Home » Archived » BIRT » BIRT runtime error (The cube result for crosstab is invalid(=null))
icon5.gif  BIRT runtime error [message #1220486] Thu, 12 December 2013 02:14 Go to next message
Hi, all,
I design a report and run very well with eclipse, but when I try to use BIRT Runtime to generate the report, I always got following error.both 3.7.2 and 4.3.1.
Any idea??
F:\birt-run2\ReportEngine>genReport.bat -f pdf GEN3_SAT.rptdesign
F:\birt-run2\ReportEngine>ECHO off
2013-12-12 15:01:41 org.eclipse.birt.report.engine.executor.ExecutorManager$Exec
utorContext executeQuery
SEVERE: An exception occurred during processing. Please see the following message
for details:
exception.error
Error happens when create hierarchy:Group.NewTabularHierarchy.
org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred
during processing. Please see the following message for details:
exception.error
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.exec
ute(DataRequestSessionImpl.java:644)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteCube(D
teDataEngine.java:233)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(Ab
stractDataEngine.java:272)
at org.eclipse.birt.report.engine.executor.ExecutorManager$ExecutorConte
xt.executeQuery(ExecutorManager.java:441)
at org.eclipse.birt.report.item.crosstab.core.re.executor.BaseCrosstabEx
ecutor.executeQuery(BaseCrosstabExecutor.java:122)
at org.eclipse.birt.report.item.crosstab.core.re.executor.CrosstabReport
ItemExecutor.execute(CrosstabReportItemExecutor.java:102)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(
ExtendedItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicat
eItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportIt
emExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReport
ItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layout
Nodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChild
ren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTML
AbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resum
eLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layou
tNodes(HTMLInlineStackingLM.java:160)
Nodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren
(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPage
LM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.lay
out(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAnd
RenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRe
nderTask.java:77)
at org.eclipse.birt.report.engine.api.ReportRunner.runAndRenderReport(Re
portRunner.java:223)
at org.eclipse.birt.report.engine.api.ReportRunner.execute(ReportRunner.
java:163)
at org.eclipse.birt.report.engine.api.ReportRunner.main(ReportRunner.jav
a:122)
Caused by: org.eclipse.birt.data.engine.core.DataException: exception.error
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.mate
rializeCube(DataRequestSessionImpl.java:773)
ute(DataRequestSessionImpl.java:633)
... 28 more
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: Error happ
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.popu
lateDimension(DataRequestSessionImpl.java:1466)
lateDimensions(DataRequestSessionImpl.java:1325)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.crea
teCube(DataRequestSessionImpl.java:824)
rializeCube(DataRequestSessionImpl.java:758)
... 29 more
Caused by: java.io.EOFException
at org.eclipse.birt.data.engine.olap.data.document.AbstractBufferedRando
mAccessObject.readFully(AbstractBufferedRandomAccessObject.java:578)
mAccessObject.readFully(AbstractBufferedRandomAccessObject.java:555)
mAccessObject.readInt(AbstractBufferedRandomAccessObject.java:230)
at org.eclipse.birt.data.engine.olap.data.document.FileDocumentManager.g
etNextBlock(FileDocumentManager.java:311)
at org.eclipse.birt.data.engine.olap.data.document.BlockRandomAccessObje
ct.<init>(BlockRandomAccessObject.java:49)
at org.eclipse.birt.data.engine.olap.data.document.FileDocumentManager.c
reateDocumentObject(FileDocumentManager.java:230)
at org.eclipse.birt.data.engine.olap.data.impl.dimension.Hierarchy.creat
eHierarchyDocumentObject(Hierarchy.java:248)
eAndSaveHierarchy(Hierarchy.java:118)
at org.eclipse.birt.data.engine.olap.data.api.cube.CubeMaterializer.crea
teHierarchy(CubeMaterializer.java:126)
lateDimension(DataRequestSessionImpl.java:1458)
... 32 more
2013-12-12 15:01:41 org.eclipse.birt.report.item.crosstab.core.re.executor.Cross
tabReportItemExecutor execute
SEVERE: The cube result for crosstab is invalid(=null).
Re: BIRT runtime error [message #1220698 is a reply to message #1220486] Fri, 13 December 2013 02:36 Go to previous messageGo to next message
Thanks for check this topic, I try whole day today, even use the sample in eclipse help page, I still get the error:
http://help.eclipse.org/helios/index.jsp?topic=%2Forg.eclipse.birt.doc%2Fbirt%2Fcrosstab.17.2.html
I attach the rptdesign file with public data cube, please help me to have a look, thanks.
Sam
Re: BIRT runtime error [message #1220703 is a reply to message #1220698] Fri, 13 December 2013 03:22 Go to previous messageGo to next message
anyone help me to try with my rptdegsin file on your runtime environment with following command and post me your result?:
Thanks you very much for your help.
