Home » Eclipse Projects » Subversive » Update site in flux
Update site in flux [message #12270] Mon, 21 January 2008 05:47 Go to next message
Buckminsters update site has a headless-site.xml file with <archive> entries for the headless
installations. These entries appoints plug-ins from other update sites at eclipse.org. Your site is
among them. This usually works very well since those update-sites are fairly stable. Your site is
moving quite often. I can certainly understand this (Buckminster is also in incubation and our site
is also moving forward) but I'd like to work something out so that I get some kind of notification
when this happens. Would that be possible?
Thomas Hallgren
Re: Update site in flux [message #12346 is a reply to message #12270] Fri, 25 January 2008 07:47 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hi Thomas,
I think it will be good if we also place archive version of update site
together with the latest version. In that case you could refer your
headlessSite.xml to the archive version and the problem will disappear.
What do you think?
Re: Update site in flux [message #12355 is a reply to message #12346] Fri, 25 January 2008 09:52 Go to previous messageGo to next message
As long as the archived site is not zipped or something, that will do just fine. Just tell me what
links you will be using and I'll make the change.
- thomas
Alexander Gurov wrote:
> Hi Thomas,
> What do you think?
Re: Update site in flux [message #12363 is a reply to message #12355] Fri, 25 January 2008 10:27 Go to previous messageGo to next message
Please use following URLs (both points to update site):
http://download.eclipse.org/technology/subversive/archive/v2 0080116
http://www.polarion.org/projects/subversive/download/eclipse /archive/v20080116
where last URL segment is build ID.
Re: Update site in flux [message #12369 is a reply to message #12363] Fri, 25 January 2008 11:14 Go to previous message
Great! Thanks.
- thomas
Previous Topic:Not automatically add new files
Next Topic:Compatibility with EclipseME
Current Time: Sat Nov 01 02:42:50 EDT 2025
Powered by FUDForum. Page generated in 0.04082 seconds
