Home » Eclipse Projects » Equinox » Eclipse-LazyStart vs Bundle-ActivationPolicy
Eclipse-LazyStart vs Bundle-ActivationPolicy [message #122561] Sun, 14 December 2008 17:03 Go to next message
Originally posted by: jmordax.terra.es
Hi, I was developing with Eclipse R3.4.1 and PDE by default, when
checking "Activate this plug-in when one of its classes is loaded",
added to MANIFEST.MF the field:
Bundle-ActivationPolicy: lazy
This worked fine with 3.4.x and 3.5. But when I tested the plug-ins with
3.2.x it failed with a NPE. After some investigation, the problem was
that 3.2 doesn't understand Bundle-ActivationPolicy field. And PDE in
3.2.x adds this other field instead:
Eclipse-LazyStart: true
I have been searching the docs to find why these two different fields
theoretically to do the same thing with no luck. Do you know of any
article related?
Finally, to have plug-ins compatible with previous versions like 3.2.x I
have both fields added to MANIFEST.MF. Does it make sense to you? Can I
have any problem in new releases because I am using two fileds
theoretically for the same thing?
Thanks in advance,
Chemi.
Re: Eclipse-LazyStart vs Bundle-ActivationPolicy [message #122573 is a reply to message #122561] Sun, 14 December 2008 17:11 Go to previous messageGo to next message
Originally posted by: ekkehard.gentz-software.de
Chemi,
since OSGI R4.1 OSGI supports lazy start using
so it makes sense to use this now as default, because its official
OSGI where Eclipse-LazyStart: true was equinox-only.
if you have to be compatible to older versions there's no probem to have
both in your manifest.mf
ekke
> article related?
> Thanks in advance,
> Chemi.
Re: Eclipse-LazyStart vs Bundle-ActivationPolicy [message #122581 is a reply to message #122573] Sun, 14 December 2008 18:23 Go to previous message
Perfect, thanks for the information. That is exactly what I was looking
for...
ekke wrote:
> Chemi,
> have both in your manifest.mf
> ekke
Previous Topic:Problem with Equinox p2 and About info?
Next Topic:Bundle-RequiredExecutionEnvironment property support
Current Time: Fri Jul 18 21:48:23 EDT 2025
Powered by FUDForum. Page generated in 0.24546 seconds
