Re: Howto use Acceleo with a UML Profile [message #1221496 is a reply to message #1221299] |
Tue, 17 December 2013 15:42   |
Thank you for your answer
Well, actually, I don't see where to add these lines. :s
You're right, I profiled my model using the UML metamodel. So in Papyrus, my model.uml knows model.profile.uml.
But when I copy these files in Acceleo, I don't know how to "link" my model with the profile...
With a non-profiled UML model, to generate code, I add my model, create an new "Empty Generator" and choose Type value: "uml.Class". Then I get a default.mt file. Then, in the Outline, I right click my model, "Acceleo">"Select Template" and then "Acceleo">"Generate File(s)". It generates a file for each class I have in my model. [Btw, I'm not sure if it's the good way to do this...]
Now, in my profiled model, I don't have class anymore, but a stereotype (called my_class and extending Class). I'd like to do the same thing I did with Class, but with my_class.
Thanks for your help.
Marc
Edit : Problem solved ! It works !!
It was just a pb of metamodel "http://www.eclipse.org/uml2/3.0.0/UML" instead of metamodel "http://www.eclipse.org/uml2/2.0.0/UML". The pb only took place in the profiled model, that's why it didn't work. Thanks for your help Siegfried Mising name !
[Updated on: Tue, 17 December 2013 16:55] by Moderator
FUDForum. Page generated in 0.10228 seconds
