Home » Archived » BIRT » Setting up BIRT report viewer 4.2.2.
Setting up BIRT report viewer 4.2.2. [message #1220098] Mon, 09 December 2013 11:21 Go to next message
Can someone please tell me where I need to place my JDBC driver for the BIRT report view version 4.2.2? I had previously been using version 2.6.2 and I noticed the directory structure is different on the server and I don't know where to stick the JDBC driver.
Re: Setting up BIRT report viewer 4.2.2. [message #1220599 is a reply to message #1220098] Thu, 12 December 2013 11:40 Go to previous messageGo to next message
I think you should be putting them into the lib folder.
Re: Setting up BIRT report viewer 4.2.2. [message #1221069 is a reply to message #1220599] Mon, 16 December 2013 15:17 Go to previous messageGo to next message
Is there any documentation on how to setup the BIRT Report Viewer including where to stick the jar files?
Re: Setting up BIRT report viewer 4.2.2. [message #1221335 is a reply to message #1221069] Tue, 17 December 2013 08:05 Go to previous messageGo to next message
Go to the following url http://www.eclipse.org/birt/phoenix/build/
Re: Setting up BIRT report viewer 4.2.2. [message #1221387 is a reply to message #1221335] Tue, 17 December 2013 10:22 Go to previous messageGo to next message
Thank you. I installed the BIRT viewer and now when I try to run one of my reports I get an error. The error says:
+ error.CannotStartupOSGIPlatform
What does this mean? Did I install the report viewer wrong? All I did was install the BIRT.war file that I found when I extracted the contents of the runtime I downloaded.
Re: Setting up BIRT report viewer 4.2.2. [message #1221399 is a reply to message #1221387] Tue, 17 December 2013 10:45 Go to previous messageGo to next message
on which server you installed it?
Re: Setting up BIRT report viewer 4.2.2. [message #1221520 is a reply to message #1221399] Tue, 17 December 2013 16:56 Go to previous messageGo to next message
The BIRT report viewer is installed on IBM i5 running on Websphere Application Server Express v8.5
Re: Setting up BIRT report viewer 4.2.2. [message #1221753 is a reply to message #1221520] Wed, 18 December 2013 06:10 Go to previous message
Sorry I cannot give you any solution since I use apache tomcat.
Previous Topic:Need help on charting for pdf using API approach
Next Topic:org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
Current Time: Sat Jul 19 03:07:14 EDT 2025
Powered by FUDForum. Page generated in 0.25945 seconds
