Home » Eclipse Projects » Eclipse Scout » Wizard initial focus
Wizard initial focus [message #1220519] Thu, 12 December 2013 05:27 Go to next message
I'm having troubles with the initial focus of a Wizard.
Opening the wizard as a dialog, the first field gets the focus. When opening the wizard within a view (DISPLAY_HINT_VIEW) no focus is set.
How can I set the focus in second case?
Thomas
Scout Version: 3.9.1
Re: Wizard initial focus [message #1220766 is a reply to message #1220519] Fri, 13 December 2013 08:19 Go to previous messageGo to next message
Hi Thomas,
Nice to see you here, on this forum!
Have a look at: IFormField#requestFocus()
I had the same discussion yesterday with someone also asking this...
Focus handling is not the biggest strength of Eclipse Scout. If you think we should improve something in this domain, feel free to make a proposal...
Nb: From what I know, your project uses or will use 3.10. In particular 3.10.0-M4. If your sources indicates 3.9.1 this is not an official version because of all the patches your project has applied on your scout-fork.
Re: Wizard initial focus [message #1221001 is a reply to message #1220519] Mon, 16 December 2013 10:46 Go to previous messageGo to next message
Hello Jeremie,
I tried IFormField#requestFocus() but the requestFocus is not accepted.
Shall I create a new Bug?
Re: Wizard initial focus [message #1223392 is a reply to message #1221001] Mon, 23 December 2013 03:52 Go to previous message
I've opened a Bugzilla ticket for this issue: https://bugs.eclipse.org/bugs/show_bug.cgi?id=424603
Summary: requestFocus does not work when displayHint of wizard is set to VIEW (default DIALOG works).
Previous Topic:Password decoding
Next Topic:Custom security filter calling a scout service
Current Time: Sat Jul 26 06:16:22 EDT 2025
Powered by FUDForum. Page generated in 0.07176 seconds
