Home » Archived » Eclipse Communications Framework (ECF) » Can't Connect to ECF Server
Can't Connect to ECF Server [message #1221687] Wed, 18 December 2013 03:37 Go to next message
I recently found out about Eclipse Communication Framework (ECF) but unfortunately, I can't use it. I can't join the session when I press the "Connect to ECF Generic Collaboration Group" button.
I also tried the "eclipse.exe -console -application org.eclipse.ecf.provider.AppGenericServer 1234" but received error instead (Application "org.eclipse.ecf.provider.AppGenericServer" could not be found in the registry.).
How do I solve this problem in order to connect to the server?
Btw, I'm using Eclipse Kepler.
Thanks in advance.
Regards.
Re: Can't Connect to ECF Server [message #1221831 is a reply to message #1221687] Wed, 18 December 2013 09:02 Go to previous messageGo to next message
Hi Liana,
AFAIK there is no public server running anymore. So unless you run your
own server, you won't be able to connect.
M.
Re: Can't Connect to ECF Server [message #1221956 is a reply to message #1221687] Wed, 18 December 2013 15:47 Go to previous messageGo to next message
Hi Liana
Liana Yusri wrote on Wed, 18 December 2013 03:37
Thanks in advance.
Regards.
Markus is correct...there is no longer a public collab/chat server for ECF. There are two reasons for this:
1) We don't currently have the admin support to be able to admin multiple public servers;
2) There are now quite a large number of different kinds of ECF server applications (e.g. server for collab app, server for remote services, event admin, alternative providers...e.g. r-osgi, jms, etc), and so problem 1 is quite a difficult one for us...i.e. we are forced to choose which servers to run...and for how long.
However, you can run an ECF generic server by running this command
eclipse.exe -console -application org.eclipse.ecf.server.generic.Server
This should produce console output like this:
osgi>
Generic server started with id=ecftcp://localhost:3282/server
You may then connect to this server within Eclipse's ECF Collaboration view with this ID: ecftcp://localhost:3282/server
Client connects should result in the server console output like this:
Client Connect Addr=/127.0.0.1:58050;ID=StringID[p8C7XCJ9HmHszEvrvaM8ftAL7Sg=];G
roup=/server
Note, that for thie org.eclipse.ecf.server.generic.Server application that you can specify a configURL to change the hostname/port/path of the server:
eclipse.exe -console -application org.eclipse.ecf.server.generic.Server -serverName ecftcp://localhost:3284/myserver
Note also that the org.eclipse.ecf.server.generic.Server app can be started/debuged from within Eclipse, and the source for the application is in this class: org.eclipse.ecf.server.generic.app.GenericServerApplication
Which is in this project/bundle: org.eclipse.ecf.server.generic. This project is in the ECF git repo here:
http://git.eclipse.org/c/ecf/org.eclipse.ecf.git/tree/server-side/bundles/org.eclipse.ecf.server.generic
Note also that we are doing some feature restructuring right now...see this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=409787
specifically around better supporting server/non-Eclipse uses of ECF.
Re: Can't Connect to ECF Server [message #1221970 is a reply to message #1221956] Wed, 18 December 2013 20:59 Go to previous message
Thank you for replying.
I followed your instructions however when Eclipse started, it is not responding and pop out a message.
As attached is the screenshot of the message.
Liana
Previous Topic:Unable to pass credentials through URL to an HTTP Server
Next Topic:How-to use css to customise ECF views ?
Current Time: Fri Oct 31 07:40:26 EDT 2025
Powered by FUDForum. Page generated in 0.04766 seconds
