Home » Eclipse Projects » Sirius » How can I change the vertical alignment of a label?(How can I change the vertical alignment of a label?)
How can I change the vertical alignment of a label? [message #1224531] Thu, 26 December 2013 20:57 Go to next message
is this possible with sirius?
[Updated on: Thu, 26 December 2013 21:06] by Moderator
Re: How can I center vertically a label inside a node? [message #1224743 is a reply to message #1224531] Fri, 27 December 2013 12:13 Go to previous messageGo to next message
Hi Camilo,
If you create a NodeMapping, you will have two label positions available
for several styles, if you selected the 'node' position, label will be
vertically centered [1]
If you want to use a ContainerMapping (to create lists or containers),
the label will be placed on the top of the figure [2]. It is not
possible to vertically center the label of a Container by changing some
properties in the VSM editor, but it should be possible to change the
label position for containers by extending the core edit parts, policies
and figures.
Maxime
[1]
http://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#node_styles
[2]
http://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#Container
Styles
Re: How can I center vertically a label inside a node? [message #1227180 is a reply to message #1224743] Fri, 03 January 2014 14:39 Go to previous message
Thank you Maxime,
I finally created a org.eclipse.sirius.diagram.styleConfigurationProvider to customize the styles.
Camilo.
Previous Topic:Diagram extensions behave differently
Next Topic:How to use a Papyrus UML profile as a DSL in Sirius?
Current Time: Sat Jul 26 10:24:17 EDT 2025
Powered by FUDForum. Page generated in 0.46759 seconds
