Home » Modeling » OCL » OCL standard library error : no viable alternative at input 'validating'
OCL standard library error : no viable alternative at input 'validating' [message #1220510] Thu, 12 December 2013 04:23 Go to next message
I have cloned the ocl repository and when i open "OCL-2.5.oclstdlib" it contains few error at "validating" keyword. The error text is "no viable alternative at input 'validating'". Can you please explain why it is so? and how i can solve this?
if i remove "validating" keywords then there is no error.
index.php/fa/17012/0/
I am also trying to extend OCL library and i have created new file. but it shows me error at import statement "No 'OclAny' type in the OCL Standard Library"
import 'OCL-2.5.oclstdlib';
library ocl : ocl = 'http://www.eclipse.org/ocl/3.1.0/OCL.oclstdlib'{
type Integer : PrimitiveType conformsTo Real {
operation test() : Integer =>'org.eclipse.ocl.examples.library.numeric.TestNumericOperation';
thanks!
[Updated on: Thu, 12 December 2013 04:45] by Moderator
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220522 is a reply to message #1220510] Thu, 12 December 2013 05:30 Go to previous messageGo to next message
You are not using consistent tooling.
The 'validating' keyword was introduced by
commit 3c715ddb11d8f316ec9e8748423204d85f1ca594 on 2012-11-28 15:54:04
to identify non-strict library functions that could turn invalid into
non-invalid.
You must use an OCLstdlib editor later than that. e.g. Kepler.
Ed Willink
> thannks!
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220538 is a reply to message #1220522] Thu, 12 December 2013 07:22 Go to previous messageGo to next message
I am using kepler. I am also trying to do updates using "http://download.eclipse.org/releases/kepler" and it says no update found...
index.php/fa/17013/0/
Can you please explain which plugin needs to updated and from where(URL)?
thanks for the help!
  • Attachment: kepler.png
    (Size: 79.27KB, Downloaded 1581 times)
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220556 is a reply to message #1220522] Thu, 12 December 2013 09:20 Go to previous messageGo to next message
HI
Ah! But the support for validating iterations was added by
commit 7f7a2b6b6533e6901b54b90a76dfc8ee514f04ad on 2013-09-05 12:39:55
so you need to install the Luna M2 or M3 milestones (or M4 Monday).
THese can be installed on Kepler.
Ed Willink
On 12/12/2013 10:30, Ed Willink wrote:
> Hi
> non-invalid.
> Regards
> Ed Willink
>> thannks!
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220581 is a reply to message #1220556] Thu, 12 December 2013 10:52 Go to previous messageGo to next message
I have updated kepler to Luna and have restarted Eclipse and now it does not load.... it gets stuck in splash screen.
I have also tried to downlaod Luna and install modeling components. Same problem, After installing, it does not get loaded. It is stuck in splash screen.....
[Updated on: Thu, 12 December 2013 10:52] by Moderator
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220620 is a reply to message #1220581] Thu, 12 December 2013 13:07 Go to previous messageGo to next message
You give no details as to what you call 'Luna'.
There was a problem in M3 with Ecore Tools pulling in Sirius that had a
dependency on self causing a stack overflow and grey screen.
Either skip Ecore Tools/Sirius of get a post M3.
Ed Willink
> does not load.... it get stuck in splash screen.
> splash screen.....
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220714 is a reply to message #1220620] Fri, 13 December 2013 04:11 Go to previous messageGo to next message
I have downloaded "eclipse-standard-luna-M3-win32.zip" and then i have tried to use luna releases site to install modeling components.
This time i have skipped sirius related options in install dialog but after installation of modeling components it is again stuck at splash screen.
should i download any other version?
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220734 is a reply to message #1220714] Fri, 13 December 2013 05:21 Go to previous messageGo to next message
You may have skipped explicit Sirius components, but you may get
implicit ones. Check the plugins folder of you installation and/or
Help->Help About Eclipse SDK->Installation->Plugins to confirm that you
do not have Sirius installed implicitly.
