Home » Language IDEs » ServerTools (WTP) » Web Deployment Descriptor Disappears(problem with web deployment descriptor)
Web Deployment Descriptor Disappears [message #1225396] Sun, 29 December 2013 12:54 Go to next message
In Eclipse, Kepler, everytime anything touches web.xml then the Web Deployment Descriptor disappears. It reappears when I close and reopen Eclipse. Any ideas?
Karl.
Re: Web Deployment Descriptor Disappears [message #1226625 is a reply to message #1225396] Thu, 02 January 2014 03:30 Go to previous messageGo to next message
Disappears from where? What do you mean by "touches"?
Re: Web Deployment Descriptor Disappears [message #1226740 is a reply to message #1226625] Thu, 02 January 2014 09:57 Go to previous messageGo to next message
Yes,
disappears from the Project Explorer, where it is normally found, and touches, in this context, means edit, as with the xml editor.
Re: Web Deployment Descriptor Disappears [message #1226745 is a reply to message #1226740] Thu, 02 January 2014 10:14 Go to previous messageGo to next message
so, the file web.xml does not disappear (is not deleted), but the node in the Project Explorer that represents the deployment descriptor disappears. Is that correct? In which version of web projects does this happen? Web 3.1 0nly? or also previous versions?
Re: Web Deployment Descriptor Disappears [message #1226752 is a reply to message #1226745] Thu, 02 January 2014 10:45 Go to previous messageGo to next message
Yes, that pretty much sums it up, except that I'm using Web 3.0. I just tried it out with a Web 2.5 project and the same thing happened.
Re: Web Deployment Descriptor Disappears [message #1226779 is a reply to message #1226752] Thu, 02 January 2014 12:40 Go to previous messageGo to next message
This sounds like a bug Smile Could you please open a bugzilla against Java EE tools? https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20Java%20EE%20Tools
Re: Web Deployment Descriptor Disappears [message #1227128 is a reply to message #1226779] Fri, 03 January 2014 11:17 Go to previous message
ok.
Previous Topic:Cannot get Web page editor + some other functionnality do not work
Next Topic:Tomcat 8 / Java EE 7 support in Kepler
Current Time: Tue Nov 04 08:08:33 EST 2025
Powered by FUDForum. Page generated in 0.74473 seconds
