Home » Eclipse Projects » Eclipse 4 » Close application
Close application [message #1228104] Mon, 06 January 2014 07:21 Go to next message
I am doing an Eclipse application, and I have an issue closing my application properly.
Here is the handler I use to close my application :
public class ExitHandler {
	@Execute
	public void execute(IWorkbench workbench,
			@Named(IServiceConstants.ACTIVE_SHELL) Shell shell){
		if (MessageDialog.openConfirm(shell, "Confirmation",
				"Do you want to exit?")) {
			workbench.close();
It works just fine if the user does "File -> Exit"
But it does not work if he clicks on the "red cross" or does Alt+F4.
How can I call my handler for the two last ways ?
Thank you for your help !
Re: Close application [message #1239101 is a reply to message #1228104] Mon, 03 February 2014 06:11 Go to previous messageGo to next message
Hello Romain,
For Alt+F4, you need to create keybinding and then attach your command to it.
For "red cross", I think your application should be closing automatically unless you explicitly stop it from being closed.
Its late. But I hope it will help
Divya
Re: Close application [message #1239116 is a reply to message #1239101] Mon, 03 February 2014 06:56 Go to previous messageGo to next message
You need to override the IWindowCloseHandler in the IEclipseContext of the Window. Then you'll get this whenever you try to close in any way.
Re: Close application [message #1239119 is a reply to message #1239116] Mon, 03 February 2014 07:01 Go to previous message
And one way to override the IWindowCloseHandler is to listen to the UIEvents.UILifecycle.APP_STARTUP_COMPLETE event in a lifecycle hook.
http://www.eclipse.org/forums/index.php/mv/msg/458123/1017259/#msg_1017259
Previous Topic:own OSGI Service in Eclipse 4 Application
Next Topic:e4 CSS with Toolbars, MenuBar and groups
Current Time: Sat Jul 26 15:23:03 EDT 2025
Powered by FUDForum. Page generated in 0.25029 seconds
