Home » Modeling » ATL » Migration from ATL to EMFTVM
Migration from ATL to EMFTVM [message #1039708] Fri, 12 April 2013 09:40 Go to next message
Dear all,
I am migrating quite a lot of code from ATL to EMFTVM. I thought the modification would be quite straight forward but I experienced several differences. Is there some documentation about the differences; or some guidelines on how to do this kind of migration?
For instance, a difference is that in atl, the any() operator returns OclUndefined if no object is found; while emftvm thows an exception in that case. Another important difference is that atl allows to initialize a local variable to OclUndefined and then to give avalue to this variable in the do section; while EMFTVM does not allow this.
Some how the question is: what are the constructs of atl that should be avoided when using EMFTVM?
Etienne.
Re: Migration from ATL to EMFTVM [message #1041075 is a reply to message #1039708] Sun, 14 April 2013 11:23 Go to previous messageGo to next message
EMFTVM includes a re-implementation of the OCL standard library, this time
based on OCL 2.2 instead of OCL 2.0. OCL 2.2 introduces OclVoid and OclInvalid
as a replacement for OclUndefined. As ATL syntax uses OclUndefined, I decided
to use the following mapping:
OclVoid -> OclUndefined (null in Java)
OclInvalid -> throw exception (fail fast principle)
OCL specifies the semantics of any() as select()->first() for Sequence. I
interpreted the outcome of first() on an empty Sequence to be OclInvalid,
hence exception. This is also compatible with the way Java treats collections.
That said, transforming empty collections to OclUndefined and vice versa is a
very common scenario in ATL, so this should be easy to do. Also, Java
collections cannot contain null values, so there is no ambiguity in returning
OclUndefined on Sequence::first().
Anyone else like to comment on this?
Dennis
Re: Migration from ATL to EMFTVM [message #1041909 is a reply to message #1041075] Mon, 15 April 2013 14:50 Go to previous messageGo to next message
XText OCL console gives:
Evaluating:
self.eStructuralFeatures->select(e|false)->first()
Results:
Evaluation failure
Empty 'OrderedSet' for 'first'
Evaluating:
self.eStructuralFeatures->any(e|false)
Results:
null
OCL console gives:
Evaluating:
Results:
OclInvalid
Evaluating:
Results:
I suppose that settles it: any() will return OclUndefined on an empty
collection. It's the pragmatic thing to do, and it coincides with current ATL
behaviour, as well as Eclipse OCL behaviour.
Dennis
Re: Migration from ATL to EMFTVM [message #1041969 is a reply to message #1041909] Mon, 15 April 2013 16:49 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Hi<br>
<br>
There is no OclUndefined.<br>
<br>
This is OMG Issue 18504.<br>
<br>
The OCL specification is superficially ambiguous.<br>
<meta http-equiv="CONTENT-TYPE" content="text/html; charset=UTF-8">
<p style="font-weight: normal"><font size="2">The 'equivalent' OCL
of</font></p>
<p style="margin-top: 0.2cm; page-break-before: auto" align="LEFT"
lang="en-US">
<font face="Courier New, monospace"><font size="2">source-&gt;select(iterator
body)-&gt;asSequence()-&gt;first()</font></font></p>
<p style="font-weight: normal"><font size="2">returns invalid if no
elements are selected, rather than null as the words say.</font></p>
<p style="font-weight: normal"><font size="2">As identified in Issue
18125, null could also be a valid value, so the words are
clearly
wrong.</font></p>
<title></title>
<meta name="GENERATOR" content="LibreOffice 4.0.0.3 (Windows)">
<style type="text/css">
@page { size: 21cm 29.7cm; margin: 2cm }
P { margin-top: 0.42cm; margin-bottom: 0cm; text-align: left }
P.western { font-family: "Arial", sans-serif; font-size: 12pt }
P.cjk { font-size: 12pt }
A:visited { color: #800080; text-decoration: underline }
A:link { color: #0000ff; text-decoration: underline }
</style><br>
Eclipse OCL is changing. The Pivot binding has no legacy and so can
just change.<br>
The Ecore binding can be corrected by a new preference option.<br>
<br>
    Regards<br>
<br>
        Ed Willink<br>
<br>
On 15/04/2013 19:50, Dennis Wagelaar wrote:
<blockquote cite="mid:kkhi5e$e1a$1@xxxxxxxxe.org" type="cite">
<pre wrap="">I suppose that settles it: any() will return OclUndefined on an empty
Dennis
</pre>
</blockquote>
<br>
</body>
</html>
Re: Migration from ATL to EMFTVM [message #1042635 is a reply to message #1041969] Tue, 16 April 2013 13:32 Go to previous messageGo to next message
Op 15-04-13 22:49, Ed Willink schreef:
> Hi
Not anymore, but ATL's syntax is still based on OCL 2.0.
