Home » Modeling » EMF » EMF.ECORE2JAVA run ant from java(EMF.ECORE2JAVA run ant from java)
EMF.ECORE2JAVA run ant from java [message #1225695] Mon, 30 December 2013 09:32 Go to next message
Hello friends
I'm trying to run an ant task from java emf for the generation of code and I get the following error
Exception: _C: \ ....... \ build.xml: 37: The following error occurred while executing this line:
C: \ ................ \ build.xml: 29: Problem: failed to create task or type emf.Ecore2Java
Cause: The name is undefined.
Action: Check the spelling.
Action: Check That any custom tasks / types Have Been Declared.
Action: Check That <presetdef> any / declarations have taken place <macrodef>.
Can you help me with this?
thanks
  • Attachment: probleam.png
    (Size: 34.75KB, Downloaded 192 times)
Re: EMF.ECORE2JAVA run ant from java [message #1225703 is a reply to message #1225695] Mon, 30 December 2013 09:53 Go to previous messageGo to next message
Again, I'm not expert at how to invoke Ant programmatically. I'm not
sure anyone on this forum is such an expert. Nor is it clear to me why
you need such a button. The ant task requires parameters you can more
easily configure in your GenModel and once you have a GenModel you can
easily generate from it. There's even Alt-Shift-G for generating all
models in your workspace.
On 30/12/2013 3:32 PM, javs javs wrote:
> Hello friends
> thanks
Re: EMF.ECORE2JAVA run ant from java [message #1225722 is a reply to message #1225703] Mon, 30 December 2013 10:36 Go to previous messageGo to next message
I want to run it through a button to call it from a plugin, but I could not do it, and I need
Re: EMF.ECORE2JAVA run ant from java [message #1225725 is a reply to message #1225703] Mon, 30 December 2013 10:44 Go to previous message
HI
I'm not an expert either, although I have many scars to show for my
attempts.
Getting the ANT classpath right is really hard. Eclipse provides
integration for plugins but you're not really using a plugin since
you've contrived to have a custom classpath within a plugin classpath.
You therefore need at least to put the EMF ant tasks library on your
classpath.
Ed M recommends a GenModel, which is fine if a GenModel is enough.
I recommend an MWE script which gives you the power to sequence more
than just GenModel.
Ed Willink
> why you need such a button. The ant task requires parameters you can
> more easily configure in your GenModel and once you have a GenModel
> you can easily generate from it. There's even Alt-Shift-G for
> generating all models in your workspace.
>> Hello friends
>> <macrodef>.
>> thanks
Previous Topic:[EMF] XML Serialization sequentially
Next Topic:[EMF Validation] IBatchValidator.validate returns "No constraints were evaluated."
Current Time: Sat Jul 19 00:04:04 EDT 2025
Powered by FUDForum. Page generated in 0.04472 seconds
