Using OCLHelper and OCL API... Simple working example !? [message #1224383] |
Thu, 26 December 2013 09:51  |
I follow OCL Pivot programmer guid to create standalone java code that uses OCLHelper and OCL API's to parse and evaluate OCL query on a UML model (State machine). Simply we pass OCL query as sting and the model URI then we load the model and parse OCL query and return the result .! since I do not find a simple start-up and complete working example, I struggle with the following code (project attached as well) and I keep getting the following error :
Failed to load '_WseC8G46EeO2DthnKXWrzA.essentialocl'
Please any advice to fix this error in order to get OCL result. Is their any simple and complete working example do such functionality.
I appreciate your help
@SuppressWarnings("unchecked")
public List<String> exeOcl(String ModelPath, String OclString) {
List<String> result = null;
try{
// ****** Load UML model ******
baseModelURL = URI.createFileURI(ModelPath);
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
resourceSet.createResource(baseModelURL);
Resource resource = resourceSet.getResource(baseModelURL, true);
Model umlModel = (Model) EcoreUtil.getObjectByType(resource.getContents(), UMLPackage.Literals.MODEL);
System.out.println("The model is successfully loaded. " + "Model Name is : " + umlModel.getName());
//**** OCL parsing OCL *******
OCL ocl = OCL.newInstance(new PivotEnvironmentFactory());
//how to set the context !??
OCLHelper oclHelper = ocl.createOCLHelper(umlModel);
//OCLHelper oclHelper = ocl.createOCLHelper(UMLPackage.Literals.MODEL);
//oclHelper.setInstanceContext(UMLPackage.Literals.MODEL);
ExpressionInOCL OclQuery = oclHelper.createQuery(OclString);
List<String> evaluateResult = (List<String>) ocl.evaluate(umlModel, OclQuery);
// loop in the list to printout the result
while (!evaluateResult.isEmpty()){
System.out.printf("Rsults : " + "%s",evaluateResult);
result = evaluateResult;
catch (ParserException e1) {
System.out.println("Error ....");
Diagnostic diagnostic = e1.getDiagnostic();
System.out.println(diagnostic.getMessage());
catch(Exception e){
System.out.println(e.getMessage());
return result;
thank you
[Updated on: Thu, 26 December 2013 15:47] by Moderator
Re: Using OCLHelper and OCL API... Simple working example !? [message #1224460 is a reply to message #1224383] |
Thu, 26 December 2013 15:30   |
The attached code has no imports.
http://wiki.eclipse.org/OCL/ForumNetiquette
Ed Willink
On 26/12/2013 14:51, Naif Mokhayesh wrote:
> try{
> true);
> catch(Exception e){
> return result;
> thank you
Re: Using OCLHelper and OCL API... Simple working example !? [message #1224465 is a reply to message #1224460] |
Thu, 26 December 2013 15:48   |
Hi Ed,
thank you for your reply. sorry for missing imports. I add it now and a complete test project is attached as well
package testocl;
import java.util.List;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
import org.eclipse.emf.common.util.Diagnostic;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.ocl.examples.pivot.ExpressionInOCL;
import org.eclipse.ocl.examples.pivot.OCL;
import org.eclipse.ocl.examples.pivot.ParserException;
import org.eclipse.ocl.examples.pivot.helper.OCLHelper;
import org.eclipse.ocl.examples.pivot.utilities.PivotEnvironmentFactory;
public class UtilitiesLibrary {
private static URI baseModelURL = null;
try{
catch(Exception e){
return result;
thanks again for help
[Updated on: Thu, 26 December 2013 15:51] by Moderator
Re: Using OCLHelper and OCL API... Simple working example !? [message #1224654 is a reply to message #1224465] |
Fri, 27 December 2013 06:08   |
I see no test project, but the imports show that you are using the pivot
code but seem to have ignored the "Pivot Standalone Configuration"
section of the documentation.
Ed Willink
On 26/12/2013 20:48, Naif Mokhayesh wrote:
> Hi Ed,
> thanks you for your reply. sorry for missing imports. I ad it now and
> package testocl;
> try{
> true);
> catch(Exception e){
> return result;
FUDForum. Page generated in 0.06804 seconds
