Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo: Issue with Merge()(Teneo: Issue with Merge())
Teneo: Issue with Merge() [message #1228004] |
Mon, 06 January 2014 02:24  |
Iam using TENEO framework and tried to update then object using session.merge().But Iam getting below error:
'Entity not Merged: object references an unsaved transient instance - save the transient instance before flushing'.
The object has list of children of same type. Also I have set following two properties during datastore initialization.
props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "REMOVE,REFRESH,PERSIST,MERGE");
props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_NON_CONTAINMENT, "MERGE,PERSIST,REFRESH,DELETE_ORPHAN");
Chandru
Re: Teneo: Issue with Merge() [message #1228013 is a reply to message #1228004] |
Mon, 06 January 2014 02:46   |
Hi Chandre,
Yes with these properties things should be fine normally. The next thing is to debug into hibernate, set a breakpoint
where hibernate throws the exception, check which entity it is and then check the hbm (dataStore.getMappingXML) if
indeed the mapping is correct.
If you don't see any special then can you post the hbm here with info on which entity/association it fails?
gr. Martin
On 01/06/2014 08:24 AM, Chandre Gowda wrote:
> Hello,
> Thanks
> Chandru
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Teneo: Issue with Merge() [message #1228488 is a reply to message #1228013] |
Tue, 07 January 2014 05:38   |
Thanks Martin.
Please find the hbm below. Iam getting issues when i try to merge execution with children into db. List of children refers to list of executions.
<subclass name="com.test.ExecutionImpl" entity-name="Execution" abstract="false" lazy="false" extends="PropertyContainer" discriminator-value="Execution">
<meta attribute="eclassName" inherit="false">Execution</meta>
<meta attribute="epackage" inherit="false">http://execution/1.0</meta>
<property name="comment" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`comment`"/>
</property>
<property name="uri" lazy="false" insert="true" update="true" not-null="false" unique="false" type="core.URI">
<column not-null="false" unique="false" name="`uri`"/>
</property>
<property name="id" lazy="false" insert="true" update="true" not-null="false" unique="false" type="long">
<column not-null="false" unique="false" name="`id`"/>
</property>
<property name="name" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`name`"/>
</property>
<list name="slots" lazy="false" cascade="persist,merge,delete,refresh,save-update,lock">
<key update="true">
<column name="`slot_owninginstance_e_id`" unique="false"/>
</key>
<list-index column="`execution_slots_idx`"/>
<one-to-many entity-name="Slot"/>
</list>
<many-to-one name="executable" entity-name="Executable" lazy="false" cascade="merge,persist,save-update,lock,refresh" foreign-key="execution_executable" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`executable_executable_e_id`"/>
</many-to-one>
<one-to-one name="executor" entity-name="Executor" cascade="merge,persist,save-update,lock,refresh" lazy="false" property-ref="execution"/>
<list name="children" lazy="false" cascade="persist,merge,delete,refresh,save-update,lock">
<key foreign-key="execution_children_key" update="true">
<column name="`execution_children_e_id`" unique="false"/>
</key>
<list-index column="`execution_children_idx`"/>
<one-to-many entity-name="Execution"/>
</list>
<list name="settings" lazy="false" cascade="persist,merge,delete,refresh,save-update,lock">
<key foreign-key="execution_settings_key" update="true">
<column name="`execution_settings_e_id`" unique="false"/>
</key>
<list-index column="`execution_settings_idx`"/>
<one-to-many entity-name="Property"/>
</list>
<list name="events" lazy="false" cascade="persist,merge,delete,refresh,save-update,lock">
<key foreign-key="execution_events_key" update="true">
<column name="`execution_events_e_id`" unique="false"/>
</key>
<list-index column="`execution_events_idx`"/>
<one-to-many entity-name="ExecutionEvent"/>
</list>
</subclass>
Re: Teneo: Issue with Merge() [message #1228540 is a reply to message #1228488] |
Tue, 07 January 2014 08:10   |
Hi Chandre,
Okay and the transient instance is an instance of Execution (and the association it uses to get their is the
'children')? I mean this is what your debugging found?
To be sure that I/we are looking at the correct association...
(I ask because the mapping looks fine to me, the merge is part of the cascade settings.., so not sure why it does not work)
gr. Martin
On 01/07/2014 11:38 AM, Chandre Gowda wrote:
> Thanks Martin.
> </property>
> </property>
> </property>
> </property>
> <key update="true">
> </key>
> </list>
> not-null="false">
> </many-to-one>
> </key>
> </list>
> </key>
> </list>
> </key>
> </list>
> </subclass>
The Netherlands
Current Time: Wed Jul 30 19:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.04735 seconds