> The 'equivalent' OCL of
> source->select(iterator | body)->asSequence()->first()
> returns invalid if no elements are selected, rather than null as the words say.
> As identified in Issue 18125, null could also be a valid value, so the words
> are clearly wrong.
> Eclipse OCL is changing. The Pivot binding has no legacy and so can just change.
> Regards
> Ed Willink
Thanks for the update! We'll have to track this issue, and see how it is
resolved then.
Dennis
Re: Migration from ATL to EMFTVM [message #1042702 is a reply to message #1042635] Tue, 16 April 2013 15:26 Go to previous messageGo to next message
This issue is now tracked in bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=405820
Dennis
Re: Migration from ATL to EMFTVM [message #1050628 is a reply to message #1042702] Sat, 27 April 2013 09:39 Go to previous messageGo to next message
Dear all,
Continuing the migration, I experienced another important difference: this has to do with adding elements to a list of the output model.
I filed a bug for this, which was not really a bug but maybe something more difficult to deal with on my end.
Here is a reference to the bug I initially posted:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=406100
after trying a lot to have this working, I am still quite puzzled by the answer.
Here is basically my need.
I have an element of class C that contains an attribute ATTR and list L. I am not using the refining mode however my input and output metamodels are the same. When I match an element c of type C, I want to copy the list from c in a list of c' (image of c). This is easy, and I do it in a matched rule. Now, when I match the attribute ATTR of c in another matched rule, I want to add an element in the image of L, produced by the previous rule.
Usinf the ATL runtime, I would basically write something like this: c'.L.add(...); in a "do" section. To be precise, c' can be retreived in this second rule using the resolveTemp operation.
However the 'add' operation is not supported by EMFTVM. Trying to use attribute helpers make the code very difficult to write, read, understand and debug...
So, I am asking for some advice to add elements to a list in different rules? Could rules inheritence be of any help here?
I could basically create c' and L' in a rule R1 and add elements to L' in a rule R2 that matches L and inherits from R1. Would that be how you would proceed? If so, my problem is that I have L defined in a resource res1 and c defined in another resource res2 that reference res1. As I only pass res1 as an input resource, my matched rules will thus only apply to elements from the resource res1 and L will not be matched. Thus R1 would be a matched rule and R2 a lazy rule... And I cannot use inheritence.
Finally, another option is to add res2 as an input of the model transformation. Then my question is: can I have an unknown number of input resources? I basically take resources from a set of file that varies, this set being provided by the users of my tool...
I am quite lost now: I think EMFTVM provides really nice features (specially for rules inheritence and traces mechanisms) but to my opinion it either needs an "add()" operation for lists of the output models, or a way to give a list of input models without enumerating each of them in advance.
What do you think? I hope I have been clear in enumerating the different problems/solutions; don't hesitate to ask if it is not the case.
Thanks in advance for your answer and best regards,
Etienne.
Re: Migration from ATL to EMFTVM [message #1050771 is a reply to message #1050628] Sat, 27 April 2013 14:45 Go to previous messageGo to next message
You should normally try to collect all elements you want to assign to the list
reference in the same rule as where you create the element that owns the list
reference:
rule ... {
from ...
to t : MM!C (
list <- MM!Child.allInstances()->select(c | ...)->union(...)