The relevant Bugzilla
is:https://bugs.eclipse.org/bugs/show_bug.cgi?id=421706
Another possible hazard is two versions of com.google.guava.
I'm using Luna M3 successfully with
GEF+EMF+UML+MWE+Xtend+Xtext+OCL+QVTo+QVTd+GIT+SVN and sometimes +Papyrus.
Ed Willink
> screen.
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220928 is a reply to message #1220734] Mon, 16 December 2013 03:34 Go to previous messageGo to next message
it is fixed, now i am able to run luna and "validating" keyword is no more problematic. but still when i am writing the extension for the OCL library then editor shows very strange error "No 'OclAny' type in the OCL Standard Library" at import statement
library ocl : ocl = 'http://www.eclipse.org/ocl/3.1.0/OCL.oclstdlib' {
do you know why it is the case?
cheers,
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220951 is a reply to message #1220928] Mon, 16 December 2013 05:30 Go to previous messageGo to next message
If you want to extend the existing library, do not respecify the nsURI.
The diagnostic is that your new library replaces the imported one but
has (at least) one deficiency with respect to the minimum requirements
on a library. e.g. there must be an OclAny type.
Ed Willink
On 16/12/2013 08:34, ModelGeek Mising name wrote:
> cheers,
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220952 is a reply to message #1220951] Mon, 16 December 2013 05:44 Go to previous messageGo to next message
I have removed nsURI and now editor does not show any error. I have changed the GenerateOCLstdlibModel.mwe2 to point to my newly extened oclstdlib file but when i run GenerateOCLstdlibModel.mwe2 script then i get following error
5677 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow GenerateOCLstdlibModel:
[ERROR]: OCLstdlib parse failure
1: The first library must have a URI(Element: -UNKNOWN-; Reported by: GenerateOCLstdlibXtend)
java.lang.RuntimeException: Problems running workflow GenerateOCLstdlibModel:
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: java.lang.RuntimeException:
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.handleIssues(Mwe2Bridge.java:56)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:48)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
... 4 more
The code for GenerateOCLstdlibModel.mwe2 script is
Workflow {
bean = ResourceSetImpl : resourceSet {}
bean = StandaloneSetup { resourceSet = resourceSet
platformUri = ".."
component = GenerateOCLstdlibXtend { resourceSet = resourceSet
projectName = "${sourceName}"
//modelFile = "model/OCL-2.5.oclstdlib"
modelFile = "model/extendedOCL.oclstdlib"
uri = "http://www.eclipse.org/ocl/3.1.0/OCL.oclstdlib"
javaFolder = "/${targetName}/emf-gen"
javaPackageName = "${targetName}.model"
javaClassName = "OCLstdlib"
component = Model2tablesGenerator { resourceSet = resourceSet
genModelFile = "/${sourceName}/model/oclstdlib.genmodel"
genOCLstdlib = true
Code for extendedOCL.oclstdlib is
library ocl {
Do you any idea why the above mention execption occurs?
thanks!
cheers
Re: OCL standard library error : no viable alternative at input 'validating' [message #1220955 is a reply to message #1220952] Mon, 16 December 2013 05:55 Go to previous messageGo to next message
I've not tried generating a custom library, so you're on your own.
However you should look at the tests for extending the library dymamically,
e.g.
org.eclipse.ocl.examples.test.xtext.ImportTests.testImport_CompleteOCL_custom_OCLstdlib
Ed Willink
> get following error
> running workflow GenerateOCLstdlibModel: [ERROR]: OCLstdlib parse failure
> at
> at
> at
> at
> at
> Caused by: java.lang.RuntimeException: [ERROR]: OCLstdlib parse failure
> at
> at
> at
> at
> at
> ... 4 more
> Workflow {
> platformUri = ".."
> genOCLstdlib = true
> Code for extendedOCL.oclstdlib is import 'OCL-2.5.oclstdlib';
> library ocl {
> thanks!
