Home » Eclipse Projects » Equinox » Declarative Services in an Eclipse Application
Declarative Services in an Eclipse Application [message #122609] Mon, 15 December 2008 03:51 Go to next message
Hello!
I have a bit of a more general question than most. I am new to this OSGi
Services thing, but I have allready seen some aspects of a project I am
working on, that would be conceptionaly better if they where defined as a
Declarative Service.
For a couple of days I have been trying to figure out how to use
Declarative Services for an Eclipse Plugin. I have been able to launch my
example code as an OSGi framework but how will I go about launching the
same code from a plugin? I have a component that offers a service
implementing an interface. Let's say the service has the name "ServiceA"
Now I have my Eclipse Plug-In code and I would like to use this
"ServiceA" everytime the user selection an Action from a menu.
What is the correct was of doing this? A very first problem I am facing
is how do I launch my eclipse-launch-configuration with declarative
services included? For the OSGi launch one needs to add the
org.eclipse.equniox.ds bundle. But how do I do the analog thing for my
eclipse-launch-configuration? I found some wiki page for using DS with a
RCP and that should be fundamentaly the same but following the
instructions ( edditing the config.ini file ) didn't bring the desired
results.
Can somebody point me to the right direction?
Thank you for reading this far and thank you for your time!
Greetings,
Alexis
Re: Declarative Services in an Eclipse Application [message #122619 is a reply to message #122609] Mon, 15 December 2008 04:40 Go to previous messageGo to next message
I've written an example application some time ago where I also show how
to use DS.
The sources are available here [1].
The things you are interested in are:
- Starting ds when applications starts [2] - this could also be done in
a customized config.ini of course
- Declaration of the DS [3,4,5]
- Accessing the DS [6,7,8,9]
Tom
[1] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/
[2] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.app/src/at/bestsolution/socc er/app/intro/Application.java
[3] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/OSGI-INF/
[4] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/src/at/bestsolution/socce r/ui/IImageStorage.java
[5] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/src/at/bestsolution/socce r/ui/internal/ImageStorageImpl.java
[6] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.playeradmin/src/at/bestso lution/soccer/ui/playeradmin/Activator.java
[7] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.playeradmin/src/at/bestso lution/soccer/ui/playeradmin/PlayerAdministrationDialog.java
[8] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.associationteamadmin/src/ at/bestsolution/soccer/ui/associationteamadmin/Activator.jav a
[9] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.associationteamadmin/src/ at/bestsolution/soccer/ui/associationteamadmin/TeamAdministr ationForm.java
Alexis R. schrieb:
> Hello!
> a Declarative Service. For a couple of days I have been trying to
> figure out how to use Declarative Services for an Eclipse Plugin. I have
> been able to launch my example code as an OSGi framework but how will I
> go about launching the same code from a plugin? I have a component that
> offers a service implementing an interface. Let's say the service has
> the name "ServiceA" :) Now I have my Eclipse Plug-In code and I would
> like to use this "ServiceA" everytime the user selection an Action from
> a menu. What is the correct was of doing this? A very first problem I am
> facing is how do I launch my eclipse-launch-configuration with
> declarative services included? For the OSGi launch one needs to add the
> results. Can somebody point me to the right direction?
> Greetings,
> Alexis
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Declarative Services in an Eclipse Application [message #123004 is a reply to message #122619] Mon, 15 December 2008 05:12 Go to previous messageGo to next message
Thank you very much! You just made my day:D
Re: Declarative Services in an Eclipse Application [message #123035 is a reply to message #122619] Tue, 16 December 2008 08:35 Go to previous messageGo to next message
Hi!
With our help I have written a very small plug-in that uses a service. Or
I should say doesn't use. I have downloaded and installed the equinox.ds
jar and the util jar. The starting of the org.eclipse.equinox.ds now
works. But when I try to get a ServiceReference for my service I get a
null.
My OSGI-INF:
<component immediate="true" name="com.ventuja.service">
<implementation class="com.ventuja.service.implementation.Messenger"/>
<service>
<provide interface="com.ventuja.plugin.interfaces.IMessenger"/>
</service>
</component>
Here is my code that I use to get the ServiceReference:
public IMessenger getMessenger() {
//gives a null
ServiceReference ref =
context.getServiceReference(IMessenger.class.getName());
if( ref != null ) {
return (IMessenger) context.getService(ref);
return null;
It is located in the Activator class of my plugin.