You can indeed not mix rule types in rule inheritance.
You can add many unknown models to your run config, and you can use their
contents in matched rules, as long as you don't require those rules to match
on specific input models. So like this:
rule ... {
from s : MM!Class
to ...
....and not like this:
rule ... {
from s : MM!Class in IN
to ...
NOTE that this doesn't work in the other ATL VMs, as the compiler always
compiles in a filter on a specific input model. This was done to work around
the issue that the other ATL VMs could otherwise match metamodel elements in
addition to input model elements. EMFTVM does not require this workaround, and
can match over all input (and in/out) models in general.
You could perhaps use the trace model to collect the elements created by your
various rules, and use that to assign to your reference list. That way you
don't even have to come up with a complex expression to collect the elements.
> Etienne.
I've given some ideas to write your transformation in an alternative way. It
will generally be much easier to get ATL/EMFTVM to do what you want using
declarative/functional style programming and matched or lazy rules. In
addition, you can use reflection on the trace model.
Hope this helps!
Dennis
Re: Migration from ATL to EMFTVM [message #1053439 is a reply to message #1050771] Sun, 05 May 2013 16:47 Go to previous messageGo to next message
Hi Dennis,
yes, the information you provided really helped! Out of the different improvement provided by EMFTVM, this one (matching every input resource) would have been put first in my motivations for the migration! ... This is just great!
Thanks a lot,
Etienne.
Migration from ATL to EMFTVM [message #1219497 is a reply to message #1039708] Wed, 04 December 2013 04:24 Go to previous messageGo to next message
I'm trying to migrate from ATL to EMFTVM but I have some issues with TupleType. I have several unique lazy rule where the element from is a Tuple, because the generation of an unique element depends of several constrains that are represents in the differents tuple values. That rules work properly with ATL but when I migrate to EMFTVM I get the error:
org.eclipse.m2m.atl.emftvm.util.VMException: java.lang.NoSuchFieldException: Field org.eclipse.m2m.atl.emftvm.util.Tuple::beanName not found
The rule is this:
unique lazy rule presentationObject {
	from
		beanNameAndContainer : Type(beanName : String, objectContainer : mmMIGRARIAMVC!ObjectRequestContainer)
	to
		presentationObject : mmMIGRARIAMVC!PresentationObject (
			name <- beanNameAndContainer.beanName,
			container <- (beanNameAndContainer.objectContainer),
Víctor Pavón.
Re: Migration from ATL to EMFTVM [message #1219504 is a reply to message #1219497] Wed, 04 December 2013 05:26 Go to previous messageGo to next message
Can't you use multiple from elements instead ?
Re: Migration from ATL to EMFTVM [message #1219517 is a reply to message #1219504] Wed, 04 December 2013 06:43 Go to previous messageGo to next message
Hello Sylvain,
I can't use multiple elements because I need that for each different value of the pair of element generate a new element. If I use multiple element ATL only consider the firstone to run the unique lazy rule, and I get less elements that I want.
Thank you.
Re: Migration from ATL to EMFTVM [message #1219534 is a reply to message #1219517] Wed, 04 December 2013 08:15 Go to previous messageGo to next message
There's a workaround for that.
You can compute a "unique" string and use that as the first element in the lazy rule even if you don't use it in the rule itself
Re: Migration from ATL to EMFTVM [message #1219561 is a reply to message #1219517] Wed, 04 December 2013 11:04 Go to previous messageGo to next message
Victor Pavon wrote on Wed, 04 December 2013 12:43
Hello Sylvain,
Thank you.
Hmm, this should work with ATL/EMFTVM. Can you try it?
Re: Migration from ATL to EMFTVM [message #1219562 is a reply to message #1219497] Wed, 04 December 2013 11:20 Go to previous messageGo to next message
Victor Pavon wrote on Wed, 04 December 2013 10:24
The rule is this:
	from
	to
That's a bug in EMFTVM: you may report it in bugzilla.
