Home » Archived » Hudson » Multiconfiguration job and setting build description
Multiconfiguration job and setting build description [message #1220659] Thu, 12 December 2013 17:32 Go to next message
I'm using multi-configuration jobs and I have the Hudson description setter plugin installed.
The multi-configuration jobs kicks off other jobs and I can set the description of these jobs based on console output.
How can the multi-configuration job's description be set automatically as the multi-configuration job just kicks off other jobs and doesn't run the description setter step?
Re: Multiconfiguration job and setting build description [message #1221107 is a reply to message #1220659] Mon, 16 December 2013 17:50 Go to previous messageGo to next message
Not clear about "multi-configuration job just kicks off other jobs", do you mean downstream jobs or uses slave axes?.
Re: Multiconfiguration job and setting build description [message #1229089 is a reply to message #1221107] Wed, 08 January 2014 12:43 Go to previous message
My bad.
Slave and user-defined axis.
Previous Topic:Live Event on the Basics of Practicing Continuous Integration with Hudson
Next Topic:Enterprise issues with the Team Concept
Current Time: Thu Jul 24 22:50:39 EDT 2025
Powered by FUDForum. Page generated in 0.06486 seconds
