Home » Eclipse Projects » EGit / JGit » Could Not Initialize NSS
Could Not Initialize NSS [message #1220847] Sat, 14 December 2013 03:09 Go to next message
Tonight I've run into two bugs. The first one was I could not get egit to download due to a "Could Not Initialize NSS" bug.
That was fixed by adding the following line:
nssLibraryDirectory = /usr/lib/x86_64-linux-gnu
to:
/etc/java-7-openjdk/security/nss.cfg
Now I'm running into the same problem "Could Not Initialize NSS" when I try to clone a repo or perform other git related tasks such as fetch from upstream.
What can I do to continue debugging this? It really confuses me how eclipse *seems* to know about it (otherwise the downloader wouldn't have started working)
Re: Could Not Initialize NSS [message #1220868 is a reply to message #1220847] Sat, 14 December 2013 17:25 Go to previous messageGo to next message
I think this is rather a problem of your OpenJDK / NSS setup
Re: Could Not Initialize NSS [message #1220871 is a reply to message #1220868] Sat, 14 December 2013 18:31 Go to previous messageGo to next message
If that is the case:
1. What does the eclipse software download plugin utilize that is different than what the egit plugin uses (After the nss.cfg modification that works perfectly fine).
2. How can I debug this? I just need some means to start probing, see a stack trace.. anything really. For now I'm stuck Sad
I'm willing to continue looking at this, but am out of ideas as to how to go about finding the problem.
[Updated on: Sat, 14 December 2013 18:41] by Moderator
Re: Could Not Initialize NSS [message #1221411 is a reply to message #1220871] Tue, 17 December 2013 11:25 Go to previous message
You can try to follow the contributor guide [1] to debug egit, but I am pretty sure the
problem you are looking for is buried somewhere in OpenJDK and its use of the security provider,
which in your case seems to be nss. If you are cloning over ssh you are using jsch [2] which itself
probably makes use of some security APIs of the JDK. Similar things happen when you clone
over https.
[1] http://wiki.eclipse.org/EGit/Contributor_Guide
[2] http://www.jcraft.com/jsch/
Previous Topic:eGit URL http://download.eclipse.org/egit/updates doesn't have any repository.
Next Topic:How to check status of local branch with respect to remote branch in a lightweight way?
Current Time: Sun Jul 27 12:13:34 EDT 2025
Powered by FUDForum. Page generated in 0.06477 seconds
