Home » Eclipse Projects » Remote Application Platform (RAP) » disabled/read-only Text theming
disabled/read-only Text theming [message #122242] Sun, 22 February 2009 22:38 Go to next message
I would like to set the background color of a disabled and/or read-only
Text widget using CSS theming.
The code is:
text1.setEnabled(false);
text2.setEditable(false);
The CSS code is:
Text:disabled {
background-color: gray;
but this seems to have no effect on the background color.
Any ideas would be appreciated.
Thanks!
-Jim
Re: disabled/read-only Text theming [message #122253 is a reply to message #122242] Mon, 23 February 2009 05:10 Go to previous messageGo to next message
Hi Jim,
I'm very thankful for comments like this, as they reveal what people are
actually struggling with.
Jim Tilley wrote:
For the read-only part of your question, the Text widget does not have a
CSS state "read-only" yet. If you need it, feel free to file a bug for
this problem. It shouldn't be hard to implement this state.
> The CSS code is:
> Text:disabled {
This should work, but I see that it currently doesn't. There must be a
bug in the theming. Could you file a bug report for this too?
Best regards, Ralf
Re: disabled/read-only Text theming [message #122264 is a reply to message #122253] Mon, 23 February 2009 05:30 Go to previous messageGo to next message
>> The CSS code is:
>> Text:disabled {
The reason is that the :disabled state is missing from most widgets,
including Text. As a result, *:disabled works, but Text:disabled
doesn't. However, this is worth a bug.
Ralf
Re: disabled/read-only Text theming [message #122318 is a reply to message #122264] Mon, 23 February 2009 11:18 Go to previous messageGo to next message
Thanks Ralf!
I'll file the bug.
-Jim
Re: disabled/read-only Text theming [message #122327 is a reply to message #122318] Mon, 23 February 2009 11:31 Go to previous messageGo to next message
Hi Jim,
Jim Tilley wrote:
> Thanks Ralf!
> I'll file the bug.
just noticed that the :disabled bug exists already:
257548: [Theming] Add disabled state for themeable widgets
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257548
Ralf
Re: disabled/read-only Text theming [message #122507 is a reply to message #122327] Tue, 24 February 2009 14:18 Go to previous messageGo to next message
Thanks Ralf,
Would the Text read-only state also be fixed under bug 257548 or would you
like me to open a separate bug?
-Jim
Re: disabled/read-only Text theming [message #122536 is a reply to message #122507] Tue, 24 February 2009 15:20 Go to previous message
Hi Jim,
> you like me to open a separate bug?
No, that's a different issue and should be reported in a bug of its own.
Thanks, Ralf
Previous Topic:parent.qx.ui is null error in IE
Next Topic:Mobile phones support (Symbian)
Current Time: Sat Jul 19 02:16:37 EDT 2025
Powered by FUDForum. Page generated in 0.04954 seconds
