[CDO 0.8.0 M7] problem retreiving collection [message #122410] |
Tue, 13 May 2008 18:36  |
Eike,
With Eclipse 3.4, etc release coming soon I have taken up again the
migration to CDO from Teneo.
I am having a problem which keeps me from continuing however.
To help you understand the model assume I have a Library class which
contains a Book class. Then the model has a number of sub-classes of book,
like redBook blueBook. In addition from the Library class there are
references to each sub class of Book. So for example I can retrieve all
the redBooks via a call to getRedBooks() on the Library object. So again,
I have two references to each sub class, one is to the super class Book
and then one to each sub class. In this way I can retrieve all Books or
all RedBooks.
BTW, the Book class is not abstract.
Now, in addition there are references from Book to other collections, like
OldBook or BigBook. As you can imagine I can from a OldBook collection
retrieve all Books via a call to the getBooks() method of OldBook object.
My problem is that if I retrieve all Books from an OldBook object and then
from each indivdual Book call getLibrary() that ALWAYS returns null. I can
not seem to get the Library from a Book.
This does not fail with Teneo, my production system.
Looking forward to your help,
Mark.
Re: [CDO 0.8.0 M7] problem retreiving collection [message #122421 is a reply to message #122410] |
Wed, 14 May 2008 02:48   |
Mark,
If I got you right, it seems like an issue with eContainer() or something
like that. Once there was a Bugzilla about that but I think it was fixed.
Maybe something was missing. Do you think you could provide me with a
small model that can demonstrate the effect. Just an Ecore file attached
to a new Bugzilla would be good.
Cheers
/Eike
geib wrote:
> Eike,
> all RedBooks.
> Mark.
Re: [CDO 0.8.0 M7] problem retreiving collection [message #122520 is a reply to message #122502] |
Thu, 15 May 2008 03:35  |
geib wrote:
> Eike,
> Time is a little scarce but I could send you the .ecore I am having the
> problem with. Would that work for you. If not I will make the time latter
> tonight to work on a simple model that reproduces the problem.
Yes, the model you are using will be fine. Please send it to me via Email
and I'll keep it confidential. I'll also file a Bugzilla then and CC you.
Cheers
/Eike
Re: [CDO 0.8.0 M7] problem retreiving collection [message #618038 is a reply to message #122410] |
Mark,
Cheers
/Eike
geib wrote:
> Eike,
> all RedBooks.
> Mark.
Re: [CDO 0.8.0 M7] problem retreiving collection [message #618048 is a reply to message #122502] |
geib wrote:
> Eike,
Cheers
/Eike
FUDForum. Page generated in 0.04855 seconds
