Re: Problem using Apache and JSP [message #1221016 is a reply to message #1220867] |
Mon, 16 December 2013 12:27  |
On 12/15/2013 11:58 PM, Dusan Kuzmanovic wrote:
> Hi everyone, my name is Dusan and I am new to using JSP and Apache.
> I have this problem that I cannot run the 'test.war' file (nothing complicated, just a header and a paragraph) that I made using Eclipse. So when I deploy it thru apache manager i get this '@imageAttached' .
> I am sorry if this is the wrong section or even a wrong forum, I just googled 'Eclipse help'.
> Godspeed!
There's much unsaid here and probably much help needed.
First, you should be following a tutorial. Second, Apache doesn't run
JSPs; you need a server container like Tomcat, though you seem to be
trying to use that. Apache isn't in the mix here. Third, the newcomers'
forum isn't the the right one. There's an Eclipse web tools forum.
FUDForum. Page generated in 0.09545 seconds
