Home » Modeling » EMF » [EMF] [CDO] ResourceSet, EPackage registry question
[EMF] [CDO] ResourceSet, EPackage registry question [message #1222042] Thu, 19 December 2013 09:11 Go to next message
Is the following statement true?
In case of an XMIResource, A ResourceSet loaded with EPackage A with
EClass B in it's EPackage registy will load resources and set a loaded
EObject's eClass to the EClass instance (of B) as defined by EPackage A?
The reason I ask is that Edapt makes use of this assumption and won't
work if resources are not loaded with a certain instance of an EPackage
(And it's EClass's etc..).
With CDO, when I load a resource it's not going to use the EPackage
instance which was set in the resource set, but the EPackage instance
provided by CDO it seems?
Rgds Christophe
Re: [EMF] [CDO] ResourceSet, EPackage registry question [message #1222403 is a reply to message #1222042] Fri, 20 December 2013 05:26 Go to previous messageGo to next message
OK no response sofar, let me try to rephrase my horrible initial question:
Scenario 1:
Load a XMI Resource with a ResourceSet, first register the EPackage in
the registry of the ResourceSet.
uri = new URI("file://project/model.xmi")
set = ResourceSetImpl()
set.getPackageRegistry().put(nsURI, p);
set.getResource(uri);
The returned EObject's have EClass instances from the EPackage
registered in the ResourceSet.
Scenario 2:
Load a CDO Resource with a Resourceset, first register the Epackage in
uri = new URI("cdo.net4j.tcp://host:port/repo_source/model")
The returned EObjects have EClass instances from a new EPackage instance
(Produced I guess from the transfer CDO Package Registry on the server,
*I assume*).
On the 2nd scenario this breaks the Edapt code has it expects the eCLass
from an EObject to conform the EPackage instance registered in the
ResourceSet (Which is apparently not used). I am looking for a way to
fix Edapt to work with CDO Resources with a different EPackage instance.
TIA Christophe
On 19-12-13 15:11, Christophe Bouhier wrote:
> Rgds Christophe
Re: [EMF] [CDO] ResourceSet, EPackage registry question [message #1222415 is a reply to message #1222403] Fri, 20 December 2013 05:51 Go to previous messageGo to next message
Looking at the code:
In EObjectInputStream for an EMF Resource, get the EPackage from the
resourceset.
protected EPackageData readEPackage() throws IOException
int id = readCompressedInt();
if (internalEPackageDataList.size() <= id)
EPackageData ePackageData = new EPackageData();
String nsURI = readSegmentedString();
URI uri = readURI();
if (resourceSet != null)
ePackageData.ePackage =
resourceSet.getPackageRegistry().getEPackage(nsURI);
if (ePackageData.ePackage == null)
(EPackage)resourceSet.getEObject(uri, true);
I am looking for the equivalent in CDO, but with dynamic loading
concept, I guess this can not be similar, correct?
Thanks Christophe
On 20-12-13 11:26, Christophe Bouhier wrote:
> Scenario 1:
> Scenario 2:
> *I assume*).
> TIA Christophe
>> Hi,
>> Rgds Christophe
Re: [EMF] [CDO] ResourceSet, EPackage registry question [message #1222458 is a reply to message #1222403] Fri, 20 December 2013 08:25 Go to previous messageGo to next message
Hi Christoph,
When there are already instances of that EClass in the repository then the related EPackage is also in the repo and when
a client session connects it knows about that. Later when that EPackage is needed (i.e. package descriptor resolves)
it's either wired from the global registry or loaded from the repo.
More comments below...
Am 20.12.2013 11:26, schrieb Christophe Bouhier:
> Scenario 1:
> Load a XMI Resource with a ResourceSet, first register the EPackage in the registry of the ResourceSet.
> The returned EObject's have EClass instances from the EPackage registered in the ResourceSet.
> Scenario 2:
> Load a CDO Resource with a Resourceset, first register the Epackage in the registry of the ResourceSet
I think this can be dangerous if p is a dynamic (i.e. not a singleton) EPackage.
Cheers
/Eike
http://www.esc-net.de
> The returned EObjects have EClass instances from a new EPackage instance (Produced I guess from the transfer CDO
> Package Registry on the server, *I assume*).
> On the 2nd scenario this breaks the Edapt code has it expects the eCLass from an EObject to conform the EPackage
> instance registered in the ResourceSet (Which is apparently not used). I am looking for a way to fix Edapt to work
> TIA Christophe
>> Hi,
>> Rgds Christophe
Re: [EMF] [CDO] ResourceSet, EPackage registry question [message #1223481 is a reply to message #1222458] Mon, 23 December 2013 09:23 Go to previous messageGo to next message
On 20-12-13 14:25, Eike Stepper wrote:
> Hi Christoph,
> the related EPackage is also in the repo and when a client session
> package descriptor resolves) it's either wired from the global registry
Thanks Eike. Can you please explain how it gets in the global registry?
Is it cached there, after the first time load from the Repository?
Thanks.
>> Hi,
>> question:
>> Scenario 1:
>> Scenario 2:
> EPackage.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> instance (Produced I guess from the transfer CDO Package Registry on
>> eCLass from an EObject to conform the EPackage instance registered in
>> to fix Edapt to work with CDO Resources with a different EPackage
>> instance.
>> TIA Christophe
>>> Hi,
>>> EPackage A?
>>> Rgds Christophe
Re: [EMF] [CDO] ResourceSet, EPackage registry question [message #1226982 is a reply to message #1223481] Fri, 03 January 2014 03:05 Go to previous messageGo to next message
Am 23.12.2013 15:23, schrieb Christophe Bouhier:
>> Hi Christoph,
Generated packages get into the global registry via their plugin.xml markup. CDO is not involved there. But CDO looks up
nsURIs there. Look at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(PackageLoader, boolean).
Cheers
/Eike
> Thanks.
>>> Hi,
>>> question:
>>> Scenario 1:
>>> Scenario 2:
>> EPackage.
>> Cheers
>> /Eike
>>> instance.
>>> TIA Christophe
>>>> Hi,
>>>> EPackage A?
>>>> Rgds Christophe
Re: [EMF] [CDO] ResourceSet, EPackage registry question [message #1226983 is a reply to message #1226982] Fri, 03 January 2014 03:07 Go to previous message
And you can create a CDOPackageRegistryPopulator to lazily mirror any EPackage.Registry content into a CDOPackageRegistry.
Cheers
/Eike
Am 03.01.2014 09:05, schrieb Eike Stepper:
>>> Hi Christoph,
> up nsURIs there. Look at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(PackageLoader, boolean).
> Cheers
> /Eike
>> Thanks.
>>>> Hi,
>>>> question:
>>>> Scenario 1:
>>>> Scenario 2:
>>> EPackage.
>>> Cheers
>>> /Eike
>>>> instance.
>>>> TIA Christophe
>>>>> Hi,
>>>>> EPackage A?
>>>>> Rgds Christophe
Previous Topic:[CDO] Minor patches for 4.3
Next Topic:[CDO] Connection Aware URI, how to use it in a ResourceSet
Current Time: Fri Jul 25 06:58:15 EDT 2025
Powered by FUDForum. Page generated in 0.08233 seconds
