Home » Language IDEs » Java Development Tools (JDT) » Desired Editing Feature
Desired Editing Feature [message #120614] Mon, 24 November 2003 22:09 Go to next message
Originally posted by: dcorbin.machturtle.com
Is there an editing feature that will slap braces around the selection, and
indent the block contents if appropriate?
David
Re: Desired Editing Feature [message #120712 is a reply to message #120614] Tue, 25 November 2003 03:56 Go to previous messageGo to next message
Select the lines you want and invoke quick assist (Ctrl+1 - turn on
"Java->Work in Progress->Enable lightbulb for quick assists" to get a
visual cue for its availability), then select one of the offered
templates (surround with if etc.).
-tom
Re: Desired Editing Feature [message #121657 is a reply to message #120712] Tue, 25 November 2003 08:34 Go to previous messageGo to next message
Tom Eicher wrote:
>> and indent the block contents if appropriate?
> -tom
Not quite what I wanted.
I have a statement that reads:
if (a)
b();
I want a keystroke that turns that into:
if (a)
b();
And, I don't want to have to select the line to do it. It should just
operate on the current line.
David
Re: Desired Editing Feature [message #121683 is a reply to message #121657] Tue, 25 November 2003 09:32 Go to previous messageGo to next message
Originally posted by: eclipse-news.forritan.net
It's actually already there.
Example:
You have this:
b();
and then you want make this call conditional, you write "if(a){" in
front of "b();" - i.e. the curser is now in front of "b" :
if(a){b();
press enter and you got:
if(a){
b();
-eyðun
>>-tom
> if (a)
> b();
> if (a)
> b();
> David
Re: Desired Editing Feature [message #121745 is a reply to message #121683] Tue, 25 November 2003 11:55 Go to previous messageGo to next message
> Example:
> You have this:
> b();
No, I don't. I already HAVE the if statement. I simply wish to turn a
single statement into a blockstatement.
Re: Desired Editing Feature [message #122166 is a reply to message #121745] Wed, 26 November 2003 03:01 Go to previous messageGo to next message
David Corbin wrote:
> Ey
Re: Desired Editing Feature [message #122748 is a reply to message #121745] Thu, 27 November 2003 13:03 Go to previous messageGo to next message
>>Example:
>>You have this:
>>b();
Oh, sorry - I think I misunderstood you...
Well, I took the challange... ;-) It's actually quite easy to implement.
(I have never worked with the internals of jdt before - and I came up
with this after a couple of hours today)
1. In org.eclipse.jdt.internal.ui.text.correction.QuickAssistProce ssor
make a new method:
<code>
private boolean getAddThenProposals(
IInvocationContext context,
ASTNode node,
Collection resultingCollections)
throws CoreException {
Statement statement= ASTResolving.findParentStatement(node);
if (!(statement instanceof IfStatement)) {
return false;
IfStatement ifStatement= (IfStatement) statement;
if (ifStatement.getThenStatement() instanceof Block) {
return false;
if (resultingCollections == null) {
return true;
AST ast= statement.getAST();
ASTRewrite rewrite= new ASTRewrite(statement);
ASTNode thenStatement=
ASTNode.copySubtree(ast, ifStatement.getThenStatement());
Block replacingBody= ast.newBlock();
replacingBody.statements().add(thenStatement);
rewrite.markAsInsert(
ifStatement,
ASTNodeConstants.THEN_STATEMENT,
replacingBody,
null);
String label=
CorrectionMessages.getString("QuickAssistProcessor.addthenblock.description ");
//$NON-NLS-1$
Image image= JavaPluginImages.get(JavaPluginImages.IMG_CORRECTION_ADD);
ASTRewriteCorrectionProposal proposal=
new ASTRewriteCorrectionProposal(
label,
context.getCompilationUnit(),
rewrite,
1,
image);
proposal.ensureNoModifications();
resultingCollections.add(proposal);
return true;
</code>
and make appropriate calls to this new method in
hasAssists(IInvocationContext)
and in
getAssists(IInvocationContext context, IProblemLocation[] locations)
also in org.eclipse.jdt.internal.ui.text.correction.QuickAssistProce ssor
2. add one line in
org.eclipse.jdt.internal.ui.text.correction.CorrectionMessag es.properties:
<code>
QuickAssistProcessor.addthenblock.description=Add then block
</code>
And thats it... Compile and be happy... ;-)
-eyðun
Re: Desired Editing Feature [message #122753 is a reply to message #122748] Thu, 27 November 2003 13:15 Go to previous messageGo to next message
... and attach your patch to a PR and make everyone else happy...
;-) tom
Re: Desired Editing Feature [message #122770 is a reply to message #122753] Thu, 27 November 2003 14:22 Go to previous messageGo to next message
Done.
Bugzilla Bug 47657:
Quick Assist Suggestion: add block to single-line then-statement
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47657
-eyðun
> ;-) tom
Re: Desired Editing Feature [message #122816 is a reply to message #122770] Fri, 28 November 2003 06:47 Go to previous messageGo to next message
And FIXED as from 3.0 M6 ;-)
> Done.
> Bugzilla Bug 47657:
> -eyðun
>> ;-) tom
Re: Desired Editing Feature [message #122840 is a reply to message #122816] Fri, 28 November 2003 08:04 Go to previous messageGo to next message
Thanks. But it looks like you took my request VERY litterally, and it's
limited to if statements. I think the same should be doable for while and
for statements.
I'm pretty sure that covers all the cases where blocks are optional, short
of just adding blocks for scoping sakes.
Davdi
>> Done.
>> Bugzilla Bug 47657:
>> -eyðun
>>> ;-) tom
Re: Desired Editing Feature [message #122852 is a reply to message #122840] Fri, 28 November 2003 08:35 Go to previous message
> for statements.
Well, that only shows how carefull you should be when you make a wish!!! ;-)
Well you are in luck, because so did Martin Aeschlimann (who committed
the code into the stream) :-)
Bugzilla Bug 47657:
------- Additional Comment #2 From Martin Aeschlimann 2003-11-28 05:07
nice! I added the code and made some changes to complete it:
- added support for else block; while, do and for statements
- use 'createMove()' instead of ASTNode.copySubtree (otherwise you loose
all
formatting and comments of the body statement.
you can submit changes as a patch (in the TEAM menu), that's the most
easiest
way for me to take fixes.
Thanks a lot!
> Davdi
>>>Done.
>>>Bugzilla Bug 47657:
>>>-eyðun
>>>>;-) tom
Previous Topic:CVS Outgoing Information
Next Topic:How to force Eclipse-CVS to use LF for line-endings?
Current Time: Wed Nov 05 18:27:24 EST 2025
Powered by FUDForum. Page generated in 0.04480 seconds
