Home » Language IDEs » ServerTools (WTP) » Could not publish to the server(Problem occurs when I try to publish my web project)
Could not publish to the server [message #1000425] Mon, 14 January 2013 13:38 Go to next message
Hi everybody,
When I try to publish one simple web project in tomcat 7 server, the wtp gives me a nullpointer with the following stacktrace:
	at org.eclipse.wst.server.core.util.PublishHelper.publishSmart(PublishHelper.java:331)
	at org.eclipse.wst.server.core.util.PublishHelper.publishSmart(PublishHelper.java:367)
	at org.eclipse.jst.server.tomcat.core.internal.TomcatServerBehaviour.publishDir(TomcatServerBehaviour.java:348)
	at org.eclipse.jst.server.tomcat.core.internal.TomcatServerBehaviour.publishModule(TomcatServerBehaviour.java:268)
	at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publishModule(ServerBehaviourDelegate.java:1046)
	at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publishModules(ServerBehaviourDelegate.java:1138)
	at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publish(ServerBehaviourDelegate.java:955)
	at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publish(ServerBehaviourDelegate.java:774)
	at org.eclipse.wst.server.core.internal.Server.publishImpl(Server.java:3108)
	at org.eclipse.wst.server.core.internal.Server$PublishJob.run(Server.java:345)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
I have tried to remove server and add again, even update eclipse!
This error never happens to me before, can you help-me?
Sorry for my bad english.
Additional information:
eclipse.buildId=M20120914-1800
java.version=1.6.0_29
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=pt_BR
Re: Could not publish to the server [message #1000487 is a reply to message #1000425] Mon, 14 January 2013 16:42 Go to previous messageGo to next message
On 1/14/2013 2:39 PM, Paulo Vitor Braga Pessoa wrote:
> Hi everybody,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
It's not clear exactly what scenario brings about this NPE. Does
right-clicking on the Tomcat 7 server in the Servers view and executing
"Clean..." able to get past this error?
Larry
Re: Could not publish to the server [message #1000768 is a reply to message #1000487] Tue, 15 January 2013 07:05 Go to previous messageGo to next message
Larry Isaacs wrote on Mon, 14 January 2013 16:42
Larry
So, when I do this, the same NPE occurs. I tried to re-build the project and clean de work directory of tomcat too. Nothing of this actions works for me.
Thank you for the answer!
Paulo
Re: Could not publish to the server [message #1002407 is a reply to message #1000768] Fri, 18 January 2013 09:17 Go to previous messageGo to next message
>> executing "Clean..." able to get past this error?
>> Cheers,
>> Larry
> for me.
> Paulo
I've inspected the code and I have no good guesses as to what is causing
you to encounter the NPE. It's not something I've ever seen. The stack
trace indicates that you have selected "Use Tomcat installation...". Do
you get the same behavior with "Use workspace metadata..."?
Larry
Re: Could not publish to the server [message #1224802 is a reply to message #1002407] Fri, 27 December 2013 15:42 Go to previous messageGo to next message
I just get this exact misbehaviour with Kepler Build id: 20130919-0819 . Stack trace belows.
It's something on the workspace? The project was being published all-right for months. without any problems. And then, for no apparent reason, this error start to popup from nowhere.
I deleted the server from workspace, recreated and no go.
I deleted org.eclipse.wst.xml.core from .metadata\.plugins . It was recreated, but no go.
I even deleted every org.eclipse.wst.* on .plugins. No go.
It appears to be a regression from https://bugs.eclipse.org/bugs/show_bug.cgi?id=219627
Should I reopen the bug?
	at org.eclipse.wst.server.core.util.PublishHelper.publishSmart(PublishHelper.java:188)
	at org.eclipse.jst.server.generic.core.internal.publishers.AbstractModuleAssembler.copyModule(AbstractModuleAssembler.java:170)
	at org.eclipse.jst.server.generic.core.internal.publishers.EarModuleAssembler.assemble(EarModuleAssembler.java:45)
	at org.eclipse.jst.server.generic.core.internal.publishers.AntPublisher.assembleModule(AntPublisher.java:169)
	at org.eclipse.jst.server.generic.core.internal.publishers.AntPublisher.publish(AntPublisher.java:130)
	at org.eclipse.jst.server.generic.core.internal.GenericServerBehaviour.publishModule(GenericServerBehaviour.java:82)
	at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publishModule(ServerBehaviourDelegate.java:1091)
	at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publishModules(ServerBehaviourDelegate.java:1183)
	at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publish(ServerBehaviourDelegate.java:987)
	at org.eclipse.wst.server.core.internal.Server.publishImpl(Server.java:3153)
Re: Could not publish to the server [message #1225766 is a reply to message #1224802] Mon, 30 December 2013 13:38 Go to previous message
> Stack trace belows.
> at
This is a different bug since the NPE is at a different location. The
code for your NPE is:
long mod = -1;
IFile file = (IFile) mf.getAdapter(IFile.class);
if (file != null) {
mod = file.getLocalTimeStamp();
} else {
File file2 = (File) mf.getAdapter(File.class);
mod = file2.lastModified(); // Line 331
The code is trying to determine the modified date of a file resource in
your project, which is why deleting things under the ".metadata" folder
didn't help. It would seem that a resource in your project that is
expected to be a file somehow isn't, or is corrupted in some way.
Unfortunately the code offers nothing in the way of diagnostic help
beyond the NPE. If you aren't able to guess which resource is the
problem, I would suggest you create a separate workspace and in that
workspace create a simple dummy plug-in project. Run this plug-in
project in debug mode and import your dynamic web project into the
workspace it creates. Set up your server and set a breakpoint on
NullPointerException. Then try to publish and hopefully you will be
able to tell from the "mf" variable what resource is causing the
problem. There might be other "normal" NPEs that occur before hitting
line 331 of PublishHelper. Source for PublishHelper can be obtained
from the the link[1] below.
Larry
[1]
http://git.eclipse.org/c/servertools/webtools.servertools.git/tree/plugins/org.eclipse.wst.server.core/servercore/org/eclipse/wst/server/core/util/PublishHelper.java
Previous Topic:Generating WS Client from WSDL gives faulty code
Next Topic:WYSIWYG functionality available?
Current Time: Thu Jul 24 22:27:47 EDT 2025
Powered by FUDForum. Page generated in 0.08201 seconds
