Home » Newcomers » Newcomers » Where can I find DLLs swt-win32-3139 ?
Where can I find DLLs swt-win32-3139 ? [message #122045] Tue, 06 December 2005 03:54 Go to next message
I'm a newbie on Eclipse and I'm trying to make the HelloWorld2.java
example from org.eclipse.swt.examples, running as a "Java Application"
Eclipse Version: 3.1.1
Build id: M20050929-0840
I'm on WinXP SP2 so I've downloaded the swt-3.1-win32-win32-x86.zip file
from
http://www.eclipse.org/downloads/download.php?file=/eclipse/ downloads/drops/R-3.1.1-200509290840/swt-3.1.1-win32-win32-x 86.zip
and installed the included DLLs swt-awt-win32-3138.dll,
swt-gdip-win32-3138.dll and swt-win32-3138.dll to C:\WINNT\SYSTEM32
Eclipse give me this error when trying to run the app :
"Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-win32-3139 in java.library.path"
Where can I download the 3139 DLLs ?
Fred
Re: Where can I find DLLs swt-win32-3139 ? [message #122150 is a reply to message #122045] Tue, 06 December 2005 13:37 Go to previous messageGo to next message
> from
You did not need to copy those files anywhere. I downloaded the
link you gave, and it does include the "-3139.dll" files as appropriate.
See this tutorial for how to import this .zip into Eclipse. You want
to use the "Existing Projects Into Workspace" import wizard:
http://www.eclipse.org/swt/eclipse.php
Hope this helps!
-Billy
Re: Where can I find DLLs swt-win32-3139 ? [message #122176 is a reply to message #122150] Tue, 06 December 2005 16:47 Go to previous messageGo to next message
Yes it worked thanks !
Re: Where can I find DLLs swt-win32-3139 ? [message #142306 is a reply to message #122045] Wed, 08 March 2006 19:26 Go to previous message
Had the same problem today. Just download the latest version of SWT from
http://www.eclipse.org/swt/ and in the zip you'll find the needed DLL. You
just have to copy it to you system directory defined in PATH environment
variable. For Example C:\Windows\System32.
Hope I could help.
Previous Topic:Error with Plug in Tutorial
Next Topic:Getting workspace from within a program
Current Time: Tue Nov 04 00:32:35 EST 2025
Powered by FUDForum. Page generated in 0.09688 seconds
