Home » Modeling » EMF » XML output unformatted with ecore:mixed
XML output unformatted with ecore:mixed [message #387047] Fri, 13 August 2004 16:31 Go to next message
I took the library.xsd example and added ecore:mixed="true" in ordet to
allow XML comments to be preserved.
The output of an instance document comes out flat on one line.
Here is the xsd I used.
<xsd:schema targetNamespace="http://www.example.eclipse.org/Library"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:lib="http://www.example.eclipse.org/Library"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:complexType name="Book" ecore:mixed="true">
<xsd:sequence>
<xsd:element name="title" type="xsd:string"/>
<xsd:element name="pages" type="xsd:int"/>
<xsd:element name="category" type="lib:BookCategory"/>
<xsd:element name="author" type="xsd:anyURI"
ecore:reference="lib:Writer" ecore:opposite="books"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Writer" ecore:mixed="true">
<xsd:sequence>
<xsd:element name="name" type="xsd:string"/>
<xsd:element maxOccurs="unbounded" minOccurs="0" name="books"
type="xsd:anyURI" ecore:reference="lib:Book"
ecore:opposite="author"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Library" ecore:mixed="true">
<xsd:sequence>
name="writers" type="lib:Writer"/>
name="books" type="lib:Book"/>
</xsd:sequence>
</xsd:complexType>
<xsd:simpleType name="BookCategory">
<xsd:restriction base="xsd:NCName">
<xsd:enumeration value="Mystery"/>
<xsd:enumeration value="ScienceFiction"/>
<xsd:enumeration value="Biography"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:schema>
Re: XML output unformatted with ecore:mixed [message #387056 is a reply to message #387047] Mon, 16 August 2004 08:06 Go to previous messageGo to next message
Mark,
Once you say it's mixed, you are responsible for the formatting. So if
you read in an instance, the instance formatting will be preserved, but
if you create an instance from scratch, you have to create the
formatting from scratch too.
> to allow XML comments to be preserved.
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:schema>
Re: XML output unformatted with ecore:mixed [message #398423 is a reply to message #387056] Wed, 08 February 2006 10:03 Go to previous messageGo to next message
Hi, I am new at EMF, but have successfully created a model and am
currently reading data from it.
I am trying to use the ecore namespace as default when generation a
model from a schema. Heres the story.
During reading I found that the xsd :
<xs:element name="resulttype">
<xs:complexType mixed="true" />
</xs:element>
Does not allow me to access CDATA like banana
<resulttype>banana</resulttype>
in the generated code.
Adding the ecore namespace to the schema node
and putting mixed in this namespace fixed the problem
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<xs:complexType ecore:mixed="true" />
</xs:element>
now the generated code has the method getMixed() on which I can use the
getValue(0) to get CDATA contents, which is fine.
Back to the question : can I get the emf codegenerator to generate
getMixed as default or define the ecore namespace to be used as default
Regards, Jesper
Ed Merks wrote:
> Mark,
>> <?xml version="1.0" encoding="UTF-8"?>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:schema>
Re: XML output unformatted with ecore:mixed [message #398425 is a reply to message #398423] Wed, 08 February 2006 11:14 Go to previous messageGo to next message
Jesper,
This was fixed by https://bugs.eclipse.org/bugs/show_bug.cgi?id=86118.
> </xs:element>
> </xs:element>
> the getValue(0) to get CDATA contents, which is fine.
> Regards, Jesper
> Ed Merks wrote:
>> Mark,
>> if you read in an instance, the instance formatting will be
>> preserved, but if you create an instance from scratch, you have to
>> create the formatting from scratch too.
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:schema>
Re: XML output unformatted with ecore:mixed [message #1221683 is a reply to message #387047] Wed, 18 December 2013 03:26 Go to previous messageGo to next message
Is it possible to allow comments for a complex type and to keep formatting working?
Re: XML output unformatted with ecore:mixed [message #1222158 is a reply to message #1221683] Thu, 19 December 2013 14:48 Go to previous messageGo to next message
Denis,
No, once you have mixed content, you have to control the format.
On 18/12/2013 9:26 AM, Denis Nikiforov wrote:
> Hi
> formatting working?
Re: XML output unformatted with ecore:mixed [message #1222303 is a reply to message #387047] Fri, 20 December 2013 00:17 Go to previous message
Thanks for reply!
For newbies like me: JDK 1.6 has a good XML support, and it's very easy to format XML even without 3rd party libraries. There are a lot of examples in a web.
Previous Topic:[EMF] [CDO] [Compare] [Bug?] Compare will not work with certan implementation of EStore
Next Topic:models referencing across editors
Current Time: Thu Jun 26 00:13:57 EDT 2025
Powered by FUDForum. Page generated in 0.09273 seconds