> cheers
Re: OCL standard library error : no viable alternative at input 'validating' [message #1221349 is a reply to message #1220955] Tue, 17 December 2013 08:41 Go to previous message
I have looked at test case. It is to load library dynamically. But my problem is code generation for customized library and i am using GenerateOCLstdlibModel.mwe2.
If i just GenerateOCLstdlibModel.mwe2 to point to customized library file instead of default(OCL-2.5.oclstdlib) and execute GenerateOCLstdlibModel.mwe2 file then i get the following error
367 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Unresolved compilation problem:
orphans cannot be resolved
java.lang.Error: Unresolved compilation problem:
at org.eclipse.ocl.examples.pivot.model.OCLstdlib$Contents.installLambdaTypes(OCLstdlib.java:236)
at org.eclipse.ocl.examples.pivot.model.OCLstdlib$Contents.create(OCLstdlib.java:178)
at org.eclipse.ocl.examples.pivot.model.OCLstdlib.getDefault(OCLstdlib.java:82)
at org.eclipse.ocl.examples.pivot.model.OCLstdlib$Loader.getResource(OCLstdlib.java:137)
at org.eclipse.ocl.examples.pivot.manager.MetaModelManager.loadDefaultLibrary(MetaModelManager.java:2595)
at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getLibraryType(PivotStandardLibrary.java:169)
at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getRequiredLibraryType(PivotStandardLibrary.java:283)
at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.resolveRequiredSimpleType(PivotStandardLibrary.java:388)
at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getOclElementType(PivotStandardLibrary.java:201)
at org.eclipse.ocl.examples.xtext.base.cs2as.BaseCSPreOrderVisitor$ClassSupersContinuation.execute(BaseCSPreOrderVisitor.java:98)
at org.eclipse.ocl.examples.xtext.base.cs2as.CS2PivotConversion.progressContinuations(CS2PivotConversion.java:819)
at org.eclipse.ocl.examples.xtext.base.cs2as.CS2PivotConversion.update(CS2PivotConversion.java:1312)
at org.eclipse.ocl.examples.xtext.base.cs2as.CS2Pivot.update(CS2Pivot.java:519)
at org.eclipse.ocl.examples.xtext.oclstdlib.cs2as.OCLstdlibCS2Pivot.update(OCLstdlibCS2Pivot.java:67)
at org.eclipse.ocl.examples.xtext.base.utilities.CS2PivotResourceAdapter.refreshPivotMappings(CS2PivotResourceAdapter.java:107)
at org.eclipse.ocl.examples.xtext.base.utilities.CS2PivotLinker.afterModelLinked(CS2PivotLinker.java:75)
at org.eclipse.xtext.linking.impl.AbstractCleaningLinker.linkModel(AbstractCleaningLinker.java:49)
at org.eclipse.xtext.resource.XtextResource.doLinking(XtextResource.java:294)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLinking(LazyLinkingResource.java:88)
at org.eclipse.ocl.examples.xtext.essentialocl.utilities.EssentialOCLCSResource.doLinking(EssentialOCLCSResource.java:169)
at org.eclipse.xtext.resource.XtextResource.updateInternalState(XtextResource.java:262)
at org.eclipse.xtext.resource.XtextResource.updateInternalState(XtextResource.java:252)
at org.eclipse.xtext.resource.XtextResource.doLoad(XtextResource.java:165)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLoad(LazyLinkingResource.java:81)
at org.eclipse.ocl.examples.xtext.essentialocl.utilities.EssentialOCLCSResource.doLoad(EssentialOCLCSResource.java:177)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.ocl.examples.build.xtend.GenerateOCLstdlib.invokeInternal(GenerateOCLstdlib.java:77)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
It seems a bug in library's import functionality as if would have imported properly then it should have worked fine as it works fine with defaul library (OCL-2.5.oclstdlib).
May be you could identify the bug and register a bug report so this can resolved for future.
Previous Topic:Checking if the ecore model is valid in code
Next Topic:OCL Set Function to Java Code
Current Time: Sun Jul 27 14:26:55 EDT 2025
Powered by FUDForum. Page generated in 0.06776 seconds