Do I need to change something in my build files or something similar?
I exported my example and have it here:
http://www.ventuja.com/dsplugin.zip if anybody is interested in peeking
into it:)
Thanks you for reading!
Alexis
Re: Declarative Services in an Eclipse Application [message #123047 is a reply to message #123035] Tue, 16 December 2008 10:27 Go to previous messageGo to next message
Originally posted by: ekkehard.gentz-software.de
if you type
services
in your osgi console - is the service listed ?
Alexis R. schrieb:
> Hi!
> Or I should say doesn't use. I have downloaded and installed the
> equinox.ds jar and the util jar. The starting of the
> org.eclipse.equinox.ds now works. But when I try to get a
> ServiceReference for my service I get a null.
> My OSGI-INF:
> <service>
> </service>
> </component>
> //gives a null
> if( ref != null ) {
> return null;
> into it:)
> Alexis
Re: Declarative Services in an Eclipse Application [message #123071 is a reply to message #123035] Tue, 16 December 2008 15:34 Go to previous messageGo to next message
I'd try launching from the Eclipse workspace first as an OSGi
application to eliminate other potential sources of problems. Make sure
that the build.properties includes the OSGI-INF folder.
Is the bundle containing the service started? I recently played with DS
and I recall that I had to start the bundles containing the service
components as well. Just starting the Equinox DS bundle wasn't enough.
But I haven't digged deeper to investigate the reason for this. My
previous assumption was that DS would start the bundles contributing
service components as necessary (similar to the extension registry). But
I haven't found clarification/confirmation in the spec yet.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Declarative Services in an Eclipse Application [message #123110 is a reply to message #123035] Wed, 17 December 2008 02:34 Go to previous messageGo to next message
Originally posted by: b.l.kelly.bigpond.com
The activation of the bundle occurs before DS looks for the service
component definitions, so it won't have published the service.
I think it is safest to always use another service component to access the
services published by a service component. If you use static binding then it
also takes less code as DS does all the work of tracking the service
availability.
"Alexis R." <alexis.raptarchis@googlemail.com> wrote in message
news:6989048d7baf599c0fff567d9738b4fc$1@www.eclipse.org...
> Hi!
> null.
> My OSGI-INF:
> <service>
> </service>
> </component>
> //gives a null
> if( ref != null ) {
> return null;
> into it:)
> Alexis
Re: Declarative Services in an Eclipse Application [message #123121 is a reply to message #123071] Wed, 17 December 2008 07:30 Go to previous messageGo to next message
Hello Gunnar!
You are right! If I first manually start my bundle then it works. But I
can't imagine that this is the way Declarative Services are intented to be
used. Or maybe I have a conceptional problem.
What I have , or better said want to have , is a host plugin that uses
services from other plugins/bundles. My host plugin doesn't know which
bundles will be available so starting them explicitly isn't an option and
imho would go against the whole point of OSGi and a SOA in general no?
I will try to dig deeper into the issue , but still any tips would be
greatly appreciated!
Alexis
> -Gunnar
Re: Declarative Services in an Eclipse Application [message #123145 is a reply to message #123035] Wed, 17 December 2008 08:23 Go to previous messageGo to next message
Hello!
I am replying to my own post because I have found the solution to the
problem ( or better said xmux in the #eclipse irc channel ). It is
intended that one has to start the bundle before DS can collect the
services declared in the bundles. The simplest way of doing this is to use
the startup extension-point from the bundles declaring the services. If
that is a good idea in the long run is a different question but atleast it
works this way.
Also manually starting org.eclipse.equinox.ds through
Platform.getBundle("org.eclipse.equinox.ds").start() is also not needed.
Maybe this info helps somebody in the future!
Thank you for all your help!
Re: Declarative Services in an Eclipse Application [message #123182 is a reply to message #123145] Wed, 17 December 2008 15:43 Go to previous message
> works this way.
The UI startup extension point? Uhh that's hackish. Anyway, I created
the concept of server roles in CloudFree. It is similar to the
application model but allows a more dynamic composition of bundles to be
started or stopped at runtime.
-Gunnar
Gunnar Wagenknecht
Previous Topic:"Deploying the info center as web archive" problem
Next Topic:Why doesn't a "initial@reference" bundle export packages ?
Current Time: Fri Nov 07 06:29:17 EST 2025
Powered by FUDForum. Page generated in 0.19060 seconds
