Home » Eclipse Projects » NatTable » how to remove configuration(Need to add/remove "Select All" checkbox from column header)
how to remove configuration [message #1221768] Wed, 18 December 2013 06:45 Go to next message
I have a wizard in which I allow user to define a filter criteria and then display results on the next page in a NatTable. Since the resultsets are expected to be large I render the checkbox for select all in a column header once all the data is loaded. I do so using the addConfiguration method on the NatTable.
So far so good.
Now if user goes back to the previous page, changes the criteria and comes to the results page, I want to remove/hide the select all checkbox till all results are loaded but there is no provision to remove configurations.
Can you please suggest a work around for this or an alternate approach to rendering the select all checkbox itself? Would disposing and re-rendering the table be a good option?
Thanks and regards,
Pradyumna
Re: how to remove configuration [message #1221784 is a reply to message #1221768] Wed, 18 December 2013 07:27 Go to previous messageGo to next message
Of which checkbox are you talking about?
It is not possible to remove a configuration because the configurations will only be loaded and applied initially. But you are able to remove the configurations itself from the ConfigRegistry if you have the reference to it. Use ConfigRegistry.unregisterConfigAttribute() to achieve that.
Re: how to remove configuration [message #1221794 is a reply to message #1221784] Wed, 18 December 2013 07:54 Go to previous messageGo to next message
Hello Dirk,
I am referring to the checkbox that is rendered in the column header that will facilitate selecting all records in a single click.
As always, your suggestion worked!
Thanks and regards,
Pradyumna
[Updated on: Wed, 18 December 2013 08:00] by Moderator
Re: how to remove configuration [message #1221798 is a reply to message #1221794] Wed, 18 December 2013 08:02 Go to previous message
I guess you are talking about the one that is showed as an example in TreeGridWithCheckBoxFieldsExample. Otherwise I don't know what you are talking about.
Usually unregistering should help. Not sure if you need to do a re-rendering to visualize the changes. But it should be possible to only refresh the cell itself instead of performing a whole NatTable refresh.
Previous Topic:next release
Next Topic:Refreshing NatTable
Current Time: Thu Sep 18 08:53:25 EDT 2025
Powered by FUDForum. Page generated in 0.03832 seconds
