Home » Modeling » TMF (Xtext) » Mapping from DSL specific ecore to a model ecore
Mapping from DSL specific ecore to a model ecore [message #1228873] Wed, 08 January 2014 03:49 Go to next message
Happy new year to all!!
I have an existing model ecore and want to create a DSL for it. But the structure of that model doesn't fit to the DSL I like to create. So my intention is to create a DSL and than map/create the data model instance from the DSL's model instance.
Can you point me to the direction where I can do this mapping?
The Generator seems a place, but I would prefer to get the resource of my mapped data model as parameter in the 'doGenerate' method. So another location seems t obe better.
Thank you,
Mark
Re: Mapping from DSL specific ecore to a model ecore [message #1228922 is a reply to message #1228873] Wed, 08 January 2014 05:53 Go to previous messageGo to next message
i am not quite sure what you are doing.
there is no default hook for m2m and then generating
so far.
Re: Mapping from DSL specific ecore to a model ecore [message #1228928 is a reply to message #1228922] Wed, 08 January 2014 06:08 Go to previous messageGo to next message
p.s. maybe the org.eclipse.xtext.resource.IDerivedStateComputer is a hook that does what you want,
but thus highly depends on your usecase
Re: Mapping from DSL specific ecore to a model ecore [message #1228967 is a reply to message #1228928] Wed, 08 January 2014 07:49 Go to previous messageGo to next message
I don't wanna do the transformation when executing MWE to generate the stuff!
The transformation should be done, when I use the generated editor typing code in my DSL and save the file.
So the ordinary use case is:
- create a DSL and generate the editor from it
- launch the generated bundles
- use the editor to write code in my DSL's grammar.
- save the file and you get the DSL's EMF Resource with the model in it
- generate any code using the generated xtend generator class
What I want is:
- transform this data model into a model instance of the customers ecore
- generate any code using the generated xtend generator class from the model of the customers ecore
I already tried to import the big ecore and created a DSL from it, but the result was not very good. Even if I deleted unnecessary stuff and changed the grammar I didn't achieved a good result.
But I can create an instance of the complex model from the DSL's model which was created from scratch. For this I have to create corresponding objects in the big model, set a lot of default values, non containing cross references and so on. It doesn't matter for me, if I do this in code or using m2m.
I just wanted to know, if there is a good place to start this transformation, when saving the code in my DSL editor. Thats why I came to the idea, do this in the xtend generator class. But my feeling says this is not a good place to do such a transformation.
I cannot change the big model, because its the one from the customer.
Mark
[Updated on: Wed, 08 January 2014 08:13] by Moderator
Re: Mapping from DSL specific ecore to a model ecore [message #1228969 is a reply to message #1228967] Wed, 08 January 2014 07:51 Go to previous messageGo to next message
are you sure it is impossible to create a grammar for the big model manually?
Re: Mapping from DSL specific ecore to a model ecore [message #1228982 is a reply to message #1228969] Wed, 08 January 2014 08:32 Go to previous messageGo to next message
no, I am not sure if it is impossible, but creating the DSL from srcatch was not as expensive as modifying the imported one, that resulted in language that I and the customer dont really wanted.
In any case I would need a hook, where I can set non containing references, default values and so on after the syntax is valid. Something like postProcess or preCodeGenerate ...
Mark
[Updated on: Wed, 08 January 2014 08:33] by Moderator
Re: Mapping from DSL specific ecore to a model ecore [message #1228986 is a reply to message #1228982] Wed, 08 January 2014 08:38 Go to previous messageGo to next message
hi,
why no simply on generate?
if not give IDerivedStateComputer a try,
afaik it is called during multiple phases so maybe even the cross ref thing will work fine.
Re: Mapping from DSL specific ecore to a model ecore [message #1229009 is a reply to message #1228986] Wed, 08 January 2014 09:40 Go to previous message
Hi Christian,
thank you I will use doGenerate and found this as a good starting point:
http://xtextcasts.org/episodes/18-model-optimization
Thank you
Mark
Previous Topic:Adding a library to runtime project
Next Topic:Maven build using Nexus with P2 repositories
Current Time: Wed Jul 23 20:34:12 EDT 2025
Powered by FUDForum. Page generated in 0.08187 seconds