Re: Migration from ATL to EMFTVM [message #1219565 is a reply to message #1219562] Wed, 04 December 2013 11:38 Go to previous messageGo to next message
Dennis Wagelaar wrote on Wed, 04 December 2013 17:20
The rule is this:
	from
	to
You may work around this bug by accessing the tuple entry using the "get" operation:
beanNameAndContainer.get ('beanName')
Re: Migration from ATL to EMFTVM [message #1219646 is a reply to message #1219565] Thu, 05 December 2013 03:09 Go to previous messageGo to next message
Dennis Wagelaar wrote on Wed, 04 December 2013 17:38
The rule is this:
	from
	to
Thank you Dennis, it works properly
[Updated on: Thu, 05 December 2013 03:09] by Moderator
Re: Migration from ATL to EMFTVM [message #1219647 is a reply to message #1219646] Thu, 05 December 2013 03:13 Go to previous messageGo to next message
Know I found another problem. When I have a rule with multiple to elements and I reference someone in other I get the error:
org.eclipse.m2m.atl.emftvm.util.VMException: java.lang.IllegalArgumentException: Cannot assign MIGRARIA_MVC.View.impl.ObjectPresentationCollectionImpl@1e3fc30 (name: subjects) (paginated: false, orderCriteria: null, multiSelection: false) to multi-valued field DataSet_PA::items
at rule presentationObjectAndPresentationCollectionCase2b@applier#50(platform:/resource//migraria.m2m.strutsJSP2MIGRARIAMVC_View/transformations/strutsJPS2MIGRARIAMVCview.atl#[228:5-228:36])
	Local variables: [__trace__: TRACE!TraceLink = c1c9d3:TRACE!TraceLink, logicIterate: mmStrutsJSP!JSPActionStrutsLogicIterate = logic:iterate:mmStrutsJSP!JSPActionStrutsLogicIterate, presentationCollection: mmMIGRARIAMVC!ObjectPresentationCollection = subjects:mmMIGRARIAMVC!ObjectPresentationCollection, presentationAttributeParentObjet: mmMIGRARIAMVC!DataSet_PA = subjects:mmMIGRARIAMVC!DataSet_PA]
at static EMFTVM!ExecEnv::main() : Object(platform:/resource//migraria.m2m.strutsJSP2MIGRARIAMVC_View/transformations/strutsJPS2MIGRARIAMVCview.atl)
	Local variables: []
This is an excerpt of the rule:
	rule presentationObjectAndPresentationCollectionCase2b {
		from
			logicIterate : mmStrutsJSP!JSPActionStrutsLogicIterate
		to
			presentationCollection : mmMIGRARIAMVC!ObjectPresentationCollection (
			presentationAttributeParentObjet : mmMIGRARIAMVC!DataSet_PA (
				items <- presentationCollection
Re: Migration from ATL to EMFTVM [message #1219661 is a reply to message #1219647] Thu, 05 December 2013 05:31 Go to previous messageGo to next message
Apparently, "items" is a collection attribute. Regular ATL is forgiving on this, and just adds your valua to the collection. EMFTVM requires that you assign the correct type:
items <- Sequence{presentationCollection}
Re: Migration from ATL to EMFTVM [message #1219702 is a reply to message #1219661] Thu, 05 December 2013 08:23 Go to previous messageGo to next message
Dennis Wagelaar wrote on Thu, 05 December 2013 11:31
Thank you, solve problem.
When I finish the migration, I'll post all the changes that I have to do to adapt the rules.
Re: Migration from ATL to EMFTVM [message #1219703 is a reply to message #1219702] Thu, 05 December 2013 08:25 Go to previous messageGo to next message
Other problem that I found is for example in helpers that return an EenumType I get the error (DirectionalTypes is the EenumType name):
org.eclipse.m2m.atl.emftvm.util.VMException: Error during module loading: Type DirectionalTypes not found in metamodel org.eclipse.m2m.atl.emftvm.impl.MetamodelImpl@1f6013a (resource: migraria.mvc)
Re: Migration from ATL to EMFTVM [message #1219717 is a reply to message #1219703] Thu, 05 December 2013 09:48 Go to previous messageGo to next message
Victor Pavon wrote on Thu, 05 December 2013 14:25
EMFTVM currently only supports EClass instances as parameter/return types. Using "OclAny" will solve your issue for now. However, we should look into supporting all EClassifier instances as type declarations within EMFTVM. You may report this as a bug, so I will remember to look into it Wink.
