri, 23 May 2008 07:18  |
Hi Eike,
In EMF, everythings is somehow attached from a resource.
However, in our production system, our IStore never update objects
Resources.
Now, that I need to follow the standard, I developped my IStore to update
every objects correctly. However, when we create thousands of objects and
add it to the resource.contents... it starting to get very slow. Also it
needs to go through the list to find out if we already have the items..
etc..etc..
Here my questions:
Can we persist objects without adding it to the resource ?
Could we persist object in a way where objectA.resourceID == resourceA but
resourceA.content will not contains objectA ?
This is in Fact how the result of never updating a Resource.(My previous
IStore)
We could have something like.
CDOTransaction.persist(CDOResource, object);
Do you think it will go against something ?
Thank you.
Re: [CDO 0.8.0] Performance [message #122923 is a reply to message #122918] |
Fri, 23 May 2008 07:57   |
Simon,
Comments below.
Simon McDuff wrote:
> Hi Eike,
> Resources.
> etc..etc..
Maybe you want to create a root contain so the resource has one child
and that child has all the other contents. Then you can manage the list
of all objects in the store itself.
> Here my questions:
In general, an object for which eResource() == null can't be persisted.
> IStore)
Very likely. It's best to meet all the expectations of the framework...
> Thank you.
Re: [CDO 0.8.0] Performance [message #122935 is a reply to message #122923] |
Fri, 23 May 2008 08:19   |
Originally posted by: stepper.sympedia.de
Ed, Simon,
I agree with Ed.
I always recommended to handle the attachment of href'ed objects
explicitely so that it is clear where they're contained.
I believe most strategies to automatically attach referenced but
uncontained objects is not scalable in the best case.
And I only agreed to develop something like a CDOAutoAttacher because it
is completely optional.
Cheers
/Eike
Ed Merks schrieb:
> Simon,
> Comments below.
> Simon McDuff wrote:
>> Hi Eike,
>> Resources.
>> update every objects correctly. However, when we create thousands of
>> objects and add it to the resource.contents... it starting to get
>> very slow. Also it needs to go through the list to find out if we
>> already have the items.. etc..etc..
> list of all objects in the store itself.
>> Here my questions:
>> resourceA but resourceA.content will not contains objectA ?
>> previous IStore)
>> Thank you.
Re: [CDO 0.8.0] Performance [message #122938 is a reply to message #122923] |
Fri, 23 May 2008 08:43  |
Understand!
So I will create an objects that have a list.
In fact, when you add to this objects you not necessarly add to a list
because it will not keep anything.
My objects will in fact call (IN CDO)
CDOStateMachine.INSTANCE.attach(eObjectToPersist, cdoResource,
(CDOViewImpl)cdoTransaction);
To make it persistent!!
I believe the implementation is cleaner using
but I will attach it indirectly.
I think by default it follow the standard.
But by having my special objects doing it .... is the same things that
having CDO framework having it. At the end, you will have an objects with a
collection that you can add to it but not retrieved from it.
"Ed Merks" <merks@ca.ibm.com> a
Re: [CDO 0.8.0] Performance [message #618162 is a reply to message #122918] |
Simon,
Comments below.
Simon McDuff wrote:
> Hi Eike,
> Resources.
> etc..etc..
> Here my questions:
> IStore)
> Thank you.
Re: [CDO 0.8.0] Performance [message #618165 is a reply to message #122923] |
Ed, Simon,
I agree with Ed.
Cheers
/Eike
Ed Merks schrieb:
> Simon,
> Comments below.
> Simon McDuff wrote:
>> Hi Eike,
>> Resources.
>> Here my questions:
>> previous IStore)
>> Thank you.
Re: [CDO 0.8.0] Performance [message #618936 is a reply to message #122923] |
Understand!
Current Time: Tue Sep 16 21:11:00 EDT 2025
Powered by FUDForum. Page generated in 0.05211 seconds
