Home » Eclipse Projects » Eclipse 4 » Reinjection on object removal
Reinjection on object removal [message #1221216] Tue, 17 December 2013 01:11 Go to next message
Hello, i recently started to use reinjection and noticed this weird behavior:
when i remove a dependency from a context that is injected into, say, a method - the system detects the "change" in the dependency and tries to reinject it and call the dependant method.
However, the object is already removed, and if i didn't mark the method or the parameter as @Optional - the system cannot find the object to inject and kind of breaks itself.
Is this intended design or maybe an oversight?
Example code:
public class TestPart {
    class A {
    @Inject
    IEclipseContext ctx;
    int i;
    @Inject
    public TestPart(IEclipseContext ctx) {
        ctx.set(A.class, new A()); // 1
    @Inject
    private void reinjectMe(A a) {
        System.out.println("Injected instance of A: " + a);
    @PostConstruct
    public void createUI(Composite parent) {
        Button btn = new Button(parent, SWT.PUSH);
        btn.setText("test");
        btn.addSelectionListener(new SelectionAdapter() {
            public void widgetSelected(SelectionEvent e) {
                if(i==0) {
                    ctx.set(A.class, new A()); // 2
                    ++i;
                } else {
                    ctx.remove(A.class); // 3
Output:
Injected instance of A: TestPart$A@1d51055 // 1
Injected instance of A: TestPart$A@b6377c // 2
// 3
!ENTRY org.eclipse.e4.core 4 0 2013-12-17 09:40:15.378
!MESSAGE Unable to process "TestPart#reinjectMe()": no actual value was found for the argument "A".
Re: Reinjection on object removal [message #1221406 is a reply to message #1221216] Tue, 17 December 2013 11:10 Go to previous messageGo to next message
You have to allow the value to be optional so that the system can inject
NULL.
Tom
> behavior:
> Example code:
> class A {
> @Inject
> int i;
> @Inject
> @Inject
> @PostConstruct
> @Override
> if(i==0) {
> ++i;
> } else {
> }Output:Injected instance of A: TestPart$A@1d51055 // 1
> // 3
Re: Reinjection on object removal [message #1221617 is a reply to message #1221406] Tue, 17 December 2013 23:24 Go to previous messageGo to next message
Yes, i know i can mark it as @Optional.
But what i'm asking is this: is it right for the system to try to reinject an object that was just removed, possibly by the system itself, and then report an error?
It looks as if it "breaks itself". Maybe it shouldn't try reinjecting removed objects, possibly those that aren't marked @Optional? Or does this feature have its use?
[Updated on: Tue, 17 December 2013 23:27] by Moderator
Re: Reinjection on object removal [message #1221786 is a reply to message #1221617] Wed, 18 December 2013 07:34 Go to previous message
IMHO it is.
Tom
> this has its use?
Previous Topic:Active Perspective Core Expression
Next Topic:Overriding Ctrl-W behavior
Current Time: Sat Jul 26 19:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.04868 seconds
