Re: Changing thread group of UIThread [message #122381 is a reply to message #122308] |
Tue, 24 February 2009 05:41  |
Enrico,
allowing to specify the ThreadGroup for UI threads isn't planned.
For now you would need to base the "context" mechanism on the session.
Rüdiger
Enrico Zanaga wrote:
> Hi Rüdiger,
> in my RCP application I've a "context" based on the ThreadGroup.
> If I be able to change the ThreadGroup of UIThread I can reuse the code,
> otherwise I must implement a "context" mechanism based on session id.
> Or I will try to find a workaround...
> Thanks anyway
> Rüdiger Herrmann ha scritto:
>> Enrico,
>> this is currently not possible. Why would you like to do that?
>> Cheers,
>> Rüdiger
>>> Hi,
>>> is it possible to change the ThreadGroup of any UIThread?
>>> Thanks
>>> Enrico
FUDForum. Page generated in 0.04035 seconds
