Home » Archived » BIRT » Drill down with engine API
Drill down with engine API [message #122591] Wed, 01 February 2006 07:45 Go to next message
Originally posted by: jan.tanis.coas.com
I'm trying to implement the runtime engine into our company framework.
And now have the result of a report embedded into a JSP. The report
contains links to other reports, so called drill-down, but the links are
NOT displayed in my embedding. How do I set up the engine so it
generated the right links to the other reports? Do I have to use
IHTMLActionHandler or something like that and can you provide me with an
example? Thanks in advance.
Regards, Jan.
Re: Drill down with engine API [message #122621 is a reply to message #122591] Wed, 01 February 2006 08:11 Go to previous messageGo to next message
Originally posted by: rams.gmail.com
hi jan,
its not answer to ur query but its once again question
as u told ur displaying reports in jsp.
let me know which version of birt ur using for that. and aslo
we are also integrated birt with our company framework and its working
fine with birt 1.0.1
after that we replaced all the 1.0.1 jars with 2.0.0 but its showing NULL
POINTER EXCEPTION when we executing the folloing statement.
reportObj = engine.openReportDesign(reportname);
here reportname is like this : e:\Reports\test.rptdesign
which are created using birt 2.0.0 designer
could help me regarding this plz.
Re: Drill down with engine API [message #122671 is a reply to message #122621] Wed, 01 February 2006 09:02 Go to previous message
rams wrote:
> hi jan,
2.0.0 release build
and aslo
> fine with birt 1.0.1 after that we replaced all the 1.0.1 jars with
> 2.0.0 but its showing NULL POINTER EXCEPTION when we executing the
> folloing statement.
Well, I did use the example code for generating report from Java code,
so you can just view that code from the BIRT website, at least it used
to be there:
public void run(OutputStream outputStream) {
EngineConfig config = new EngineConfig();
config.setEngineHome(engineHome);
if (tempDir != null) {
config.setTempDir(tempDir);
String format = HTMLRenderOption.OUTPUT_FORMAT_HTML;
if(formatType.equalsIgnoreCase("PDF")) {
format = HTMLRenderOption.OUTPUT_FORMAT_PDF;
HTMLEmitterConfig hc = new HTMLEmitterConfig();
HTMLCompleteImageHandler imageHandler
= new HTMLCompleteImageHandler();
hc.setImageHandler(imageHandler);
config.setEmitterConfiguration(
format
, hc);
ReportEngine engine = new ReportEngine(config);
IReportRunnable report = null;
try {
report = engine.openReportDesign(input);
} catch (EngineException e) {
System.err.println("Report not found!\n");
engine.destroy();
return;
if (format != null) {
parseParams(engine, report, parameters);
IRunAndRenderTask task =
engine.createRunAndRenderTask(report);
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFormat(format);
options.setOutputStream(outputStream);
options.setEmbeddable(embeddable);
task.setRenderOption(options);
task.setParameterValues(parameters);
// Run the report.
try {
task.run();
} catch (EngineException e1) {
System.err.println("Report run failed.\n");
System.err.println(e1.toString());
engine.destroy();
Good luck with the integration, it works fine here now:) Besides the
drill-down linking.
Regards, Jan.
Previous Topic:Query Parameters Question
Next Topic:How to migrate birt 1.0.1 to 2.0.0
Current Time: Mon Jul 21 01:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.26451 seconds
