Home » Archived » Hudson » Hudson svn-tag plug-in 1.16 throwing exception( Hudson svn-tag plug-in 1.16 throwing exception of missing descriptor during upgrade to 3.1.1)
Hudson svn-tag plug-in 1.16 throwing exception [message #1227168] Fri, 03 January 2014 13:49 Go to next message
Hi All.
I have this problem.
I have upgraded our HUDSON 2.2.1 to 3.1.1. I did not have any problem with svn-tag in 2.2.1. however during the upgrade the startup is failing after initialization with an error which is below. This has stopped my upgrade and it looks as if the plugin is no longer compatible with Hudson. if there is another plugin that has the same behavior I would be willing to switch but we do have over 100 projects that will need to be upgraded to us the new plugin which I would rather not do. Very Happy
org.jvnet.hudson.reactor.ReactorException: com.google.common.util.concurrent.ExecutionError: java.lang.AssertionError: class hudson.plugins.svn_tag.SvnTagPublisher is missing its descriptor
at org.jvnet.hudson.reactor.Reactor.execute(Reactor.java:246)
at hudson.model.Hudson.executeReactor(Hudson.java:719)
at hudson.model.Hudson.<init>(Hudson.java:616)
at org.eclipse.hudson.init.InitialRunnable.run(InitialRunnable.java:51)
at java.lang.Thread.run(Thread.java:662)
Caused by: com.google.common.util.concurrent.ExecutionError: java.lang.AssertionError: class hudson.plugins.svn_tag.SvnTagPublisher is missing its descriptor
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2261)
at com.google.common.cache.LocalCache.get(LocalCache.java:4000)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:4004)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4874)
at hudson.model.TopLevelItemsCache.get(TopLevelItemsCache.java:78)
at hudson.model.LazyTopLevelItem.item(LazyTopLevelItem.java:144)
at hudson.model.LazyTopLevelItem.hasPermission(LazyTopLevelItem.java:271)
at hudson.model.Hudson.getItems(Hudson.java:1303)
at hudson.model.Hudson.getItems(Hudson.java:223)
at hudson.model.Hudson.getAllItems(Hudson.java:1367)
at hudson.model.Hudson$12.run(Hudson.java:2481)
at org.jvnet.hudson.reactor.TaskGraphBuilder$TaskImpl.run(TaskGraphBuilder.java:146)
at org.jvnet.hudson.reactor.Reactor.runTask(Reactor.java:259)
at hudson.model.Hudson$4.runTask(Hudson.java:699)
at org.jvnet.hudson.reactor.Reactor$2.run(Reactor.java:187)
at org.jvnet.hudson.reactor.Reactor$Node.run(Reactor.java:94)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
... 1 more
Caused by: java.lang.AssertionError: class hudson.plugins.svn_tag.SvnTagPublisher is missing its descriptor
at hudson.model.Hudson.getDescriptorOrDie(Hudson.java:1009)
at hudson.tasks.Publisher.getDescriptor(Publisher.java:129)
at hudson.tasks.Notifier.getDescriptor(Notifier.java:46)
at hudson.plugins.svn_tag.SvnTagPublisher.getDescriptor(SvnTagPublisher.java:96)
at hudson.plugins.svn_tag.SvnTagPublisher.getDescriptor(SvnTagPublisher.java:31)
at hudson.model.Descriptor.toMap(Descriptor.java:877)
at hudson.util.DescribableList.toMap(DescribableList.java:121)
at hudson.util.DescribableListUtil.convertToProjectProperties(DescribableListUtil.java:126)
at hudson.model.BaseBuildableProject.convertPublishersProperties(BaseBuildableProject.java:356)
at hudson.model.BaseBuildableProject.buildProjectProperties(BaseBuildableProject.java:106)
at hudson.model.FreeStyleProject.buildProjectProperties(FreeStyleProject.java:87)
at hudson.model.Job.onLoad(Job.java:435)
at hudson.model.AbstractProject.onLoad(AbstractProject.java:325)
at hudson.model.BaseBuildableProject.onLoad(BaseBuildableProject.java:94)
at hudson.model.TopLevelItemsCache$1.load(TopLevelItemsCache.java:64)
at hudson.model.TopLevelItemsCache$1.load(TopLevelItemsCache.java:57)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3599)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2379)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2342)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2257)
Re: Hudson svn-tag plug-in 1.16 throwing exception [message #1227204 is a reply to message #1227168] Fri, 03 January 2014 16:13 Go to previous messageGo to next message
What was the version of svn tag plugin you used in 2.2.1?
[Updated on: Fri, 03 January 2014 16:13] by Moderator
Re: Hudson svn-tag plug-in 1.16 throwing exception [message #1229051 is a reply to message #1227204] Wed, 08 January 2014 11:00 Go to previous messageGo to next message
the version that is currently being used is 1.14. I have also upgraded to 1.16 in 2.2.1 and it worked fine but had the same failure during the upgrade process.
Re: Hudson svn-tag plug-in 1.16 throwing exception [message #1232439 is a reply to message #1229051] Thu, 16 January 2014 18:58 Go to previous message
Hi, I have released SVN tag plugin v. 1.17-h-2. With this you should be able to tag in Hudson 3.x. I tested it with 3.1.1
At revision 247
Remote Module Location: https://svn.java.net/svn/hudson-test~tpc-test@247.
Tag Base URL: https://svn.java.net/svn/hudson-test~tpc-test/tags/last-successful/svn-tag-test.
There was no old tag at https://svn.java.net/svn/hudson-test~tpc-test/tags/last-successful/svn-tag-test.
Tagged as Revision 248
Finished: SUCCESS
Previous Topic:SVN Credential Storage
Next Topic:Git Parameter Plugin is missing in Hudson
Current Time: Sat Jul 26 21:23:50 EDT 2025
Powered by FUDForum. Page generated in 0.03532 seconds
