Some comments disappear when model is manipulated [message #1220761] |
Fri, 13 December 2013 08:08  |
Hi guys,
I am doing something wrong in my model manipulation/serialization code, or xtext model definition in regards of comment? Or did I stumbled upon a Xtext bug?
Basically comments disappears from my DSL at/around point of model modification, like adding or missing elements or removing wrong element.
Both // (double slash line comment) and /* */ (block comments) both courtesy of included Xbase grammar (right?).
I found this issue when I was testing my Quick Fix provider, I then extracted this unit test to demonstrate the issue:
/** FAILS */
@Test
def void addFieldToModelAndSerializeBack_testCommentsHandling_simplestCase() {
val sample = '''
deepClone
package my.home.cloners
a.b.m.Magazine {
// comment 1
val expectedModifiedSample = '''
deepClone
a.b.m.Magazine {
// comment 1
fooFoo
'''.toString
val model = parser.parse(sample)
val articleContainerField = (model as Body).cloners.get(0).asContainer
articleContainerField.addFields(newArrayList("fooFoo")) // do tested model manipulation
val result = model.serialize
assertEquals(
expectedModifiedSample,
result
instead of expected:
deepClone
a.b.m.Magazine {
// comment 1
fooFoo
I get:
deepClone
a.b.m.Magazine {
fooFoo
The comment completely disappears.
Same happens when I remove some elements from a Cloner; from root element or deeper in more complex structures.
Please check my complete unit test for further details, wat works and what does not:
https://bitbucket.org/espinosa/deepclone/src/218c858feb6c0d02a332dde598138089e57f765a/my.home.dsl.DeepClone.tests/src/my/home/dsl/deepclone/Test6DeepCloneModelManipulation.xtend?at=master
I did some further test, see my DeepCloneModelManipulationTest, and found that all comments following the spot where change in the model was made disappear when model is serialized.
I am still using Xtext 2.4.3; I have just spot you released a new version of Xtext and Xtend. 2.5.0. Great! I will give it a go and if the issue is still present I will submit a bug report.
[Updated on: Fri, 13 December 2013 08:09] by Moderator
Re: Some comments disappear when model is manipulated [message #1239183 is a reply to message #1220835] |
Mon, 03 February 2014 10:23  |
I have exactly the same problem, with an ISemanticModification
Foo foo = DSLFactory.eINSTANCE.createFoo();
bar.setFoo(foo);
If I serialize the EObject bar before the set, comments are in place, but after comments are moved.
I'm running Xtext 2.5.0.v201312110906
Thanks for your answer
Best Regard
Sylvain
FUDForum. Page generated in 0.05914 seconds
