Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Delete Model and unset all CrossReferences
[Teneo] Delete Model and unset all CrossReferences [message #1228945] Wed, 08 January 2014 06:48 Go to next message
Hi! I am still new to Teneo Smile and couldn't find anything usefull on the net. But people must have this problem too.
I want to unset (nullify) crossreferences of a model on delete.
With a xmi-resources this is easy
	private void unsetCrossReferences(EObject model) {
		Collection<Setting> find = EcoreUtil.UsageCrossReferencer.find(model, getEditingDomain().getResourceSet());
		for(Setting setting : find) { setting.unset(); }
I found in the web that with teneo one should use the HbDataStore:
Object[]
HbDataStore hbDataStore
Object[] objects = hbDataStore.getCrossReferencers(getHibernateSession(), eObject);
This also works fine and i get all the referenced EObjects, but now i am stuck.
How do i unset/nullify the correct references in these eObjects?
Is there a way to get the "EStructuralFeature.Setting" from this EObjects to unset them?
Sure i could also manualy remove the references in the concrete objects but i am looking for a more generic way like the xmi - approach.
Is this possible and a correct approach? Does anybody now of some samples? This should be a common problem i think.
Thanks in advanced
and best regards weinma
Re: [Teneo] Delete Model and unset all CrossReferences [message #1228960 is a reply to message #1228945] Wed, 08 January 2014 07:22 Go to previous messageGo to next message
Jürgen,
The setting.unset call does the same thing as
eObject.eUnset(eStructuralFeature). And yes, you can get a Setting
object by casting to InternalEObject and using the eSetting method.
On 08/01/2014 12:48 PM, Jürgen Weinberger wrote:
> Hi! I am still new to Teneo :) and couldn't find anything usefull on
> Object[] HbDataStore hbDataStore
> Object[] objects =
> am stuck.
> How do i unset/nullify the correct references in these eObjects? Is
> to unset them?
> Thanks in advanced
Re: [Teneo] Delete Model and unset all CrossReferences [message #1229023 is a reply to message #1228945] Wed, 08 January 2014 10:05 Go to previous messageGo to next message
Hi!
Thanks for the answer! I think eObject.unset() would do the trick.
Can you just point me in the right direction? I would need to know which StructuralFeature contains the referenced EObject to unset it.
Is this even possible ?
Thanks again!
best regards
Re: [Teneo] Delete Model and unset all CrossReferences [message #1229033 is a reply to message #1229023] Wed, 08 January 2014 10:22 Go to previous message
Jürgen,
What are you trying to do? Eliminate all references to some object?
Perhaps org.eclipse.emf.ecore.util.EcoreUtil.delete(EObject, boolean)
does what you need or at least will give you the idea of how to
implement what you need.
On 08/01/2014 4:05 PM, Jürgen Weinberger wrote:
> Hi!
> Thanks again!
> best regards
Previous Topic:[Teneo] Delete Model and unset all CrossReferences
Next Topic:[Teneo] Delete Database for Unit Tests
Current Time: Fri Jul 18 18:52:38 EDT 2025
Powered by FUDForum. Page generated in 0.04080 seconds
