Home » Newcomers » Newcomers » Is Javascript Eclipse a different application?(Should I install other Eclipse for, let say, Java?)
Is Javascript Eclipse a different application? [message #1226335] Wed, 01 January 2014 07:23 Go to next message
Hi, in this new machine I only installed Eclipse for Javascript:
Version: Helios Service Release 1
Build id: 20100917-0705
I'm confussed about if Eclipse for Javascript is an expansion of the actual Eclipse, or it is a different app.
I want to try Java for Android:
Should I append Android SDK tools, or should I download the whole ADT bundle which include Eclipse?
Or should I download last version Eclipse, and add Android SDK tools?
I know this isn't a forum for Android. I mentioned it only for clarity, my question is about if I should have two Eclipse installations.
Thank you very much.
Re: Is Javascript Eclipse a different application? [message #1227140 is a reply to message #1226335] Fri, 03 January 2014 11:56 Go to previous message
You can install new features into your existing Eclipse, it's designed to do that. See the top section of this page for more info: http://www.eclipse.org/downloads/compare.php?release=kepler
Previous Topic:Install Maven plugin via command prompt
Next Topic:slf4j problem with Eclipse Luna
Current Time: Tue Jul 22 02:15:32 EDT 2025
Powered by FUDForum. Page generated in 0.42207 seconds