Re: Migration from ATL to EMFTVM [message #1220082 is a reply to message #1219717] Mon, 09 December 2013 09:51 Go to previous messageGo to next message
Dennis Wagelaar wrote on Thu, 05 December 2013 15:48
Thank you, problem solved Wink
Re: Migration from ATL to EMFTVM [message #1220210 is a reply to message #1220082] Tue, 10 December 2013 06:55 Go to previous messageGo to next message
After execute full ATL rule without errors after adaptation from ATL. When I open the trace model I get an error like:
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'iDataSet_PA:null -> []' is not legal. (platform:/resource/migraria.m2m.strutsJSP2MIGRARIAMVC_View/mTarget/crs/trace.xmi, 22073, 5681)
The element iDataSet_PA is an unique lazy rule.
Best regards, Víctor.
Re: Migration from ATL to EMFTVM [message #1220249 is a reply to message #1220210] Tue, 10 December 2013 10:49 Go to previous messageGo to next message
I can't tell why your trace model cannot be read back. Can you upload your zipped project somewhere (e.g. Google Drive)?
Re: Migration from ATL to EMFTVM [message #1222509 is a reply to message #1220249] Fri, 20 December 2013 11:17 Go to previous messageGo to next message
Dennis Wagelaar wrote on Tue, 10 December 2013 16:49
Hello Dennis,
Thank you for your help. Finally I found the problem. The problem was that I used an element of tuple type in the from clause. I change this for several from elements and now it works properly.
Re: Migration from ATL to EMFTVM [message #1222532 is a reply to message #1222509] Fri, 20 December 2013 12:38 Go to previous messageGo to next message
Hello Dennis,
about the operation toSequence(), isn't it supported in EMFTVM?
Re: Migration from ATL to EMFTVM [message #1223251 is a reply to message #1222532] Sun, 22 December 2013 17:43 Go to previous messageGo to next message
op 20-12-13 18:38, Victor Pavon schreef:
> Hello Dennis,
String::toSequence() is indeed not (yet) supported; it's not part of the OCL
2.2 spec, but is an ATL addition. You can implement it as follows, however:
helper context String def : toSequence() : Sequence(String) =
Sequence{}
->includingRange(0, self.size() - 1)
->collect(i | self.charAt(i).toString());
Dennis
Re: Migration from ATL to EMFTVM [message #1228958 is a reply to message #1223251] Wed, 08 January 2014 07:20 Go to previous messageGo to next message
Thank you very much, Dennis.
Dennis Wagelaar wrote on Sun, 22 December 2013 23:43
> Hello Dennis,
Sequence{}
Dennis
Re: Migration from ATL to EMFTVM [message #1384823 is a reply to message #1228958] Mon, 02 June 2014 07:15 Go to previous messageGo to next message
I still migrating some transformations to EMFTVM, and I have problems with regexReplaceAll operation. It is supported by EMFTVM?
Best Regards,
Víctor.
Re: Migration from ATL to EMFTVM [message #1384919 is a reply to message #1384823] Tue, 03 June 2014 03:13 Go to previous message
EMFTVM exposes the underlying Java API, instead of ATL's renamed "replace*" operations:
http://docs.oracle.com/javase/6/docs/api/java/lang/String.html#replaceAll(java.lang.String, java.lang.String)
http://docs.oracle.com/javase/6/docs/api/java/lang/String.html#replace(java.lang.CharSequence, java.lang.CharSequence)
So: regexReplaceAll() becomes replaceAll() and replaceAll() becomes replace()
Previous Topic:AM3 installation for ATL Version 3.x
Next Topic:[EMFTVM] writing to console
Current Time: Sat Jul 26 17:04:59 EDT 2025
Powered by FUDForum. Page generated in 0.07578 seconds
