Home » Archived » BIRT » Deploying birt in tomcat(the test report is not displayed)
Deploying birt in tomcat [message #1220513] Thu, 12 December 2013 04:32 Go to next message
Hey,
I'm beginer with birt using.
I followed the tutorial on how to install birt viewer in tomcat at http://www.eclipse.org/birt/phoenix/...iewerSetup.php. I have installed the folder "WebViewerExample" in "webapps" of the server tomcat and rename it "birt-viewer" and it well appear in the server tree, I also have the page which confirm that I have installed the viewer.
The problem is that when I want to test the "View example" link to know if the viewer is properly installed I have the 404 error saying that the ressource is not avaible.
Here the ressource might be the report "test.rptdesign" which is in the folder that I have copied in the "webapps" folder.
May be you have experiment this error. Please help.
Re: Deploying birt in tomcat [message #1220559 is a reply to message #1220513] Thu, 12 December 2013 09:35 Go to previous messageGo to next message
I'm on Windows 7.
Actually, the first error before the one I exposed appeared only one time and was the following (it's in french):
type Rapport d''exception
message Erreur à l'instantiation de la classe servlet org.eclipse.birt.report.servlet.ViewerServlet
description Le serveur a rencontré une erreur interne qui l''a empêché de satisfaire la requête.
exception
javax.servlet.ServletException: Erreur à l'instantiation de la classe servlet org.eclipse.birt.report.servlet.ViewerServlet
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002)
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
cause mère
java.lang.NoClassDefFoundError: org.apache.commons.logging.LogFactory
org.apache.axis.components.logger.LogFactory.class$(LogFactory.java:45)
org.apache.axis.components.logger.LogFactory$1.run(LogFactory.java:45)
java.security.AccessController.doPrivileged(Native Method)
org.apache.axis.components.logger.LogFactory.getLogFactory(LogFactory.java:41)
org.apache.axis.components.logger.LogFactory.<clinit>(LogFactory.java:33)
org.apache.axis.transport.http.AxisServletBase.<clinit>(AxisServletBase.java:58)
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
java.lang.reflect.Constructor.newInstance(Unknown Source)
java.lang.Class.newInstance0(Unknown Source)
java.lang.Class.newInstance(Unknown Source)
I've just copy the commons-logging.1.1.1.jar into the /lib folder in tomcat. That avoid the previous error and show this other one:
message /webcontent/birt/pages/layout/FramesetFragment.jsp (line: 1, column: 5) Tag &lt;%-- non terminé
exception
org.apache.jasper.JasperException: /webcontent/birt/pages/layout/FramesetFragment.jsp (line: 1, column: 5) Tag &lt;%-- non terminé
org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:42)
org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:408)
org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:133)
org.apache.jasper.compiler.Parser.parseComment(Parser.java:615)
org.apache.jasper.compiler.Parser.parseElements(Parser.java:1425)
org.apache.jasper.compiler.Parser.parse(Parser.java:138)
org.apache.jasper.compiler.ParserController.doParse(ParserController.java:242)
org.apache.jasper.compiler.ParserController.parse(ParserController.java:102)
org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:198)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:373)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:353)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:340)
org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:646)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:357)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
org.eclipse.birt.report.presentation.aggregation.layout.FramesetFragment.service(FramesetFragment.java:98)
org.eclipse.birt.report.servlet.ViewerServlet.__doGet(ViewerServlet.java:181)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doGet(BirtSoapMessageDispatcherServlet.java:146)
javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:112)
org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
note La trace complète de la cause mère de cette erreur est disponible dans les fichiers journaux de Apache Tomcat/7.0.32.
Please help.
Re: Deploying birt in tomcat [message #1220826 is a reply to message #1220559] Fri, 13 December 2013 17:04 Go to previous messageGo to next message
Can you attach your framesetFragment.jsp page? It looks as if you might have a JSP tag that isn't ended properly. If you didn't edit the JSP page, you might just try redownloading it and trying again.
Re: Deploying birt in tomcat [message #1220957 is a reply to message #1220826] Mon, 16 December 2013 06:08 Go to previous messageGo to next message
This is the framesetFragmentpage attached. I did not edit it, but after the error message I checked and I thought there was no problem. please see by yourself.
I will also try to download it again or may be another version or the birt viewer
Re: Deploying birt in tomcat [message #1221294 is a reply to message #1220957] Tue, 17 December 2013 05:29 Go to previous messageGo to next message
It's OK now. Thanks to Michael Williams.
I've just remove the wrong tags and now it works!
Re: Deploying birt in tomcat [message #1221309 is a reply to message #1221294] Tue, 17 December 2013 06:28 Go to previous messageGo to next message
actually it works, but, the /frameset mapping does not display the report, I can display the report only with the /run mapping or the /preview mapping of Servlets of birtviewer.
May be its because of what I've remove: I've removed from the FramesetFragment.jsp the comments like:
Copyright (c) 2004 Actuate Corporation and others.
All rights reserved. This program and the accompanying materials
are made available under the terms of the Eclipse Public License v1.0
which accompanies this distribution, and is available at
http://www.eclipse.org/legal/epl-v10.html
Contributors:
Actuate Corporation - Initial implementation.
Expected java beans
Viewer root fragment
certainly, the problem is that I shoul have complete the "expected java beans" and the "viewer root fragment" and not remove it. but I don't know how!
If you can help please
Re: Deploying birt in tomcat [message #1222223 is a reply to message #1220513] Thu, 19 December 2013 18:24 Go to previous message
Try this one. When I opened in Notepad++, one of the end tags wasn't being recognized. I re-saved the file in utf-8 encoding in notepad and reopened with Notepad++ and the tag was now recognized. Let me know. Did you ever try re-downloading?
Previous Topic:BIRT runtime error
Next Topic:Crosstab hiding of columns and rows does not reflect when export to excel/pdf
Current Time: Wed Jul 23 10:46:23 EDT 2025
Powered by FUDForum. Page generated in 0.08325 seconds
