Home » Language IDEs » Java Development Tools (JDT) » relative paths in classpath
relative paths in classpath [message #122114] Wed, 26 November 2003 00:38 Go to next message
Originally posted by: fschaper.zerodegree.de
since I'm not working alone on a project and I have to expect people to have
different path's for their workspaces, I would like to specify relative
paths based on the project root for external jar's.
I ended up changing the ".classpath" file manually to a relative location
<classpathentry kind="lib" path="lib/axis.jar"/>
however this was fruitless.
Eclipse reports the jar missing at "<projectname>/lib/axis.jar".
Since I expect more people than just me trying to share their project via
CVS shipping with all the build requirements I guess there _is_ a solution
out there. I hope somebody shares his with me ...
I'm using the win32 build of eclipse (2.1.2) btw.
../regards
Florian
Re: relative paths in classpath [message #122239 is a reply to message #122114] Wed, 26 November 2003 05:31 Go to previous messageGo to next message
Have you tried using classpath variables?
Jerome
"Florian Schaper" <fschaper@zerodegree.de> wrote in message
news:bq1e6c$9i9$2@eclipse.org...
> Hello,
have
> ./regards
> Florian
Re: relative paths in classpath [message #122320 is a reply to message #122239] Wed, 26 November 2003 08:54 Go to previous message
> Jerome
Well thanx Jerome, using variables works. I defined a variable in eclipse
and could use that in the ".classpath" file
<classpathentry kind="var" path="BLK_LIBS/axis.jar"/>
So my coworkers would now only have to point the variable at the correct
folder and be done with it. However I thought there might be a variable
already set for the root of the project or whatever .. I thought seeing a
project on the web that used relative path's without the need of extra
variables in their eclipse project.
Previous Topic:How do I specify vmargs on Mac?
Next Topic:parseCompilationUnit problem with passing in true
Current Time: Tue Jul 22 19:52:38 EDT 2025
Powered by FUDForum. Page generated in 0.03702 seconds
