Home » Eclipse Projects » Virgo » Enabling DEBUG logging in spring security classes(Enabling DEBUG logging in spring security classes)
Enabling DEBUG logging in spring security classes [message #1219763] Thu, 05 December 2013 12:05 Go to next message
I have added the following to serviceability.xml to enable logging in spring security code.
<logger level="DEBUG" additivity="false" name="org.springframework.security">
        <appender-ref ref="SIFTED_LOG_FILE" />
        <appender-ref ref="LOG_FILE" />
</logger>
Unfortunately, this doesn't seem to do the trick. I don't see any DEBUG messages from spring security classes. Is there any other configuration I need to modify? Any help is greatly appreciated.
I am using Virgo 3.5.0 and spring-security 3.1.4.
Raghu
Re: Enabling DEBUG logging in spring security classes [message #1219838 is a reply to message #1219763] Fri, 06 December 2013 03:50 Go to previous messageGo to next message
Hi Raghu,
with your snippet I do get DEBUG and INFO messages:
[2013-12-06 09:30:26.471] DEBUG start-signalling-1           .s.s.w.a.e.ExpressionBasedFilterInvocationSecurityMetadataSource  Adding web access control expression 'hasRole('ROLE_USER')', for Ant [pattern='/forms/**']
[2013-12-06 09:30:26.472] DEBUG start-signalling-1           .s.s.w.a.e.ExpressionBasedFilterInvocationSecurityMetadataSource  Adding web access control expression 'permitAll', for Ant [pattern='/']
[2013-12-06 09:30:26.472] DEBUG start-signalling-1           o.s.security.web.access.intercept.FilterSecurityInterceptor       Validated configuration attributes
[2013-12-06 09:30:26.474] INFO  start-signalling-1           org.springframework.security.web.DefaultSecurityFilterChain       Creating filter chain: org.springframework.security.web.util.AnyRequestMatcher@1, [org.springframework.security.web.context.SecurityContextPersistenceFilter@144edb15, org.springframework.security.web.authentication.logout.LogoutFilter@45114a1d, org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter@7218d957, org.springframework.security.web.authentication.ui.DefaultLoginPageGeneratingFilter@3d651946, org.springframework.security.web.authentication.www.BasicAuthenticationFilter@385e6227, org.springframework.security.web.savedrequest.RequestCacheAwareFilter@3c7e0b5a, org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter@771b60bc, org.springframework.security.web.authentication.AnonymousAuthenticationFilter@266c13bb, org.springframework.security.web.session.SessionManagementFilter@1836db2, org.springframework.security.web.access.ExceptionTranslationFilter@5b96c1e4, org.springframework.security.web.access.intercept.FilterSecurityInterceptor@6938eb6]
[2013-12-06 09:30:26.480] INFO  start-signalling-1           o.s.security.config.http.DefaultFilterChainValidator              Checking whether login URL '/spring_security_login' is accessible with your configuration
[2013-12-06 09:30:26.482] DEBUG start-signalling-1           o.s.security.config.http.DefaultFilterChainValidator              Default generated login page is in use
Please note the various types of abbreviations for types with long names and lots of packages:
  • org.springframework.security.web.DefaultSecurityFilterChain
  • o.s.security.web.access.intercept.FilterSecurityInterceptor
  • .s.s.w.a.e.ExpressionBasedFilterInvocationSecurityMetadataSource
florian
Re: Enabling DEBUG logging in spring security classes [message #1219903 is a reply to message #1219838] Fri, 06 December 2013 10:09 Go to previous messageGo to next message
Thanks. I will double check but I didn't see any debug messages, in particular from spring security ACL classes.
Re: Enabling DEBUG logging in spring security classes [message #1219997 is a reply to message #1219903] Sun, 08 December 2013 16:37 Go to previous messageGo to next message
Just to update, I have done some reflection hackery to access the "logger" field of the following two classes.
- org.springframework.jdbc.core.JdbcTemplate
- org.springframework.security.acls.AclPermissionEvaluator
Both logger objects are of type "org.apache.commons.logging.impl.Jdk14Logger" but logger.isDebugEnabled() returns true for JdbcTemplate while the same call for AclpermissionEvaluator returns false. So I could see DEBUG messages from JdbcTemplate but there were no debug messages from either AclPermissionEvaluator or any other ACL classes.
For some reason, the debug level logger configuration in serviceability.xml is not taking effect for Acl classes.
If there is any one out there using spring security ACL with Virgo, can you please enable debug level as mentioned in the original post and see if you are seeing any DEBUG messages?
Raghu
Re: Enabling DEBUG logging in spring security classes [message #1219998 is a reply to message #1219997] Sun, 08 December 2013 16:37 Go to previous messageGo to next message
I should have mentioned in my earlier post that I enabled DEBUG for "org.springframework".
Re: Enabling DEBUG logging in spring security classes [message #1220405 is a reply to message #1219838] Wed, 11 December 2013 09:34 Go to previous messageGo to next message
It turns out the problem was with subclassing AclPermissionEvaluator. With the subclass in place, AclPermissionEvaluator's logger was not seeing the debug level configuration. When I switched to using it directly, debug was enabled and I could see the debug log messages in Virgo's log.
It is not clear to me why the subclass should cause problems with logging here, though.
Raghu
Re: Enabling DEBUG logging in spring security classes [message #1220504 is a reply to message #1220405] Thu, 12 December 2013 04:00 Go to previous messageGo to next message
I guess your subclass resides in a different package. In this case you will have to update your log configuration to enable logging for your own code.
Re: Enabling DEBUG logging in spring security classes [message #1220580 is a reply to message #1220504] Thu, 12 December 2013 10:50 Go to previous message
This did occur to me and I enabled DEBUG for the my subclass's package. How ever, it didn't help.
Previous Topic:How to verify Application are Deployed
Next Topic:Equinox based War to Virgo plan
Current Time: Wed Jul 23 23:34:13 EDT 2025
Powered by FUDForum. Page generated in 0.06566 seconds