Reagrds,
Sam
Re: BIRT runtime error [message #1220829 is a reply to message #1220703] Fri, 13 December 2013 17:21 Go to previous messageGo to next message
So, you're executing this report with Java or with the viewer? If Java, can you attach the java class you're using to run the report, as well?
Re: BIRT runtime error [message #1220909 is a reply to message #1220829] Mon, 16 December 2013 00:13 Go to previous messageGo to next message
Hi, Michael,
Thank you for your help, i did not executed the report with java, I just downlaod the runtime 3.7.2 and 4.3.1, try to use the reportengine on the runtime folder to generate the report with my rptdegisn file. I only add "mysql-connector-java-5.1.26-bin.jar" to the lib of runtime, because I use mysql as database of my data. please check attach
Sam Wu
Re: BIRT runtime error [message #1220913 is a reply to message #1220486] Mon, 16 December 2013 01:42 Go to previous messageGo to next message
Hi, all,
Thanks for review this topic, if you have your runtime environment.
Plrease help me to have a run with my rptdesign file and pose me your result.
second attachment is basic on eclipse public database, you can always run it with internet.
Thanks.
Sam Wu
Re: BIRT runtime error [message #1220939 is a reply to message #1220486] Mon, 16 December 2013 04:30 Go to previous messageGo to next message
It is this runtime bug?
Dec 16, 2013, 5:27 PM
The following items have errors:
ReportDesign (id = 1):
- An exception occurred during processing. Please see the following message for details:
exception.error
exception.error ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details:
exception.error
at org.eclipse.birt.report.engine.executor.ExecutorManager$ExecutorContext.executeQuery(ExecutorManager.java:457)
at org.eclipse.birt.report.item.crosstab.core.re.executor.BaseCrosstabExecutor.executeQuery(BaseCrosstabExecutor.java:122)
at org.eclipse.birt.report.item.crosstab.core.re.executor.CrosstabReportItemExecutor.execute(CrosstabReportItemExecutor.java:102)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(ExtendedItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:181)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.engine.api.ReportRunner.runAndRenderReport(ReportRunner.java:245)
at org.eclipse.birt.report.engine.api.ReportRunner.execute(ReportRunner.java:168)
at org.eclipse.birt.report.engine.api.ReportRunner.main(ReportRunner.java:127)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
exception.error
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:657)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteCube(DteDataEngine.java:233)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:280)
at org.eclipse.birt.report.engine.executor.ExecutorManager$ExecutorContext.executeQuery(ExecutorManager.java:447)
... 14 more
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.materializeCube(DataRequestSessionImpl.java:788)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:646)
... 17 more
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: Error happens when create hierarchy:Group.NewTabularHierarchy.
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.populateDimension(DataRequestSessionImpl.java:1487)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.populateDimensions(DataRequestSessionImpl.java:1345)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.createCube(DataRequestSessionImpl.java:839)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.materializeCube(DataRequestSessionImpl.java:773)
... 18 more
at org.eclipse.birt.data.engine.olap.data.document.AbstractBufferedRandomAccessObject.readFully(AbstractBufferedRandomAccessObject.java:578)
at org.eclipse.birt.data.engine.olap.data.document.AbstractBufferedRandomAccessObject.readFully(AbstractBufferedRandomAccessObject.java:555)
at org.eclipse.birt.data.engine.olap.data.document.AbstractBufferedRandomAccessObject.readInt(AbstractBufferedRandomAccessObject.java:230)
at org.eclipse.birt.data.engine.olap.data.document.FileDocumentManager.getNextBlock(FileDocumentManager.java:311)
at org.eclipse.birt.data.engine.olap.data.document.BlockRandomAccessObject.<init>(BlockRandomAccessObject.java:49)
at org.eclipse.birt.data.engine.olap.data.document.FileDocumentManager.createDocumentObject(FileDocumentManager.java:230)
at org.eclipse.birt.data.engine.olap.data.impl.dimension.Hierarchy.createHierarchyDocumentObject(Hierarchy.java:248)
at org.eclipse.birt.data.engine.olap.data.impl.dimension.Hierarchy.createAndSaveHierarchy(Hierarchy.java:118)
at org.eclipse.birt.data.engine.olap.data.api.cube.CubeMaterializer.createHierarchy(CubeMaterializer.java:126)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.populateDimension(DataRequestSessionImpl.java:1479)
... 21 more
Re: BIRT runtime error [message #1222218 is a reply to message #1220939] Thu, 19 December 2013 18:10 Go to previous message
I just ran the attached report above in 4.3.0 with no issues. What is your Java version?
Previous Topic:BIRT Report Viewer 4.3.1 won't run on Webshere 7
Next Topic:Deploying birt in tomcat
Current Time: Sat Jul 19 03:03:48 EDT 2025
Powered by FUDForum. Page generated in 0.05397 seconds
